| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hi All, I am converting a Deckel mill to EMC using the Mesa 7I37 TA, 5I23, 7I33 TA and AMT-2 encoders. The motors are DC brush type with a Siemens control. I have a problem with the 7I33T card connections to my Amp. I have four input wires to the Amp Earth wire Wire from a relay Two wires from the old controller. One of these wires must go to the +- 10V (pin 10 on the 7I33Tcard) where do I connect the other wire from the controller? Are the GND wires on this card all common? (Pins 9,11,21,23) Someone suggested I earth that wire, just want to be sure before I damage something. Regards |
| I haven't even ordered my 7i33TA yet but the info I got in another thread was that (for drive0) I should hook the +-10v to AOUT0 (pin 10) and the other wire to gnd (pin11). Maybe Peter Wallace can give us a clue. I am very interested in what you find out. Alan
__________________ http://www.alansmachineworks.com |
| It helps to look at the Engineering Resources on the AMC drive page. This one shows using a buffer if using single ended 10v analogue input. So far I have never had to use a buffer with the cards I use. http://www.a-m-c.com/download/manual...tallManual.pdf Page 36, fig 3.12. Al.
| AMC REF+IN --> 7I33TA AOUT AMC REF-IN --> 7I33TA GND (pin adjacent to AOUT) These 2 wires should be a shielded twisted pair with the shield terminated to 7I33TA GND In addition the signal GND of the AMC drive should connect to the 7I33TA GND No buffer s needed as the 7I33 has a low impedance output |
| Hi All, I am still having problems. I can’t get the motors to turn from the +-10v input I get the 10v on the Amps from EMC but the motors would not turn. I have one wire that came from the original controller going on to the front card by the Amps. I gave that wire current using a globe in the circuit and it blew the main fuse on that Amp when I energized it with the +-10v. I think that wire must give the Amps a signal to work. The Amps are made by Siemens No: MLFM :6RA4013-5BA01 Could anyone help me with information on these Amps? It would be greatly appreciated. Regards Gombault |
1. You can enable the drive 2. You can make your motor run in each direction by putting a small voltage into the analog input (a 1.5V battery will do here) "I gave that wire current using a globe in the circuit and it blew the main fuse on that Amp when I energized it with the +-10v." I find this rather scary... current from where? It really looks like you need to find the drive connection information somewhere I found someone offering schematics on CNCZONE a few years ago, maybe that should be pursued (google "siemens simoreg 6RA4013 schematics ") Last edited by PCW_MESA; 11-18-2011 at 09:25 AM. Reason: omission |
| Need Help!- EMC and Mesa | Holzwurm56 | LinuxCNC (formerly EMC2) | 4 | 09-26-2011 11:09 AM |
| Mesa punzonadora | ferlemega | Spanish CNCzone | 1 | 08-31-2010 05:08 PM |
| Brand new to EMC,need some Mesa help | JR1050 | LinuxCNC (formerly EMC2) | 2 | 06-11-2010 10:04 AM |
| Mesa de agua | goyoasturias | Spanish CNCzone | 5 | 01-09-2009 01:06 PM |
| Mesa, AZ | john matthews | Mentors & Apprentice Locator | 1 | 08-24-2008 01:48 PM |
