| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hi, I am new to Visual Mill and EMC so not sure if this problem is due to Visual Mill or EMC. I am using Visual Mill 6 and have created a cut path for a house sign that I designed in SolidWorks. I used horizontal roughing for my first cut with a 19mm end mill. My second Horizontal roughing tool path was programmed with a 13mm end mill. When I ran the program on EMC, the second tool path started cutting without prompting for a tool change and destroyed all the work that had been done with 19mm tool. By the way all my tool paths are in one MOp Set. Is this maybe the problem, should I be using a different MOp set for each tool? Please help, it's soul destroying after watching everything go fine for an hour only to see it get ruined. Thanks for any advice. Simon |
| Need more info. For instance does it usually prompt but this time it didn't or it never has? How did you build your config files? A small sample of the G code showing the tool change and a copy of your config files would help too. Chris |
| need help wana make macro for getting tool change by giving tool pot no on vmc instea | ghevari | Parametric Programing | 0 | 02-14-2010 12:26 PM |
| Need Help!- Green "Tool Reset" prompt, but we have no button to push for that, or a tool changer. | tomdbiggs | Milltronics | 8 | 02-01-2010 09:45 AM |
| DOS Prompt ? | Andre' B | OpenSource Software | 5 | 09-05-2008 07:26 AM |
| How to change Tool change position(About MAZATROL T1 control) | liushuixingyun | Mazak, Mitsubishi, Mazatrol | 5 | 07-07-2007 02:58 PM |
| fanuc tool change prompt light | cam | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 04-02-2004 08:27 AM |
