Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 01-07-2012, 12:15 PM
albabis is on a distinguished road
PCI parallel port error
Hi
I have to change the internal parallel port with a PCI one. I install the new one and the drivers from it.The port looks ok, when i run lspci -v
04:02.0 Parallel controller: SUNIX Co., Ltd. Device 1999 (prog-if 03)
Subsystem: SUNIX Co., Ltd. Device 0100
Flags: medium devsel, IRQ 18
I/O ports at dce0 [size=8]
I/O ports at dce8 [size=8]
I/O ports at dcf0 [size=16]
Capabilities: [40] Power Management version 3
But when i start the EMC i take the message "Device or resource busy".
I have spend several hours reading previous messages and the documentation without lack.
Old 01-07-2012, 07:10 PM
chester88 is on a distinguished road
What version of EMC are you using?
I believe this means that linux is using the parallel port for something else.
What config are you using to test with?
Old 01-07-2012, 09:44 PM
Lake Cruiser is on a distinguished road
Don't know about Linux but I had an issue with a PCI board in the fact that the address was EC00 and not the usual 378. This was a MOSChip board. Maybe this will help.
Old 01-08-2012, 02:48 AM
Hi
EMC version is 2.5.0-pre2
This is part of my HAL file
loadrt probe_parport
loadrt hal_parport cfg="0xdce0"
setp parport.0.reset-time 1000
loadrt stepgen step_type=0,0,0,0
addf parport.0.read base-thread
addf stepgen.make-pulses base-thread
addf parport.0.write base-thread
addf parport.0.reset base-thread
I am not sure what you mean, i change the address with stepconf and if EMC starts i will see if signal are there.
Old 01-08-2012, 04:56 AM
stepconf made the config that what I meant.
Have you tried the other addresses listed ?
Old 01-08-2012, 06:19 AM
Yes.
The first two produce the error. The last one does not produce error but not working. there is no signal output. I use oscilloscope to measure it.
parallel port lucky021 Canadian Club House 3 05-02-2010 01:42 PM
NC parallel port? Soloratov General CNC (Mill and Lathe) Control Software (NC) 3 01-12-2010 09:50 PM
parallel port or parallel universe bruno34 Taig Mills & Lathes 5 04-15-2009 10:58 AM
Where's the parallel port? cdlenterprises Mastercam 23 01-20-2007 05:23 PM
2nd PCI Parallel Port sunmix Mach Software (ArtSoft software) 8 11-22-2006 02:17 PM
