Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-17-2011, 09:38 PM
T_Brown is on a distinguished road
Z-Axis Config
I am trying to setup my machine with home/limit switches and my z-axis started acting funny. I can get it to home properly, but then when I try to run any type of code it either runs in the wrong direction, or hits a soft limit or something. Can someone please share a couple screen shots of their x,y&z axis config wizard screens? I feel like i can figure out how to fix mine if I see someone who has it working correctly. Thanks,
Old 10-18-2011, 12:46 AM
chester88 is on a distinguished road
when you jog the Z axis does it move the right way?
How did you build the configuration?
Old 10-18-2011, 08:42 AM
Yes it jogs in the right direction, but I have the leadscrew pitch at -4. I can't remember if I saw to do that somewhere or just tried that and it made it work correctly. I used the stepconf wizard to set it up.
Old 10-19-2011, 11:30 PM
tommylight is on a distinguished road
post some pictures of your z axis and the switches, and in the mean time try editing that config and changing the "oposite" or something like that near the home switch seting in the pinout menu. I dont remember how i had it setup in my plasma cutter but i know i had to fidle with that to make it home and move properly.
Old 10-20-2011, 11:54 PM
CaptainVee is on a distinguished road
Try to return the pitch to +4 and then invert the direction in a checkbox, that is meant for reversing direction.
Sven
http://www.puresven.com/?q=building-cnc-router
Old 11-19-2011, 01:25 PM
still frustrated
Well I finally got some time to mess around wihnthis again. I changed my pitch to positive and inverted the direction pin out however it still won't work properly. I got it to move in rthe right direcioms and got it to find hme, but it exceeds soft limits when I try and ru something. I used stepconifg to set it up. Anyone have a screen shot of their working z axis? Thanks,
Need Help!- 4 Axis TB6560 to Mach3 Config ? ? brutusgraphics Controller & Computer Solutions 3 07-08-2011 04:31 PM
Need help with config justin bowser Mach Mill 2 05-09-2011 07:53 AM
New Machine Build- Need Help with 2-AXIS Config WoR LinuxCNC (formerly EMC2) 2 11-25-2009 06:37 PM
Config for 2 motors on x-axis (w/ Gecko g540) rogerer LinuxCNC (formerly EMC2) 5 05-16-2009 09:30 PM
Old 4-axis box and Mach2 spindle config Guy Smiley Xylotex 2 04-12-2006 01:47 AM
