I have problem - when start EMC give error, here is log file, please help me. With my desktop PC all is fine, but not work with laptop
Code:
Print file information:
RUN_IN_PLACE=no
EMC2_DIR=
EMC2_BIN_DIR=/usr/bin
EMC2_TCL_DIR=/usr/share/emc/tcl
EMC2_SCRIPT_DIR=
EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2
EMC2_CONFIG_DIR=
EMC2_LANG_DIR=/usr/share/emc/tcl/msgs
INIVAR=inivar
HALCMD=halcmd
EMC2_EMCSH=/usr/bin/wish8.5
EMC2 - 2.4.6
Machine configuration directory is '/home/milen/emc2/configs/my-mill'
Machine configuration file is 'my-mill.ini'
INIFILE=/home/milen/emc2/configs/my-mill/my-mill.ini
PARAMETER_FILE=emc.var
EMCMOT=motmod
EMCIO=io
TASK=milltask
HALUI=
DISPLAY=axis
NML_FILE=
Starting EMC2...
Starting EMC2 server program: emcsvr
Loading Real Time OS, RTAPI, and HAL_LIB modules
Realtime system did not load
Shutting down and cleaning up EMC2...
Killing task emcsvr, PID=1500
Removing HAL_LIB, RTAPI, and Real Time OS modules
Removing NML shared memory segments
Cleanup done
Debug file information:
insmod: error inserting '/usr/realtime-2.6.32-122-rtai/modules/rtai_hal.ko': -1 Operation not permitted
1500
PID TTY STAT TIME COMMAND
Stopping realtime threads
RTAPI: ERROR: could not open shared memory (errno=2)
HAL: ERROR: rtapi init failed
halcmd: hal_init() failed: -22
NOTE: 'rtapi' kernel module must be loaded
Unloading hal components
ERROR: Module hal_lib does not exist in /proc/modules
ERROR: Module rtapi does not exist in /proc/modules
ERROR: Module rtai_math does not exist in /proc/modules
ERROR: Module rtai_sem does not exist in /proc/modules
ERROR: Module rtai_fifos does not exist in /proc/modules
ERROR: Module rtai_sched does not exist in /proc/modules
ERROR: Module rtai_hal does not exist in /proc/modules
Kernel message information:
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Linux version 2.6.32-122-rtai (root@moses-6core) (gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) ) #rtai SMP Tue Jul 27 12:44:07 CDT 2010 (Ubuntu 2.6.32-122.35.rtai-rtai 2.6.32.11+drm33.2)
[ 0.000000] KERNEL supported cpus:
[ 0.000000] Intel GenuineIntel
[ 0.000000] AMD AuthenticAMD
[ 0.000000] NSC Geode by NSC
[ 0.000000] Cyrix CyrixInstead
[ 0.000000] Centaur CentaurHauls
[ 0.000000] Transmeta GenuineTMx86
[ 0.000000] Transmeta TransmetaCPU
[ 0.000000] UMC UMC UMC UMC
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: 0000000000000000 - 000000000009f000 (usable)
[ 0.000000] BIOS-e820: 000000000009f000 - 00000000000a0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000c0000 - 00000000000d0000 (reserved)
[ 0.000000] BIOS-e820: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] BIOS-e820: 0000000000100000 - 0000000017ef0000 (usable)
[ 0.000000] BIOS-e820: 0000000017ef0000 - 0000000017eff000 (ACPI data)
[ 0.000000] BIOS-e820: 0000000017eff000 - 0000000017f00000 (ACPI NVS)
[ 0.000000] BIOS-e820: 0000000017f00000 - 0000000018000000 (usable)
[ 0.000000] BIOS-e820: 00000000fffc0000 - 0000000100000000 (reserved)
[ 0.000000] DMI 2.3 present.
[ 0.000000] last_pfn = 0x18000 max_arch_pfn = 0x100000
[ 0.000000] MTRR default type: uncachable
[ 0.000000] MTRR fixed ranges enabled:
[ 0.000000] 00000-9FFFF write-back
[ 0.000000] A0000-BFFFF uncachable
[ 0.000000] C0000-C7FFF write-protect
[ 0.000000] C8000-DFFFF uncachable
[ 0.000000] E0000-FFFFF write-protect
[ 0.000000] MTRR variable ranges enabled:
[ 0.000000] 0 base 000000000 mask FF0000000 write-back
[ 0.000000] 1 base 010000000 mask FF8000000 write-back
[ 0.000000] 2 disabled
[ 0.000000] 3 disabled
[ 0.000000] 4 disabled
[ 0.000000] 5 disabled
[ 0.000000] 6 disabled
[ 0.000000] 7 disabled
[ 0.000000] PAT not supported by CPU.
[ 0.000000] e820 update range: 0000000000002000 - 0000000000006000 (usable) ==> (reserved)
[ 0.000000] Scanning 1 areas for low memory corruption
[ 0.000000] modified physical RAM map:
[ 0.000000] modified: 0000000000000000 - 0000000000002000 (usable)
[ 0.000000] modified: 0000000000002000 - 0000000000006000 (reserved)
[ 0.000000] modified: 0000000000006000 - 000000000009f000 (usable)
[ 0.000000] modified: 000000000009f000 - 00000000000a0000 (reserved)
[ 0.000000] modified: 00000000000c0000 - 00000000000d0000 (reserved)
[ 0.000000] modified: 00000000000e0000 - 0000000000100000 (reserved)
[ 0.000000] modified: 0000000000100000 - 0000000017ef0000 (usable)
[ 0.000000] modified: 0000000017ef0000 - 0000000017eff000 (ACPI data)
[ 0.000000] modified: 0000000017eff000 - 0000000017f00000 (ACPI NVS)
[ 0.000000] modified: 0000000017f00000 - 0000000018000000 (usable)
[ 0.000000] modified: 00000000fffc0000 - 0000000100000000 (reserved)
[ 0.000000] initial memory mapped : 0 - 00c00000
[ 0.000000] init_memory_mapping: 0000000000000000-0000000018000000
[ 0.000000] Using x86 segment limits to approximate NX protection
[ 0.000000] 0000000000 - 0000400000 page 4k
[ 0.000000] 0000400000 - 0018000000 page 2M
[ 0.000000] kernel direct mapping tables up to 18000000 @ 7000-b000
[ 0.000000] RAMDISK: 112ed000 - 11f73090
[ 0.000000] ACPI: RSDP 000f6d90 00014 (v00 PTLTD )
[ 0.000000] ACPI: RSDT 17efb449 00028 (v01 PTLTD RSDT 06040000 LTP 00000000)
[ 0.000000] ACPI: FACP 17efef8c 00074 (v01 SMDVIA VT5228C 06040000 PTL 000F4240)
[ 0.000000] ACPI: DSDT 17efb471 03B1B (v01 VIA PTL_ACPI 06040000 MSFT 0100000D)
[ 0.000000] ACPI: FACS 17efffc0 00040
[ 0.000000] 0MB HIGHMEM available.
[ 0.000000] 384MB LOWMEM available.
[ 0.000000] mapped low ram: 0 - 18000000
[ 0.000000] low ram: 0 - 18000000
[ 0.000000] node 0 low ram: 00000000 - 18000000
[ 0.000000] node 0 bootmap 00007000 - 0000a000
[ 0.000000] (8 early reservations) ==> bootmem [0000000000 - 0018000000]
[ 0.000000] #0 [0000000000 - 0000001000] BIOS data page ==> [0000000000 - 0000001000]
[ 0.000000] #1 [0000001000 - 0000002000] EX TRAMPOLINE ==> [0000001000 - 0000002000]
[ 0.000000] #2 [0000006000 - 0000007000] TRAMPOLINE ==> [0000006000 - 0000007000]
[ 0.000000] #3 [0000100000 - 00008b0db8] TEXT DATA BSS ==> [0000100000 - 00008b0db8]
[ 0.000000] #4 [00112ed000 - 0011f73090] RAMDISK ==> [00112ed000 - 0011f73090]
[ 0.000000] #5 [000009f000 - 0000100000] BIOS reserved ==> [000009f000 - 0000100000]
[ 0.000000] #6 [00008b1000 - 00008b414e] BRK ==> [00008b1000 - 00008b414e]
[ 0.000000] #7 [0000007000 - 000000a000] BOOTMAP ==> [0000007000 - 000000a000]
[ 0.000000] Zone PFN ranges:
[ 0.000000] DMA 0x00000000 -> 0x00001000
[ 0.000000] Normal 0x00001000 -> 0x00018000
[ 0.000000] HighMem 0x00018000 -> 0x00018000
[ 0.000000] Movable zone start PFN for each node
[ 0.000000] early_node_map[4] active PFN ranges
[ 0.000000] 0: 0x00000000 -> 0x00000002
[ 0.000000] 0: 0x00000006 -> 0x0000009f
[ 0.000000] 0: 0x00000100 -> 0x00017ef0
[ 0.000000] 0: 0x00017f00 -> 0x00018000
[ 0.000000] On node 0 totalpages: 98187
[ 0.000000] free_area_init_node: node 0, pgdat c07470e0, node_mem_map c1001000
[ 0.000000] DMA zone: 32 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 3963 pages, LIFO batch:0
[ 0.000000] Normal zone: 736 pages used for memmap
[ 0.000000] Normal zone: 93456 pages, LIFO batch:31
[ 0.000000] Using APIC driver default
[ 0.000000] ACPI: PM-Timer IO Port: 0x4008
[ 0.000000] SMP: Allowing 1 CPUs, 0 hotplug CPUs
[ 0.000000] Local APIC disabled by BIOS -- you can enable it with "lapic"
[ 0.000000] APIC: disable apic facility
[ 0.000000] nr_irqs_gsi: 16
[ 0.000000] Allocating PCI resources starting at 18000000 (gap: 18000000:e7fc0000)
[ 0.000000] NR_CPUS:8 nr_cpumask_bits:8 nr_cpu_ids:1 nr_node_ids:1
[ 0.000000] PERCPU: Embedded 24 pages/cpu @c1400000 s74936 r0 d23368 u4194304
[ 0.000000] pcpu-alloc: s74936 r0 d23368 u4194304 alloc=1*4194304
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 97419
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-2.6.32-122-rtai root=UUID=618415b9-fd01-4f0b-93af-cffdfc987b13 ro quiet splash
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Enabling fast FPU save and restore... done.
[ 0.000000] Enabling unmasked SIMD FPU exception support... done.
[ 0.000000] Initializing CPU#0
[ 0.000000] allocated 1966080 bytes of page_cgroup
[ 0.000000] please try 'cgroup_disable=memory' option if you don't want memory cgroups
[ 0.000000] Initializing HighMem for node 0 (00000000:00000000)
[ 0.000000] Memory: 366092k/393216k available (4539k kernel code, 26232k reserved, 1928k data, 620k init, 0k highmem)
[ 0.000000] virtual kernel memory layout:
[ 0.000000] fixmap : 0xfff1e000 - 0xfffff000 ( 900 kB)
[ 0.000000] pkmap : 0xff800000 - 0xffc00000 (4096 kB)
[ 0.000000] vmalloc : 0xd8800000 - 0xff7fe000 ( 623 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd8000000 ( 384 MB)
[ 0.000000] .init : 0xc0751000 - 0xc07ec000 ( 620 kB)
[ 0.000000] .data : 0xc056ecbc - 0xc0750e68 (1928 kB)
[ 0.000000] .text : 0xc0100000 - 0xc056ecbc (4539 kB)
[ 0.000000] Checking if this processor honours the WP bit even in supervisor mode...Ok.
[ 0.000000] SLUB: Genslabs=13, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] NR_IRQS:2304 nr_irqs:256
[ 0.000000] I-pipe 2.6-03: pipeline enabled.
[ 0.000000] Console: colour VGA+ 80x25
[ 0.000000] console [tty0] enabled
[ 0.000000] Fast TSC calibration using PIT
[ 0.000000] Detected 1199.702 MHz processor.
[ 0.004011] Calibrating delay loop (skipped), value calculated using timer frequency.. 2399.40 BogoMIPS (lpj=4798808)
[ 0.004056] Security Framework initialized
[ 0.004127] AppArmor: AppArmor initialized
[ 0.004147] Mount-cache hash table entries: 512
[ 0.004472] Initializing cgroup subsys ns
[ 0.004485] Initializing cgroup subsys cpuacct
[ 0.004495] Initializing cgroup subsys memory
[ 0.004520] Initializing cgroup subsys devices
[ 0.004527] Initializing cgroup subsys freezer
[ 0.004534] Initializing cgroup subsys net_cls
[ 0.004588] CPU: L1 I cache: 16K, L1 D cache: 16K
[ 0.004596] CPU: L2 cache: 256K
[ 0.004607] mce: CPU supports 5 MCE banks
[ 0.004644] Performance Events:
[ 0.004651] no APIC, boot with the "lapic" boot parameter to force-enable it.
[ 0.004656] no hardware sampling interrupt available.
[ 0.004662] p6 PMU driver.
[ 0.004696] ... version: 0
[ 0.004701] ... bit width: 32
[ 0.004705] ... generic registers: 2
[ 0.004710] ... value mask: 00000000ffffffff
[ 0.004716] ... max period: 000000007fffffff
[ 0.004721] ... fixed-purpose events: 0
[ 0.004726] ... event mask: 0000000000000003
[ 0.004740] Checking 'hlt' instruction... OK.
[ 0.021310] SMP alternatives: switching to UP code
[ 0.030029] Freeing SMP alternatives: 31k freed
[ 0.030069] ACPI: Core revision 20090903
[ 0.038859] ACPI: setting ELCR to 0200 (from 0020)
[ 0.040134] ftrace: converting mcount calls to 0f 1f 44 00 00
[ 0.040161] ftrace: allocating 21003 entries in 42 pages
[ 0.054129] Enabling APIC mode: Flat. Using 0 I/O APICs
[ 0.054144] weird, boot CPU (#0) not listed by the BIOS.
[ 0.054148] SMP motherboard not detected.
[ 0.054155] Local APIC not detected. Using dummy APIC emulation.
[ 0.054159] SMP disabled
[ 0.054719] Brought up 1 CPUs
[ 0.054738] Total of 1 processors activated (2399.40 BogoMIPS).
[ 0.055605] CPU0 attaching NULL sched-domain.
[ 0.056059] devtmpfs: initialized
[ 0.056901] regulator: core version 0.5
[ 0.057035] NET: Registered protocol family 16
[ 0.057332] EISA bus registered
[ 0.057355] ACPI: bus type pci registered
[ 0.057770] PCI: PCI BIOS revision 2.10 entry at 0xfd84e, last bus=1
[ 0.057777] PCI: Using configuration type 1 for base access
[ 0.059729] bio: create slab at 0
[ 0.060688] ACPI: EC: Look up EC in DSDT
[ 0.066788] ACPI: Interpreter enabled
[ 0.066797] ACPI: (supports S0 S5)
[ 0.066819] ACPI: Using PIC for interrupt routing
[ 0.075936] ACPI: Power Resource [PFAN] (on)
[ 0.076211] ACPI: No dock devices found.
[ 0.076514] ACPI: PCI Root Bridge [PCI0] (0000:00)
[ 0.076612] pci 0000:00:00.0: reg 10 32bit mmio pref: [0xe8000000-0xefffffff]
[ 0.076732] pci 0000:00:06.0: reg 10 32bit mmio: [0x000000-0x0000ff]
[ 0.076742] pci 0000:00:06.0: reg 14 io port: [0x00-0x07]
[ 0.076752] pci 0000:00:06.0: reg 18 io port: [0x00-0xff]
[ 0.076788] pci 0000:00:06.0: PME# supported from D3hot D3cold
[ 0.076796] pci 0000:00:06.0: PME# disabled
[ 0.076914] pci 0000:00:07.1: reg 20 io port: [0x1000-0x100f]
[ 0.076984] pci 0000:00:07.2: reg 20 io port: [0x1020-0x103f]
[ 0.077071] pci 0000:00:07.4: quirk: region 8100-810f claimed by vt82c686 SMB
[ 0.077118] pci 0000:00:07.5: reg 10 io port: [0x1400-0x14ff]
[ 0.077129] pci 0000:00:07.5: reg 14 io port: [0x1014-0x1017]
[ 0.077139] pci 0000:00:07.5: reg 18 io port: [0x1010-0x1013]
[ 0.077204] pci 0000:00:09.0: reg 10 io port: [0x00-0xff]
[ 0.077215] pci 0000:00:09.0: reg 14 32bit mmio: [0x000000-0x0003ff]
[ 0.077239] pci 0000:00:09.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.077258] pci 0000:00:09.0: supports D1 D2
[ 0.077264] pci 0000:00:09.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.077271] pci 0000:00:09.0: PME# disabled
[ 0.077308] pci 0000:00:0c.0: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.077328] pci 0000:00:0c.0: supports D1 D2
[ 0.077333] pci 0000:00:0c.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.077340] pci 0000:00:0c.0: PME# disabled
[ 0.077375] pci 0000:00:0c.1: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.077395] pci 0000:00:0c.1: supports D1 D2
[ 0.077400] pci 0000:00:0c.1: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.077408] pci 0000:00:0c.1: PME# disabled
[ 0.077449] pci 0000:00:0d.0: reg 10 32bit mmio: [0x000000-0x000fff]
[ 0.077489] pci 0000:00:0d.0: supports D1 D2
[ 0.077494] pci 0000:00:0d.0: PME# supported from D0 D1 D2 D3hot
[ 0.077501] pci 0000:00:0d.0: PME# disabled
[ 0.077565] pci 0000:01:00.0: reg 10 32bit mmio pref: [0xf0000000-0xf7ffffff]
[ 0.077576] pci 0000:01:00.0: reg 14 io port: [0x9000-0x90ff]
[ 0.077586] pci 0000:01:00.0: reg 18 32bit mmio: [0xe0000000-0xe000ffff]
[ 0.077606] pci 0000:01:00.0: reg 30 32bit mmio pref: [0x000000-0x01ffff]
[ 0.077628] pci 0000:01:00.0: supports D1 D2
[ 0.077669] pci 0000:00:01.0: bridge io port: [0x9000-0x9fff]
[ 0.077676] pci 0000:00:01.0: bridge 32bit mmio: [0xe0000000-0xe00fffff]
[ 0.077685] pci 0000:00:01.0: bridge 32bit mmio pref: [0xf0000000-0xf7ffffff]
[ 0.077728] pci_bus 0000:00: on NUMA node 0
[ 0.077738] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0._PRT]
[ 0.077906] ACPI: PCI Interrupt Routing Table [\_SB_.PCI0.PPB_._PRT]
[ 0.083332] ACPI: PCI Interrupt Link [LNKA] (IRQs *10)
[ 0.083568] ACPI: PCI Interrupt Link [LNKB] (IRQs *10)
[ 0.083790] ACPI: PCI Interrupt Link [LNKC] (IRQs *5)
[ 0.084016] ACPI: PCI Interrupt Link [LNKD] (IRQs 5) *0, disabled.
[ 0.084292] vgaarb: device added: PCI:0000:01:00.0,decodes=io+mem,owns=io+mem,locks=none
[ 0.084300] vgaarb: loaded
[ 0.084620] SCSI subsystem initialized
[ 0.084842] libata version 3.00 loaded.
[ 0.085050] usbcore: registered new interface driver usbfs
[ 0.085081] usbcore: registered new interface driver hub
[ 0.085157] usbcore: registered new device driver usb
[ 0.085500] ACPI: WMI: Mapper loaded
[ 0.085506] PCI: Using ACPI for IRQ routing
[ 0.085814] NetLabel: Initializing
[ 0.085819] NetLabel: domain hash size = 128
[ 0.085823] NetLabel: protocols = UNLABELED CIPSOv4
[ 0.085856] NetLabel: unlabeled traffic allowed by default
[ 0.085947] Switching to clocksource tsc
[ 0.089066] AppArmor: AppArmor Filesystem Enabled
[ 0.089127] pnp: PnP ACPI init
[ 0.089184] ACPI: bus type pnp registered
[ 0.091653] pnp 00:06: io resource (0x80-0x80) overlaps 0000:00:06.0 BAR 2 (0x0-0xff), disabling
[ 0.091674] pnp 00:06: io resource (0x80-0x80) overlaps 0000:00:09.0 BAR 0 (0x0-0xff), disabling
[ 0.096739] pnp: PnP ACPI: found 13 devices
[ 0.096746] ACPI: ACPI bus type pnp unregistered
[ 0.096755] PnPBIOS: Disabled by ACPI PNP
[ 0.096789] system 00:05: iomem range 0x0-0x9ffff could not be reserved
[ 0.096797] system 00:05: iomem range 0xe0000-0xfffff could not be reserved
[ 0.096815] system 00:06: ioport range 0x4d0-0x4d1 has been reserved
[ 0.096823] system 00:06: ioport range 0x8100-0x810f has been reserved
[ 0.131893] pci 0000:00:01.0: PCI bridge, secondary bus 0000:01
[ 0.131902] pci 0000:00:01.0: IO window: 0x9000-0x9fff
[ 0.131910] pci 0000:00:01.0: MEM window: 0xe0000000-0xe00fffff
[ 0.131918] pci 0000:00:01.0: PREFETCH window: 0xf0000000-0xf7ffffff
[ 0.131929] pci 0000:00:0c.0: CardBus bridge, secondary bus 0000:02
[ 0.131935] pci 0000:00:0c.0: IO window: 0x002000-0x0020ff
[ 0.131943] pci 0000:00:0c.0: IO window: 0x002400-0x0024ff
[ 0.131951] pci 0000:00:0c.0: PREFETCH window: 0x18000000-0x1bffffff
[ 0.131960] pci 0000:00:0c.0: MEM window: 0x1c000000-0x1fffffff
[ 0.131968] pci 0000:00:0c.1: CardBus bridge, secondary bus 0000:06
[ 0.131974] pci 0000:00:0c.1: IO window: 0x002800-0x0028ff
[ 0.131982] pci 0000:00:0c.1: IO window: 0x002c00-0x002cff
[ 0.131990] pci 0000:00:0c.1: PREFETCH window: 0x20000000-0x23ffffff
[ 0.131998] pci 0000:00:0c.1: MEM window: 0x24000000-0x27ffffff
[ 0.132023] pci 0000:00:01.0: setting latency timer to 64
[ 0.132124] pci 0000:00:0c.0: power state changed by ACPI to D0
[ 0.132527] ACPI: PCI Interrupt Link [LNKA] enabled at IRQ 10
[ 0.132535] PCI: setting IRQ 10 as level-triggered
[ 0.132545] pci 0000:00:0c.0: PCI INT A -> Link[LNKA] -> GSI 10 (level, low) -> IRQ 10
[ 0.132554] pci 0000:00:0c.0: setting latency timer to 64
[ 0.132606] pci 0000:00:0c.1: power state changed by ACPI to D0
[ 0.132962] ACPI: PCI Interrupt Link [LNKB] enabled at IRQ 10
[ 0.132970] pci 0000:00:0c.1: PCI INT B -> Link[LNKB] -> GSI 10 (level, low) -> IRQ 10
[ 0.132979] pci 0000:00:0c.1: setting latency timer to 64
[ 0.132991] pci_bus 0000:00: resource 0 io: [0x00-0xffff]
[ 0.132997] pci_bus 0000:00: resource 1 mem: [0x000000-0xffffffff]
[ 0.133004] pci_bus 0000:01: resource 0 io: [0x9000-0x9fff]
[ 0.133011] pci_bus 0000:01: resource 1 mem: [0xe0000000-0xe00fffff]
[ 0.133018] pci_bus 0000:01: resource 2 pref mem [0xf0000000-0xf7ffffff]
[ 0.133025] pci_bus 0000:02: resource 0 io: [0x2000-0x20ff]
[ 0.133032] pci_bus 0000:02: resource 1 io: [0x2400-0x24ff]
[ 0.133038] pci_bus 0000:02: resource 2 pref mem [0x18000000-0x1bffffff]
[ 0.133045] pci_bus 0000:02: resource 3 mem: [0x1c000000-0x1fffffff]
[ 0.133052] pci_bus 0000:06: resource 0 io: [0x2800-0x28ff]
[ 0.133058] pci_bus 0000:06: resource 1 io: [0x2c00-0x2cff]
[ 0.133064] pci_bus 0000:06: resource 2 pref mem [0x20000000-0x23ffffff]
[ 0.133071] pci_bus 0000:06: resource 3 mem: [0x24000000-0x27ffffff]
[ 0.133178] NET: Registered protocol family 2
[ 0.133410] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.134174] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.134589] TCP bind hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.135062] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.135070] TCP reno registered
[ 0.135434] NET: Registered protocol family 1
[ 0.135506] pci 0000:00:01.0: disabling DAC on VIA PCI bridge
[ 0.135519] pci 0000:00:07.0: Disabling VIA external APIC routing
[ 0.135572] pci 0000:01:00.0: Boot video device
[ 0.136084] Scanning for low memory corruption every 60 seconds
[ 0.136412] audit: initializing netlink socket (disabled)
[ 0.136451] type=2000 audit(1313753958.133:1): initialized
[ 0.151176] Trying to unpack rootfs image as initramfs...
[ 0.166476] HugeTLB registered 4 MB page size, pre-allocated 0 pages
[ 0.178112] VFS: Disk quotas dquot_6.5.2
[ 0.178379] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.180176] fuse init (API version 7.13)
[ 0.180443] msgmni has been set to 715
[ 0.186755] alg: No test for stdrng (krng)
[ 0.186986] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.186995] io scheduler noop registered
[ 0.187000] io scheduler anticipatory registered
[ 0.187005] io scheduler deadline registered
[ 0.187142] io scheduler cfq registered (default)
[ 0.187422] pci_hotplug: PCI Hot Plug PCI Core version: 0.5
[ 0.187491] pciehp: PCI Express Hot Plug Controller Driver version: 0.4
[ 0.187666] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0D:00/input/input0
[ 0.187995] ACPI: Lid Switch [LID]
[ 0.188102] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.188110] ACPI: Power Button [PWRB]
[ 0.188263] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input2
[ 0.188270] ACPI: Power Button [PWRF]
[ 0.191759] isapnp: Scanning for PnP cards...
[ 0.197815] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.198032] serial8250: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.198206] serial8250: ttyS1 at I/O 0x2f8 (irq = 3) is a 16550A
[ 0.198819] 00:08: ttyS0 at I/O 0x3f8 (irq = 4) is a 16550A
[ 0.201410] brd: module loaded
[ 0.250930] loop: module loaded
[ 0.251243] input: Macintosh mouse button emulation as /devices/virtual/input/input3
[ 0.252519] Fixed MDIO Bus: probed
[ 0.252610] PPP generic driver version 2.4.2
[ 0.252767] tun: Universal TUN/TAP device driver, 1.6
[ 0.252773] tun: (C) 1999-2004 Max Krasnyansky
[ 0.253006] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.253053] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.253096] uhci_hcd: USB Universal Host Controller Interface driver
[ 0.253732] ACPI: PCI Interrupt Link [LNKD] enabled at IRQ 5
[ 0.253741] PCI: setting IRQ 5 as level-triggered
[ 0.253752] uhci_hcd 0000:00:07.2: PCI INT D -> Link[LNKD] -> GSI 5 (level, low) -> IRQ 5
[ 0.253773] uhci_hcd 0000:00:07.2: UHCI Host Controller
[ 0.258506] uhci_hcd 0000:00:07.2: new USB bus registered, assigned bus number 1
[ 0.258582] uhci_hcd 0000:00:07.2: irq 5, io base 0x00001020
[ 0.259007] usb usb1: configuration #1 chosen from 1 choice
[ 0.259090] hub 1-0:1.0: USB hub found
[ 0.259118] hub 1-0:1.0: 2 ports detected
[ 0.259381] PNP: PS/2 Controller [PNP0303:PS2K,PNP0f13:PS2M] at 0x60,0x64 irq 1,12
[ 0.261209] i8042.c: Detected active multiplexing controller, rev 1.1.
[ 0.266468] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 0.266507] serio: i8042 AUX0 port at 0x60,0x64 irq 12
[ 0.266637] serio: i8042 AUX1 port at 0x60,0x64 irq 12
[ 0.266696] serio: i8042 AUX2 port at 0x60,0x64 irq 12
[ 0.266775] serio: i8042 AUX3 port at 0x60,0x64 irq 12
[ 0.267156] mice: PS/2 mouse device common for all mice
[ 0.267528] rtc_cmos 00:02: RTC can wake from S4
[ 0.267659] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[ 0.267701] rtc0: alarms up to one year, y3k, 242 bytes nvram
[ 0.267988] device-mapper: uevent: version 1.0.3
[ 0.268425] device-mapper: ioctl: 4.15.0-ioctl (2009-04-01) initialised: dm-devel@redhat.com
[ 0.270758] device-mapper: multipath: version 1.1.0 loaded
[ 0.270772] device-mapper: multipath round-robin: version 1.0.0 loaded
[ 0.274851] EISA: Probing bus 0 at eisa.0
[ 0.274870] Cannot allocate resource for EISA slot 1
[ 0.274877] Cannot allocate resource for EISA slot 2
[ 0.274888] Cannot allocate resource for EISA slot 4
[ 0.274913] EISA: Detected 0 cards.
[ 0.274921] cpuidle: using governor ladder
[ 0.274927] cpuidle: using governor menu
[ 0.276026] TCP cubic registered
[ 0.276520] NET: Registered protocol family 10
[ 0.277606] lo: Disabled Privacy Extensions
[ 0.278443] NET: Registered protocol family 17
[ 0.278544] Using IPI No-Shortcut mode
[ 0.278836] registered taskstats version 1
[ 0.279271] rtc_cmos 00:02: setting system clock to 2011-08-19 11:39:18 UTC (1313753958)
[ 0.279279] BIOS EDD facility v0.16 2004-Jun-25, 0 devices found
[ 0.279283] EDD information not available.
[ 0.297550] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input4
[ 0.617797] usb 1-2: new low speed USB device using uhci_hcd and address 2
[ 0.878201] isapnp: No Plug & Play device found
[ 0.891177] usb 1-2: configuration #1 chosen from 1 choice
[ 1.267565] Freeing initrd memory: 12824k freed
[ 1.306081] Freeing unused kernel memory: 620k freed
[ 1.307853] Write protecting the kernel text: 4540k
[ 1.307923] Write protecting the kernel read-only data: 1668k
[ 1.368792] udev: starting version 151
[ 1.832726] Floppy drive(s): fd0 is 1.44M
[ 1.851900] FDC 0 is a post-1991 82077
[ 1.868645] pata_via 0000:00:07.1: version 0.3.4
[ 1.880566] scsi0 : pata_via
[ 1.888843] scsi1 : pata_via
[ 1.889018] ata1: PATA max UDMA/100 cmd 0x1f0 ctl 0x3f6 bmdma 0x1000 irq 14
[ 1.889026] ata2: PATA max UDMA/100 cmd 0x170 ctl 0x376 bmdma 0x1008 irq 15
[ 1.943312] Linux agpgart interface v0.103
[ 1.969262] Linux Tulip driver version 1.1.15 (Feb 27, 2007)
[ 1.969368] tulip 0000:00:09.0: enabling device (0000 -> 0003)
[ 1.969386] tulip 0000:00:09.0: PCI INT A -> Link[LNKA] -> GSI 10 (level, low) -> IRQ 10
[ 1.969428] tulip 0000:00:09.0: setting latency timer to 64
[ 1.969732] tulip0: MII transceiver #1 config 3000 status 786d advertising 01e1.
[ 1.974448] eth0: ADMtek Comet rev 17 at Port 0x1c00, 00:90:96:1d:04:b7, IRQ 10.
[ 2.052496] ata1.00: ATA-6: TOSHIBA MK3025GAS, KA302B, max UDMA/100
[ 2.052508] ata1.00: 58605120 sectors, multi 16: LBA48
[ 2.052557] ata1.00: limited to UDMA/33 due to 40-wire cable
[ 2.060499] ata1.00: configured for UDMA/33
[ 2.060830] scsi 0:0:0:0: Direct-Access ATA TOSHIBA MK3025GA KA30 PQ: 0 ANSI: 5
[ 2.061247] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 2.062128] sd 0:0:0:0: [sda] 58605120 512-byte logical blocks: (30.0 GB/27.9 GiB)
[ 2.062266] sd 0:0:0:0: [sda] Write Protect is off
[ 2.062274] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[ 2.062343] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 2.062754] sda: sda1 sda2 < sda5 sda6 sda7 >
[ 2.183625] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.224456] ata2.00: ATAPI: TOSHIBA DVD-ROM SD-R2002, 1024, max MWDMA2
[ 2.240467] ata2.00: configured for MWDMA2
[ 2.242773] scsi 1:0:0:0: CD-ROM TOSHIBA DVD-ROM SD-R2002 1024 PQ: 0 ANSI: 5
[ 2.251140] sr0: scsi3-mmc drive: 24x/24x writer cd/rw xa/form2 cdda tray
[ 2.251153] Uniform CD-ROM driver Revision: 3.20
[ 2.251981] sr 1:0:0:0: Attached scsi CD-ROM sr0
[ 2.252474] sr 1:0:0:0: Attached scsi generic sg1 type 5
[ 2.270940] ohci1394 0000:00:0d.0: enabling device (0000 -> 0002)
[ 2.270965] ohci1394 0000:00:0d.0: PCI INT A -> Link[LNKA] -> GSI 10 (level, low) -> IRQ 10
[ 2.270978] ohci1394 0000:00:0d.0: setting latency timer to 64
[ 2.336542] ohci1394: fw-host0: OHCI-1394 1.0 (PCI): IRQ=[10] MMIO=[28022000-280227ff] Max Packet=[2048] IR/IT contexts=[8/8]
[ 2.346786] agpgart: Detected VIA Apollo Pro 133 chipset
[ 2.355568] agpgart-via 0000:00:00.0: AGP aperture is 128M @ 0xe8000000
[ 2.377820] [drm] Initialized drm 1.1.0 20060810
[ 2.408871] usbcore: registered new interface driver hiddev
[ 2.409678] usbcore: registered new interface driver usbhid
[ 2.410309] usbhid: v2.6:USB HID core driver
[ 2.470618] input: A4Tech USB Mouse as /devices/pci0000:00/0000:00:07.2/usb1/1-2/1-2:1.0/input/input5
[ 2.471567] a4tech 0003:09DA:000A.0001: input,hidraw0: USB HID v1.10 Mouse [A4Tech USB Mouse] on usb-0000:00:07.2-2/input0
[ 2.536718] [drm] radeon defaulting to kernel modesetting.
[ 2.536731] [drm] radeon kernel modesetting enabled.
[ 2.537351] ACPI: PCI Interrupt Link [LNKC] enabled at IRQ 5
[ 2.537363] radeon 0000:01:00.0: PCI INT A -> Link[LNKC] -> GSI 5 (level, low) -> IRQ 5
[ 2.551573] [drm] radeon: Initializing kernel modesetting.
[ 2.551774] [drm] register mmio base: 0xE0000000
[ 2.551779] [drm] register mmio size: 65536
[ 2.553720] [drm] GPU reset succeed (RBBM_STATUS=0x00000140)
[ 2.554035] agpgart-via 0000:00:00.0: AGP 2.0 bridge
[ 2.554067] agpgart-via 0000:00:00.0: putting AGP V2 device into 4x mode
[ 2.554134] radeon 0000:01:00.0: putting AGP V2 device into 4x mode
[ 2.554143] [drm] radeon: VRAM 64M
[ 2.554148] [drm] radeon: VRAM from 0x00000000 to 0x03FFFFFF
[ 2.554153] [drm] radeon: GTT 128M
[ 2.554158] [drm] radeon: GTT from 0xE8000000 to 0xEFFFFFFF
[ 2.554214] [drm] radeon: irq initialized.
[ 2.554491] [drm] Detected VRAM RAM=64M, BAR=128M
[ 2.554502] [drm] RAM width 64bits DDR
[ 2.554723] [TTM] Zone kernel: Available graphics memory: 189996 kiB.
[ 2.554770] [drm] radeon: 32M of VRAM memory ready
[ 2.554776] [drm] radeon: 128M of GTT memory ready.
[ 2.565292] [drm] radeon: cp idle (0x00008080)
[ 2.565402] [drm] Loading R100 Microcode
[ 2.566105] platform radeon_cp.0: firmware: requesting radeon/R100_cp.bin
[ 2.599631] [drm] radeon: ring at 0x00000000E8000000
[ 2.599662] [drm] ring test succeeded in 1 usecs
[ 2.621073] [drm] radeon: ib pool ready.
[ 2.621511] [drm] ib test succeeded in 0 usecs
[ 2.622866] [drm] DFP table revision: 2
[ 2.623422] [drm] Panel ID String: 1024x768
[ 2.623430] [drm] Panel Size 1024x768
[ 2.623674] [drm] Default TV standard: NTSC
[ 2.623680] [drm] 27.000000000 MHz TV ref clk
[ 2.623688] [drm] Default TV standard: NTSC
[ 2.623692] [drm] 27.000000000 MHz TV ref clk
[ 2.623862] [drm] Radeon Display Connectors
[ 2.623868] [drm] Connector 0:
[ 2.623873] [drm] VGA
[ 2.623879] [drm] DDC: 0x60 0x60 0x60 0x60 0x60 0x60 0x60 0x60
[ 2.623884] [drm] Encoders:
[ 2.623888] [drm] CRT1: INTERNAL_DAC1
[ 2.623892] [drm] Connector 1:
[ 2.623896] [drm] DVI-D
[ 2.623900] [drm] HPD1
[ 2.623906] [drm] DDC: 0x64 0x64 0x64 0x64 0x64 0x64 0x64 0x64
[ 2.623910] [drm] Encoders:
[ 2.623915] [drm] DFP1: INTERNAL_TMDS1
[ 2.623919] [drm] Connector 2:
[ 2.623923] [drm] LVDS
[ 2.623926] [drm] Encoders:
[ 2.623930] [drm] LCD1: INTERNAL_LVDS
[ 2.623934] [drm] Connector 3:
[ 2.623938] [drm] S-video
[ 2.623941] [drm] Encoders:
[ 2.623945] [drm] TV1: INTERNAL_DAC2
[ 2.718157] [drm] fb mappable at 0xF0040000
[ 2.718167] [drm] vram apper at 0xF0000000
[ 2.718171] [drm] size 786432
[ 2.718175] [drm] fb depth is 8
[ 2.718179] [drm] pitch is 1024
[ 2.721458] fb0: radeondrmfb frame buffer device
[ 2.721467] registered panic notifier
[ 2.721483] [drm] Initialized radeon 2.0.0 20080528 for 0000:01:00.0 on minor 0
[ 2.729533] vga16fb: initializing
[ 2.729553] vga16fb: mapped to 0xc00a0000
[ 2.729569] vga16fb: not registering due to another framebuffer present
[ 2.831693] Console: switching to colour frame buffer device 128x48
[ 3.624487] ieee1394: Host added: ID:BUS[0-00:1023] GUID[0040ca010508a754]
[ 3.792270] xor: automatically using best checksumming function: pIII_sse
[ 3.812028] pIII_sse : 2833.000 MB/sec
[ 3.812034] xor: using function: pIII_sse (2833.000 MB/sec)
[ 3.840703] device-mapper: dm-raid45: initialized v0.2594b
[ 4.000700] kjournald starting. Commit interval 5 seconds
[ 4.000739] EXT3-fs: mounted filesystem with ordered data mode.
[ 27.653830] Adding 618460k swap on /dev/sda6. Priority:-1 extents:1 across:618460k
[ 28.077026] EXT3 FS on sda7, internal journal
[ 28.173363] udev: starting version 151
[ 28.545334] lp: driver loaded but no devices found
[ 28.588623] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 28.732408] parport_pc: VIA 686A/8231 detected
[ 28.732417] parport_pc: probing current configuration
[ 28.732435] parport_pc: Current parallel port base: 0x378
[ 28.732481] parport0: PC-style at 0x378, irq 7 [PCSPP,TRISTATE,EPP]
[ 28.824923] lp0: using parport0 (interrupt-driven).
[ 28.824934] parport_pc: VIA parallel port: io=0x378, irq=7
[ 28.842544] via686a 0000:00:07.4: base address not set - upgrade BIOS or use force_addr=0xaddr
[ 29.461197] yenta_cardbus 0000:00:0c.0: CardBus bridge found [1509:1860]
[ 29.461227] yenta_cardbus 0000:00:0c.0: O2: res at 0x94/0xD4: e8/00
[ 29.461233] yenta_cardbus 0000:00:0c.0: Yenta O2: old bridge, disabling read prefetch/write burst
[ 29.588666] yenta_cardbus 0000:00:0c.0: ISA IRQ mask 0x0800, PCI irq 10
[ 29.588678] yenta_cardbus 0000:00:0c.0: Socket status: 30000810
[ 29.601110] yenta_cardbus 0000:00:0c.1: CardBus bridge found [1509:1860]
[ 29.675121] ppdev: user-space parallel port driver
[ 29.728616] yenta_cardbus 0000:00:0c.1: ISA IRQ mask 0x0800, PCI irq 10
[ 29.728628] yenta_cardbus 0000:00:0c.1: Socket status: 30000006
[ 29.859298] type=1505 audit(1313743188.076:2): operation="profile_load" pid=583 name="/sbin/dhclient3"
[ 29.871538] type=1505 audit(1313743188.088:3): operation="profile_load" pid=583 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 29.872222] type=1505 audit(1313743188.092:4): operation="profile_load" pid=583 name="/usr/lib/connman/scripts/dhclient-script"
[ 29.938441] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x100-0x3af: clean.
[ 29.940804] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x3e0-0x4ff: clean.
[ 29.941762] pcmcia_socket pcmcia_socket1: cs: IO port probe 0x820-0x8ff: clean.
[ 29.942584] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xc00-0xcf7: clean.
[ 29.943711] pcmcia_socket pcmcia_socket1: cs: IO port probe 0xa00-0xaff: clean.
[ 30.157479] Synaptics Touchpad, model: 1, fw: 5.6, id: 0x9244b1, caps: 0x80471b/0x0
[ 30.197645] input: SynPS/2 Synaptics TouchPad as /devices/platform/i8042/serio4/input/input6
[ 30.241534] pcmcia_socket pcmcia_socket0: pccard: PCMCIA card inserted into slot 0
[ 30.607882] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x100-0x3af: clean.
[ 30.631412] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x3e0-0x4ff: clean.
[ 30.648590] pcmcia_socket pcmcia_socket0: cs: IO port probe 0x820-0x8ff: clean.
[ 30.649419] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xc00-0xcf7: clean.
[ 30.650552] pcmcia_socket pcmcia_socket0: cs: IO port probe 0xa00-0xaff: clean.
[ 30.651489] pcmcia_socket pcmcia_socket0: cs: memory probe 0xa0000000-0xa0ffffff:
[ 30.802668] type=1505 audit(1313743189.020:5): operation="profile_load" pid=696 name="/usr/share/gdm/guest-session/Xsession"
[ 30.847566] type=1505 audit(1313743189.064:6): operation="profile_replace" pid=698 name="/sbin/dhclient3"
[ 30.874975] type=1505 audit(1313743189.092:7): operation="profile_replace" pid=698 name="/usr/lib/NetworkManager/nm-dhcp-client.action"
[ 30.875567] type=1505 audit(1313743189.092:8): operation="profile_replace" pid=698 name="/usr/lib/connman/scripts/dhclient-script"
[ 30.881451] clean.
[ 30.882465] pcmcia 0.0: pcmcia: registering new device pcmcia0.0
[ 31.071793] VIA 82xx Audio 0000:00:07.5: PCI INT C -> Link[LNKC] -> GSI 5 (level, low) -> IRQ 5
[ 31.071807] VIA 82xx Audio 0000:00:07.5: VIA VLink IRQ fixup, from 255 to 5
[ 31.154829] type=1505 audit(1313743189.372:9): operation="profile_load" pid=700 name="/usr/bin/evince"
[ 31.261057] type=1505 audit(1313743189.480:10): operation="profile_load" pid=700 name="/usr/bin/evince-previewer"
[ 31.300870] cfg80211: Calling CRDA to update world regulatory domain
[ 31.332478] type=1505 audit(1313743189.552:11): operation="profile_load" pid=700 name="/usr/bin/evince-thumbnailer"
[ 31.366444] cfg80211: World regulatory domain updated:
[ 31.366457] (start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
[ 31.366465] (2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 31.366472] (2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 31.366479] (2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
[ 31.366485] (5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 31.366492] (5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
[ 31.400942] orinoco 0.15 (David Gibson , Pavel Roskin , et al)
[ 31.424178] VIA 82xx Audio 0000:00:07.5: setting latency timer to 64
[ 31.429695] orinoco_cs 0.15 (David Gibson , Pavel Roskin , et al)
[ 32.031756] orinoco_cs 0.0: Failed to initialize firmware (err = -19)
[ 32.031764] orinoco_cs: orinoco_init() failed
[ 33.700527] orinoco_cs 0.0: Failed to initialize firmware (err = -19)
[ 33.700540] orinoco_cs: orinoco_init() failed
[ 34.133614] 0000:00:09.0: tulip_stop_rxtx() failed (CSR5 0xfc664010 CSR6 0xff972117)
[ 34.133633] eth0: Setting full-duplex based on MII#1 link partner capability of 45e1.
[ 41.832092] eth0: no IPv6 routers present
[ 611.556515] RTAI[hal]: ERROR, LOCAL APIC CONFIGURED BUT NOT AVAILABLE/ENABLED.
