| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hello. I'm an electrical engineer with CAD and programming experience. I'm finishing a homemade 3-axis CNC machine with control by EMC2. Everything going well. I don't have a spindle yet so I've made a hot-wire foam cutter attachment. It's mounted on the Z-axis with the wire parallel to the Y-axis. I need some help in converting DXF to NGZ. Can members recommend -
Many thanks. |
| Cambam has a Free version and several good tutorials to get you started. His price was very reasonable for the full version. linux has gcam, pycam, and a gcode hack for blender. I have not enough patience to learn to use. |
| Also take a look at Heekscnc & Heekscad heekscnc - CNC machining add-in for HeeksCAD - Google Project Hosting orentation of the axis is in the configuration also a good program for foam cutting is http://gm.cnc.free.fr/en/index.html and Jedicut http://www.aeropassion.net/index-en.php |
| Foam cutter Kit | RedLabel | CNC Wire Foam Cutter Machines | 1 | 05-26-2012 04:59 PM |
| Info Required For Acrylic Cutter | Bread_O | Laser Engraving & Cutting Machines | 21 | 11-01-2011 06:39 AM |
| Hot Pin Foam Cutter | damae | CNC Wire Foam Cutter Machines | 3 | 01-24-2009 07:40 PM |
| Cutting bed is out of plane with the cutter | hualon | DIY-CNC Router Table Machines | 21 | 06-22-2008 11:28 AM |
| My first CNC! soon to be foam cutter | nikolatesla20 | CNC Wire Foam Cutter Machines | 8 | 08-06-2005 01:48 PM |
