| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hi All I am in the middle of doing an EMC retrofit of a Cincinnati Arrow 500 using a mesa 5i20, 7i33 combo. I am new to EMC2 and learning very fast but have come accross something I just cant figure out. Using the pncconf I calculated the output scale to be 40. To get to this I have 3000 rpm analogue servos with a 8mm pitch ballscrew and at full speed this gives 24,000mm/min rapid or 400mm/sec. The servo drive is +-10v analogue driven so therefore the output scale is 1v=40mm/sec. The problem is that when I test the axis it does not go anywhere near the speed it should and at rapid it only does 100mm/sec and not 400. Please can anyone help me on this or point me in the right direction. Thanks Flannman |
| check that infact 10v gives you full speed , you may well find the servo drive has been calibrated for a different voltage scale have you checked that you have 10v from the card and also at the input terminals of the servo drive , you could have losses in the cable , therfore reducing the voltage reaching the servo drive , adjusting the input of the servo drive to compensate to give you full speed , if thats the case . the easy way is to use one or 2 1.5v battery in series |
| Cncbasher Thanks for your reply. The servo drive is set to +-10v and using the open loop control when i put 1v into it the velocity is approximately 40mm/sec which is correct. Also when I set the output scale to 10 i can 9.6v from the card but when set to 40 i can only get 3.5v. Its baffling me. Flannmann |
| PCW_MESA I have been using the pid loop and configuring the ini file manually due to the limitations of pncconf. I can get very good motion with the output scale set to 10 and i have been doing some pid tuning. Its just when the output scale is set to 40 it is very slow. Flannman |
(that said there's no particular reason the output scale needs to be in machine units/sec (output scale of 10 for 10V FS makes sense also). The only advantage I see in setting the output scale to machine units/sec is that it would make the PID loop tuning parameters independent of machine units. |
| Newbie- How to get Encoder readings and change analog output using Mesa 5i20 + 7i33? | Shen Bingquan | LinuxCNC (formerly EMC2) | 10 | 10-03-2010 11:58 PM |
| Mesa PWM Output Mode | tig-tec | LinuxCNC (formerly EMC2) | 2 | 10-14-2009 03:43 PM |
| Mesa 7i33 and AMC amplifiers | Monroe Design | LinuxCNC (formerly EMC2) | 2 | 04-12-2009 10:09 AM |
| Anyone with Mesa 5I20 and 7I33 stories? | karl1 | LinuxCNC (formerly EMC2) | 15 | 12-13-2008 11:28 PM |
| Problem using EMC with MESA 5I20 + 7I33 + 7137 | hooeey | LinuxCNC (formerly EMC2) | 6 | 03-05-2008 03:39 PM |
