Results 1 to 5 of 5
Thread: EMC and Mesa
    Nov 2005
    Germany
    EMC and Mesa
    It's possible to use the Mesa 5i20 out of the Pc in a extra box ? With a converter Pci-e to Pci or is there a better way ? I think it's easier for wiring the 5i20 and daughter boards and the connectors for servodrive , encoder and i/o's .
    Many thanks for every answer
    Hans
    Feb 2008
    Quote Originally Posted by Holzwurm56 View Post
    Hans
    Its possible but a little awkward mechanically with a PCI card. If you want all the I/O out of the box there are several options with different prices and capabilities. Here are a few options
    1. You can use a 3X20/7I68 externally and a 5I71 or 6I71 PCIE extender in the PC box. This is expensive (~$600) but has 144 I/O points and a large FPGA
    2 You can use a 4I73 with stacked 4I65/4I68/4I69 FPGA card and again a 5I71 or 6I71 cabled PCIE extender (this is a little less expensive ~$400)
    3. You could use a 5I25 plus 7I77 (This is the cheapest for a up to 6 channel servo interface ~$250 but the 7I77 is not quite available yet)
    4. Wait for the 7I80-CBB external PCIE FPGA card (also cheap and works with standard 50 pin daughtercards)
    Nov 2005
    Germany
    Hi PCW Mesa,
    many thanks for your answer . Works EMC with the Mesa 7i80 ?
    Hans
    Feb 2008
    Hi PCW Mesa,
    Hans
    It should work with nothing more than a 1 line patch to change the subsystem ID, hardware wise (register level) its identical to all of our cards
    PEU
    PEU is offline
    Registered PEU's Avatar
    May 2005
    Buenos Aires - Argentina (I like Ribs)
    do you have pdf info for the 7i80, 7i76 and 7i77? found no info on your site for these. Thanks!!
    ● Distribuidor Syil en Argentina ● "www.syil.com.ar" ●
    1. Mesa punzonadora
      By ferlemega in forum Spanish CNCzone
      Last Post: 08-31-2010, 06:08 PM
    2. Brand new to EMC,need some Mesa help
      By JR1050 in forum LinuxCNC (formerly EMC2)
      Last Post: 06-11-2010, 11:04 AM
    3. Mesa de agua
      By goyoasturias in forum Spanish CNCzone
      Last Post: 01-09-2009, 02:06 PM
    4. Mesa, AZ
      By john matthews in forum Mentors & Apprentice Locator
      Last Post: 08-24-2008, 02:48 PM
    5. Mesa 5i20 and EMC
      By daedalus in forum LinuxCNC (formerly EMC2)
      Last Post: 06-27-2007, 03:19 PM
