Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-22-2011, 10:06 AM
beezerlm's Avatar
beezerlm is on a distinguished road
HEALD ID GRINDER EMC2 PROJECT
I have an old heald ID grinder model 271, I believe from 1951. The machine is in good shape other than the hydraulics. I have decided to attempt to take over control of the main table cylinder by means of a moog servovalve operated by EMC2. I have never used EMC, but I have done a lot of Mach 3 retrofits in the past. Also, my knowledge of hydraulics is limited, so I hope to learn a lot from this.
Here are pics of the machine. I tore it all apart and painted it a few years back the same color as my chevalier surface and OD grinder. It needs cleaned up a bit cause its been sitting for a few years.
ID:	144503   Click image for larger version
Old 10-22-2011, 10:26 AM
beezerlm's Avatar
Here is a picture of the Moog valve, a Mesa 7i43, and a precision level that was build into the machine table. The back of the level says "June 51" on it. I also have a dell optiplex 620 with EMC2 installed I plan to use.
Here are the specs on the servovalve:
-772-280 has model code HXXFOFM4VAL
H high response (standard)
XX 4 GPM
F 3000 psi max pressure
O 4-way, axis cut spool
F standard, low flow pilot
M midposition spool (no bias offset)
4 internal pilot supply pressure
V Viton seals
A 4 pin connector, orientation over "A" port
L +/-40mA command signal
Old 10-22-2011, 10:29 AM
beezerlm's Avatar
Here the diagram of the hydraulic system from the manual. I plan on keeping just the area circled.
Old 10-22-2011, 10:39 AM
beezerlm's Avatar
Here is a sketch of a manifold block I plan on making to mount to the moog servovalve.
Old 10-22-2011, 02:32 PM
svenakela is on a distinguished road
Cool! Did you post this to the mailing list?
Old 10-22-2011, 09:06 PM
beezerlm's Avatar
I did not know there was a mailing list. Is this the URL? Gmane -- Mail To News And Back Again
Old 10-22-2011, 10:16 PM
Al_The_Man's Avatar
How do you intend controlling the valve? or are you going to use a simple ±10vdc analogue to 40ma conversion?
Old 10-23-2011, 05:15 AM
The mailing list is the info channel number on when it comes to EMC2.
LinuxCNC.org - Community
Old 10-23-2011, 08:56 PM
beezerlm's Avatar
Yes, I was hoping to accomplish exactly that. Is that possible with the mesa 7i43?
Old 10-23-2011, 08:58 PM
beezerlm's Avatar
I subscribed to the list. Should I post a link to this thread on the mailing list? I am not familiar with the mailing lists and what to expect.
Old 10-24-2011, 05:53 AM
Write a hello and describe what you're doing, that would be fine.
I think you'll get some good response, all the sharp edged guys are there.
  #12   Ban this user!
Old 10-25-2011, 06:52 PM
beezerlm's Avatar
Today I made a trip to a friends shop who's sole focus is hydraulics. I had him make up a couple new lines for the machine and and talked to him a bit about what I am doing.
He said he would run a few calculations on what I can expect for a feedrate in in/min with 4gpm rating on the servovalve and a 3" cylinder bore ( 3" is a guess ).
I also posted a message on the emc2 mailing list regarding this project. ( I don't see it there yet? )
Tags
emc2, heald, hydraulic, mach 3, servovalve
Need Help!- sunnen grinder lathe attachment or in block grinder? Goldhunter_2 General Metal Working Machines 4 06-28-2011 07:42 AM
New Machine Build- building manuel surface grinder and a od grinder toolsrule Benchtop Machines 7 05-09-2011 09:06 AM
Need Help!- Heald (Cincinnati) ID grinder beezerlm General Metal Working Machines 2 07-27-2010 06:15 AM
looking for swisher grinder or swisher type of grinder JMG1 Toolgrinding & Toolgrinding Machines 1 09-04-2008 07:58 AM
Need Help!- need a manual for Heald plain 271 tjenkins007 Want To Buy...Need help! 0 03-20-2008 11:34 AM
