Page 1 of 2 12 LastLast
Results 1 to 12 of 14
Thread: EMC2 A Axis Control
    Oct 2009
    EMC2 A Axis Control
    Is there a way to configure EMC to manually move the A axis either by steps or degree incrementally. The only option Emc currently allows me is continuous.
    thanks
    Mar 2007
    U.S.A.
    What interface are you using? Probably AXIS but I need to know.
    Oct 2009
    Axis. I am also having trouble with the A in my programing. Should I be adding feed rate to the program or not. When ruining A manually it runs smooth however when I run the program it is choppy no matter what I set the fee rate at. I am running the A independent of any other axis in the program.
    Mar 2007
    U.S.A.
    you need a feed rate in the program
    would you post a sample of your program?
    Oct 2009
    N1 G20 G54
    N2 G4 P1
    N3 M3 G4 P1
    N4 M5 G4 P1
    N5 G1 A10 F300
    N6 G4 P1
    N7 M3 G4 P1
    N8 M5 G4 P1
    N9 G1 A20 F300
    N10 G4 P1
    N11 M3 G4 P1
    N12 M5 G4 P1
    N13 G1 A30 F300
    N14 G4 P1
    N15 M3 G4 P1
    N16 M5 G4 P1
    N17 G1 A40 F300
    N18 G4 P1
    N19 M3 G4 P1
    N20 M5 G4 P1
    N21 G1 A50 F300
    N22 G4 P1
    N23 M3 G4 P1
    N24 M5 G4 P1
    N25 G1 A60 F300
    N26 G4 P1
    N27 M3 G4 P1
    N28 M5 G4 P1
    N29 G1 A70 F300
    N30 G4 P1
    N31 M3 G4 P1
    N32 M5 G4 P1
    N33 G1 A80 F300
    N34 G4 P1
    N35 M3 G4 P1
    N36 M5 G4 P1
    N37 G1 A90 F300
    N38 G4 P1
    N39 M3 G4 P1
    N40 M5 G4 P1
    N41 G1 A100 F300
    N42 G4 P1
    N43 M3 G4 P1
    N44 M5 G4 P1
    N45 G1 A110 F300
    N46 G4 P1
    N47 M3 G4 P1
    N48 M5 G4 P1
    N49 M2
    Mar 2007
    U.S.A.
    Please describe exactly what the machine does for each of the first 5 lines in the example you posted.
    Oct 2009
    Laser welding. turning the A then firing the laser. There will also be X & Y Linear movements as well but after the weld sequence. We will be turning the part 360 deg but this is how far I got when I noticed the problem. This is a new setup bu did not figure to have an issue like this. We run Emc on our mill but have but only XYZ.
    Mar 2007
    U.S.A.
    The purpose of the program is not important. The exact machine response is. Pictures would be sweet. Video even better
    Oct 2009
    N1 G20 G54
    N2 G4 P1 Everything in dwell
    N3 M3 G4 P1 Spindle on (Toggle Fire laser) This works
    N4 M5 G4 P1 Spindle off (Toggle Laser off) This works
    N5 G1 A10 F300 Step motor rotates 10 deg but is jittery for lack of better explanation
    N6 G4 P1 Dwell
    I added N6 as the machine started to fire before the move was completed.
    Oct 2009
    As a side note, if I turn the A stepper hooked up to the Z axis everything works as it should. And I would have it this way except I would need need to change the stepconf every time the diameter of a piece would change.
    Mar 2007
    U.S.A.
    Do you have a way to post a link to your configuration files?
    Pastebin.com - #1 paste tool since 2002!
    Pasting the files in this forum would be a lllloooonnnngggg post.
    This is a tuning issue. The first thing I would look at is the max velocity of the A axis as set in the ini file.
    Oct 2009
    Sorry it has taken so long to get back . Her is a link to the ini file.
    ini file - Pastebin.com
    thanks
  • Page 1 of 2 12 LastLast
    1. Need Help!- 4th axis control in EMC2 (Tangent knife cutter)
      By EduardKieser in forum LinuxCNC (formerly EMC2)
      Last Post: 06-27-2011, 01:22 PM
    2. trying to use emc2 for 2x3 router control
      By mediaconvert in forum LinuxCNC (formerly EMC2)
      Last Post: 04-23-2011, 01:01 PM
    3. Hacking a Keyboard for EMC2 / Axis Control
      By scotta in forum LinuxCNC (formerly EMC2)
      Last Post: 06-14-2010, 12:45 AM
    4. Build Thread- My Control panel for EMC2
      By jbcj in forum LinuxCNC (formerly EMC2)
      Last Post: 04-25-2010, 11:20 AM
    5. Feedrate control in EMC2?
      By pauldkeeton in forum LinuxCNC (formerly EMC2)
      Last Post: 11-06-2007, 01:14 AM
