| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I bougth nema 23 cnc kit by ebay and connect every componenet to pc and check the wiring again and again, and no movement happens please help me |
| If you can tell more about what you did it would be easier to help. There is too much that can go wrong just to start writing possibilities down.
__________________ Sven http://www.puresven.com/?q=building-cnc-router |
| In the attached files I provided the connections and the breakout board type, and yes I connect the power supply and did all the necessary work, but no respond. In addition that I don't now how to check every component if it is work correctly or not. the stepper got too hot when I turn on the power supply. |
#12
| Well since you said you have checked your wiring to the diagram.. Well the next thing I might do is check each individual component. disconnect the power supply and check the output. disconnect the breakout board and check that it actually sends out pulses with a multimeter. The motors can become quite hot if the driver doesn't lower the output when it stops. |
| Free MastercamX setup sheets for milling free 3 axis milling active designer setup sh | bigban | Mastercam | 1 | 07-26-2011 05:28 AM |
| Looking to buy my first CNC setup. Thoughts on this Partner III / Cent IV setup? | motoguy | Milltronics | 13 | 06-30-2011 09:34 AM |
| CNC setup Help | tlf92 | TurboCAD/CAM | 0 | 02-23-2010 06:59 PM |
| New Machine Build- Need help with setup | LaserImage | Stepper Motors and Drives | 25 | 07-18-2008 01:25 PM |
| What is your setup? | dolanosa | CNC Wire Foam Cutter Machines | 5 | 10-09-2005 02:00 AM |
