Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 07-23-2011, 05:47 PM
IMSlo is on a distinguished road
Probe Problems
I tried to digitize a simple rc airplane body today. What should have taken 15 minutes took two hours.
I was running a diy probe. The procedure I use for digitizing is I jog to a point I want, probe it then jog to the next point. All I want is the x and y coordinates I am not usually interested in z.
Somewhere, maybe here, I got a digitizing program. It was an automatic program that would probe a grid.
I broke the program into three files. A program to open the probe file, a program to probe and a program to close the file. The procedure I use is open the file probe all the points I want then close the file.
Today I kept get a "probe tripped before G38 (of whatever the probe G code is) command executed" error. I finally got around the part after starting over many times and fiddling around with Z jogging. I even got my meter out and checked the the probe. It didn't look tripped but I thought it might have something in a contact that I couldn't see. The probe was not tripped.
My question: Is there a command that will save coordinates to a file without probing? I am always sitting on the point I want before I do the probe. If I could just save those points I wouldn't need the probe.
Old 07-24-2011, 03:07 AM
cncbasher is on a distinguished road
LinuxCNC.org - DIgitizing a part with no probe - EMC Support Forum
Old 07-24-2011, 06:23 AM
Thanks for the reply cncbasher.
Apparently there is a bug in the release I'm running. Maybe I can get an update before my next digitizing project. I only digitize occasionally.
Old 07-24-2011, 09:45 PM
I copied the code on the link supplied by cncbasher.
It works like a top.
All I need to do now is sharpen a 1/4" dowel, chuck it up in my router and start digitizing.
Thanks again for the reply.
Need Help!- if you had 300$ for a probe 7718 Digitizing and Laser Digitizing 1 03-02-2010 10:45 AM
Mach Probe plug in what is "maximum z height for stuck probe" option do? Rich05 Digitizing and Laser Digitizing 7 04-11-2009 12:05 PM
Super Probe 17 Functions in one probe thegimpster PIC Programing / Design 0 01-25-2008 12:46 PM
Marposs T25 probe problems 2alpha Milltronics 1 11-05-2007 07:50 AM
CMM probe sab Open Source Controller Boards 3 03-07-2006 04:37 AM
