Results 1 to 6 of 6
Thread: EMC Lathe Handwheel
    Nov 2005
    Germany
    EMC Lathe Handwheel
    Hi ,
    I want to control my lathe with EMC and servomotors and a uhu servodriver .
    The lathe has two handwheels build in , does someone knows in what kind of way this is possible to use the handwheels for convetionell turning , what HAL file I need ?
    Many thanks for your help
    Hans
    Nov 2005
    Do you mean you want to use the hand wheels from a conventional lathe?
    Or are you wanting to add electronic hand wheels (MPG) to the lathe?
    Adding a MPG is relativity easy.
    Nov 2005
    Germany
    Hi Chester88 ,
    I mean two electronic handwheels .
    Hans
    Jan 2007
    UK
    setting quadrature encoder wheels is straightforward in emc , but this depends to some extent on spare connections you have available , you will need 2 input pins at a minimum for A & B per wheel . see the axis jog hal commands .
    you dont say if your using a parrell port or mesa card for input i/o
    i'm not aware the uhu servodrive is compatable with EMC
    Nov 2005
    Germany
    Hi ,
    I am using a pc with two parallelports , the UHU need step and direction signals
    like a stepperdriver .
    Hans
    Jan 2007
    UK
    ok set up as per this link for each axis , should do the trick
    LinuxCNC.org - MPG Example
    if you set up in custom hal it will not be over written if you use stepconf
    set the pins approprately of course
    i presume your encoder wheels are quadrature
    1. Problem- Heidenhain Handwheel
      By resuengineering in forum General Metal Working Machines
      Last Post: 12-22-2010, 02:21 PM
    2. Need Help!- Handwheel accuracy
      By PhilCote in forum CamSoft Products
      Last Post: 08-14-2008, 07:11 AM
    3. Tree Handwheel
      By dougwr in forum Tree
      Last Post: 03-10-2008, 04:03 PM
    4. Heidenhain Hr-410 handwheel
      By khbash in forum General Electronics Discussion
      Last Post: 08-04-2007, 07:42 AM
    5. tm-1 handwheel removal?
      By superrat in forum Haas Mills
      Last Post: 11-10-2006, 10:52 AM
