Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-19-2011, 04:46 PM
acondit's Avatar
acondit is on a distinguished road
Using 7i43 with Advanced Motion Control 30A8T
I picked up some used Advanced Motion Control 30A8T Controllers (Brush Type PWM Servo Amplifier). They require a +-10v analog signal.
Has anyone used these?
Is there a simple circuit to convert PWM/Dir to +-10v output?
Or am I better off just biting the bullet for a Mesa 7i33TA Quad analog servo amp interface?
Thanks,
Alan
http://www.alansmachineworks.com
Old 10-19-2011, 05:39 PM
Al_The_Man's Avatar
I have used A-M-C extensively but only with ±10vdc.
There was someone here some time ago offering a PWM to analogue convertor, not sure if they are still around.
But these amps are not very useful for Mach as the drive needs to close the loop, which the A-M-C. do not, they are for controller closed loop systems.
Old 10-19-2011, 05:46 PM
acondit's Avatar
I use EMC2 which closes the loop so that is not a problem.
Old 10-19-2011, 06:42 PM
Al_The_Man's Avatar
So you should be able to use ±10vdc, no?
Old 10-19-2011, 07:25 PM
acondit's Avatar
Yes, but I don't currently have anything to generate +-10v, while I do have something to generate PWM/Dir. Hence the questions:
Old 10-19-2011, 08:49 PM
Iron-Man's Avatar
Iron-Man is on a distinguished road
Interfacing with a PWM & Direction reference
acondit
I will also be using MESA cards. Currently working on several projects. Here is a link to Elmo motion control for a proven circuit to convert PWM-DIR to +- 10V analog. Here is the direct link:
http://www.elmomc.com/applications/a...with-a-PWM.pdf
You will still need to close the loop with encoders in EMC.
Hope this helps,
Iron-Man
Old 10-19-2011, 10:44 PM
acondit's Avatar
Thanks for the link. That is what I have been looking for.
I have a 7i43 and two 7i42TA daughter cards to which I can wire the encoders. I may go ahead and build one of these to try it out. I suspect given the parts count that buying the 7i33TA may be cheaper in the long run, since it will do the DA conversion for 4 servos. Then I could save one of the 7i42TAs for my next machine controller.
Alan
Old 10-20-2011, 09:13 AM
samco is on a distinguished road
there is also the 7i48 that does 6 axis analog. (I am using both the 7i33 and the 7i48 in my machine) (2 5i20 fpga cards)
sam
Old 10-20-2011, 02:40 PM
Iron-Man's Avatar
Mesa 5i25 ?
Has anyone used this ( 5i25) card? I am still undecided on the 5i20 or wait for the 5i25.
Iron-Man
Old 10-22-2011, 10:51 AM
acondit's Avatar
Another Question
OK, I have another question. It appears from the manual for the 30A8T that it expects 0 to +10v on one pin and -10v to 0 on another pin. The 7i33 and 7i48 have a single output pin for each amp that swings from -10v to +10v.
How do you connect the 30A8T to the 7i33 or 7i48???
Alan
Old 10-22-2011, 11:16 AM
Al_The_Man's Avatar
The 30A8 only requires two connections which strictly speaking are differential +- but if you have two conductor single ended the common goes to -ref pin and the + to the +ref pin.
Your controller card should alternate polarity to alternate motor direction.
Your 7i card should have a common to the ±10vdc signal.
  #12   Ban this user!
Old 10-22-2011, 12:01 PM
acondit's Avatar
Thanks Al,
OK, on the 30A8T
Pin 1 is +10v/3mA output
Pin 2 is signal gnd
Pin 3 is -10v/3mA output
Pin 4 is +15v(max) +Ref Input
Pin 5 is -15v(max) -Ref Input
Lets just take the connections for one servo and see if I have it correct:
The first three pins from the 30A8T are an anemic power supply.
You are saying that I connect the +/-10v signal from the 7i48 pin10 AOUT0 to 30A8T pin4 +RefIn.
Then connect the 7i48 pin11 gnd to 30A8T pin5 -RefIn.
Is that correct?
I edited this to attach the schematic for the 30A8T to show the input connections for it.
Alan
Advanced Motion Control Drives - Need Help ktmrider Servo Motors and Drives 3 12-31-2010 04:11 PM
Question about AMC 30A8T servo drive Jackal66 Servo Motors and Drives 5 10-31-2010 08:20 PM
G08 Advanced Preview Control ggborgen G-Code Programing 15 08-06-2010 02:10 AM
AI Advanced preview control qmas99 Fanuc 1 09-21-2008 08:49 PM
advanced motion servo drives cueshark Servo Motors and Drives 2 01-15-2007 09:42 PM
