Page 4 of 4 FirstFirst 1234
Results 37 to 48 of 48
Thread: HEALD ID GRINDER EMC2 PROJECT
  1. #37
    Registered beezerlm's Avatar
    Oct 2005
    I bought a 24" X 24" enclosure for the machine. Hoping to do something like this drawing.
    Attached Thumbnails Attached Thumbnails HEALD ID GRINDER EMC2 PROJECT-0314121944a.jpg   HEALD ID GRINDER EMC2 PROJECT-control_panel.jpg
  2. #38
    Oct 2005
    Question
    Is there a way to make a somewhat conversational interface with LinuxCNC?
    I am planning on setting a zero against the shoulder of the part and pressing cycle start to prompt "SET Z AXIS STROKE" AND "SET FEED IN IPM". After entering the data, I want the table to reciprocate from zero to the stroke distance repeatedly. Then maybe have an interrupt button to back the grinding wheel out for checking size or changing parts.
    Could some one lead me in the right direction for this?
  3. #39
    Oct 2005
    Here's one of the front plates for the soon to be panel. I plan to clean this up and have it flash chromed. I'm going to paint the enclosure black.
    Attached Thumbnails Attached Thumbnails HEALD ID GRINDER EMC2 PROJECT-panel.jpg
  4. #40
    Dec 2003
    Considered reverse engraved lamacoid?
    Attached Thumbnails Attached Thumbnails HEALD ID GRINDER EMC2 PROJECT-dscf0195.jpg
  • #41
    Oct 2005
    Al,
    I did not know what a lamacoid was until I just googled it. I already have the plates made and ready for plating but I will look into lamacoids next time. Know of any good suppliers?
  • #42
    Oct 2005
    Smile Video
    Here is a video of the machine grinding a 5° angle on the inside of a grinding wheel hub/mount we are making. Sorry it's a little shaky.
    http://www.youtube.com/watch?v=NMkNCSUJBvs]Heald id grinder run by LinuxCNC - YouTube
  • #43
    Mar 2004
    Sweden
    Wow!!!
  • #44
    Sep 2008
    UK
    Quote Originally Posted by beezerlm View Post
    Is there a way to make a somewhat conversational interface with LinuxCNC? I am planning on setting a zero against the shoulder of the part and pressing cycle start to prompt "SET Z AXIS STROKE" AND "SET FEED IN IPM". After entering the data, I want the table to reciprocate from zero to the stroke distance repeatedly.
    This is possible, but I wouldn't claim that it is easy.
    You could write a new UI in Glade, and interface that directly with your existing HAL. In this scenario you wouldn't have any need for the Axis UI, or the G-code interpreter. You might even be able to do away with the motion module.
    I know of one chap who has done this for a cutter sharpening machine.
    If this sounds like more of a challenge than you fancy, then you could look at using ngcgui
    NGCGUI
    Or possibly something similar to my lathe config.
    http://www.bodgesoc.org/lathe/lathe.html
    Did you ever manage to subscribe to the LinuxCNC users mailing list? We have a serious spam problem and it is possible you were lost in the noise.
  • #45
    Oct 2005
    svenakela - Thanks!
    Andy - Thanks for the info. I may give the NGCGUI a shot. I am still fairly new to linux but I would love to learn more.
    I have tried many times to post to the mailing list and it never shows up or gets responded to. I would like to join....Is there anyway to get around the spam filter?
  • #46
    Dec 2003
    Al,
    I have a guy that specializes in Panels, but a local sign engraver should be able to fit you up.
    Mine takes DXF or DWG so this is handy.
  • #47
    Sep 2008
    UK
    Actually, JT just created this tutorial on creating a GUI for LinuxCNC from scratch:
    Creating a GUI - LinuxCNC Support Forum
    contains lots of links and discussion, the tutorial link in the first post might be worth reading.
    Are you using Gmail? If so, have a look at
    New User Registration - LinuxCNC Support Forum
    Though I am not sure that the same applies to the mailing list.
    Otherwise, send me a private message with your email address and I will try to get you subscribed.
  • #48
    Oct 2005
    Great info thanks! Looks like I have some reading to do.
    I will send you a PM. I am subscribed to the mailing list, but my posts don't show up.
  • Page 4 of 4 FirstFirst 1234
    1. Need Help!- sunnen grinder lathe attachment or in block grinder?
      By Goldhunter_2 in forum General Metal Working Machines
      Last Post: 06-28-2011, 08:42 AM
    2. New Machine Build- building manuel surface grinder and a od grinder
      By toolsrule in forum Benchtop Machines
      Last Post: 05-09-2011, 10:06 AM
    3. Need Help!- Heald (Cincinnati) ID grinder
      By beezerlm in forum General Metal Working Machines
      Last Post: 07-27-2010, 07:15 AM
    4. looking for swisher grinder or swisher type of grinder
      By JMG1 in forum Toolgrinding & Toolgrinding Machines
      Last Post: 09-04-2008, 08:58 AM
    5. Need Help!- need a manual for Heald plain 271
      By tjenkins007 in forum Want To Buy...Need help!
      Last Post: 03-20-2008, 12:34 PM
