Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-03-2011, 04:24 PM
Todd Zuercher is on a distinguished road
XYZW 4th axis?
We have some old Digital Tool routers with 4 axis. X, Y and two Zs (Z and W). We use these machines to do a lot of 2 1/2-D v-groove carving/engraving. Most things we will use both vertical axis simultaniously to double production. I need a way to make the W slave to the Z during a run, but still be independent, for jogging, setting depth, homing ect. In other words read the z command in the g-code file as both a z command and a w command. I would like to have the ability to turn this on and off perhaps with a custom M-code.
I've tried playing with gantrykins some, but I don't think it is going to work for this.
I also need to figure out how to set up Axis for xyzw, or make xyza not think a is rotary.
Problem- a problem with slaved A-axis moving properly relative to Y-axis zool Mach Software (ArtSoft software) 34 07-05-2011 09:45 PM
the Difference of 2-Axis and 3-Axis of Vertical Mill Machine begacon Knee Vertical Mills 6 07-30-2009 06:31 AM
New Machine Build- post for 2 axis ez trak versus 3 axis ez vision tooolman G-Code Programing 0 11-28-2008 03:33 PM
Compare Catia and MCX2 for multi axis lathe/4 axis mill bob1112 General CAM Discussion 0 10-10-2008 07:15 PM
New Design - Hybrid 3-Axis Router/4-axis Foam Hot Wire Cutter the__extreme CNC Wood Router Project Log 3 02-26-2007 02:58 PM
