Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-05-2011, 04:50 AM
CaptainVee is on a distinguished road
running emc as a simulator, running out of ideas
Hey folks,
I have a smooth running 10.04 pc in my workshop for emc, a win pc at home office for design work and cam, a laptop with ubuntu 11.04 for primary work.
I need to somehow run emc in the home office for testing (not for actual milling).
In 10.10 I could run the simulator version of emc on the laptop but since 11.04 has a newer python version, the simulator will not work.
I've tried to install it on windos using wubi, did not work.
I've tried several instalations in virtualbox on 11.04
Getting fed up now, ready to smash pc's and stuff...
Any ideas on how I can test run files without installing 10.04 besides my current 11.04 installation on the laptop?
Sven
http://www.puresven.com/?q=building-cnc-router
Old 10-06-2011, 02:03 AM
cncbasher is on a distinguished road
EMC will not work with 11.04
due to a number of factors , the changes to python being one of them.
and probably wont for some considerable time
Old 10-06-2011, 02:39 AM
tried installing it in 10.10 in virtualbox. will not run. Tried running emc from live cd in virtual box, crashes. tried live-usb emc, will not run. tried simulator in 10.04 in virtualbox after complete removal of the original emc through synaptic, error.
Now it could have something to do with onboard video of the laptop but I have had that running on the same laptop but from it's own partition. I'll try some more in that direction.
Sven
Old 10-06-2011, 05:51 AM
svenakela is on a distinguished road
Weird, I've been running EMC2 simulated long before the sim-packages were built.
Did you check:
EMC Documentation Wiki: EMC2RunningInsideVirtualbox
EMC Documentation Wiki: EMC2 Pure Simulator
You don't need Real Time patching for simulation. It might be as you say that your hardware is not good enough. You could try to make a dual boot as well.
Old 10-06-2011, 06:24 AM
Did not know the first, have been using the second one.
Just to be sure, I've installed the downloaded package through software centre rather than from terminal, is that the same?
IŽ ve been trying to start it from the live usb so to have the option of installing it to dual boot... Can not even get that to work, will not start. Was able to do so on the original drive that came with the laptop.
10.04 original gave error, 10.10 with simulator did then
Sven
Old 10-13-2011, 03:28 AM
melee is on a distinguished road
Running EMC as simulator
The unasked and therefore unanswered question, is why don't you install Ubuntu 10.04 from the live EMC2 CD on your laptop?
The only way currently for someone without a lot of linux and emc knowledge to run emc under 11.04, is to use the 10.04 rtai kernel and modules, which then negates any reason to be using 11.04.
I can't understand why so many people only want to run the latest number of Ubuntu.
If you want a particular app version, install that.
Old 10-14-2011, 01:47 AM
I can give you a reason good enough. Lets say you have a number of U11-boxes running an application you paid a big amount of money to use, and still want to run simulation.
Or, lets say you have laptop being totally crap on U10 that works splendid with U11, and still need a simulator.
There you go, at least two reasons that are totally spot on for my office.
Running EMC2 in simulation mode doesn't need RTAI.
Old 10-14-2011, 02:45 AM
as i have already made very clear before EMC will not run under 11.04
even in simulation ! , unless you wish to install and uninstall different versions of python
each time you wish to switch , believe me it''s a lot of work ( amongst others ) .
install virtualbox and install 10.04 linuxcnc LTS as an os ( not running as a live cd ) , i would also download a new copy of 10.04 Linuxcnc LTS Live cd incase of it being a bad copy .
you also mention version 10.10 ? that also will not work , so your mixing versions and kernels somehow , so i'm not suprised your having problems .
any deviation from using 10.04 live cd for emc is asking for problems , even in sim mode .
emc will not be supported under 11.04 or similar for sometime , due to some considerable changes made to 11.04.
also do not install any binary video drivers , stick with the default , this is the major area of machines crashing emc in particular nvida.
Old 10-14-2011, 05:54 PM
Weeeell... I've been running Emc2 on UBUNTU 11.04 for quite a while. Rrrright then?..
It's not that hard to make it work. But to help you guys out I made a deb-package that will run on 11.04.
Just double click it to install with Package Manager, click install and then ignore in the user warning dialog. Runs fine with Python 2.7 (which is default in 11.04).
Here's a vid on a brand new installation of EMC2-SIM on my workstation:
The package is right here, go get it:
http://dl.dropbox.com/u/45105575/emc...for_U11.04.deb
Please note I'm running 64-bit. You need that too.
I'll update the EMC2-wiki as well.
Old 10-14-2011, 07:46 PM
klick0 is on a distinguished road
I also run EMC in simulation under Ubuntu 11.04, it works fine, I don't remember doing anything special to achieve this. EMC 2.4.6.
  #11   Ban this user!
Old 10-20-2011, 09:56 AM
Oww, so close... I need 32 bit.
But thanks for the effort!
Sven
  #12   Ban this user!
Old 10-28-2011, 05:10 AM
Well, one step forward...
I' ve been able to get the laptops started with 10.04 from stick.
But now emc will not start, not in normal version nor the simulator. Any idea what to try?
I've had the simulator running from hard drive in 10.10 (will also not run from stick) and had it running in full version from stick in 10.04 but it is never reliably starting up, allmost as if it only does so the first 2-3 times and then stops working alltogether. any ideas?
Edit:
I realised I may might have found a solution earlier and written about it. After a quick search I found my older message:
You have to use a specific simulator configuration (for a mill) in the emc simulator, normal configurations will not work propperly!
Now on to testing!
Sven
Need Help!- Anyone running V22 on a Mac? sansbury BobCad-Cam 3 01-29-2009 05:12 AM
up and running clammy23 JGRO Router Table Design 1 11-13-2008 05:07 PM
Anyone out there running there car on CNG austin.mn CNCzone Club House 8 06-14-2008 01:11 PM
Running hot, really, really hot imagineer Stepper Motors and Drives 10 01-18-2007 08:51 AM
Can't get EMC running borrisl LinuxCNC (formerly EMC2) 2 08-18-2006 02:58 PM
