Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 06-01-2011, 08:56 AM
Todd Zuercher is on a distinguished road
EMC2 with Teknics servo drives?
I am new to this.
I am trying to refit a CNC router after a lightning strike took out the old PC control.
The router is 3 axis using Teknic servos and drives. The drives are SST-1500-ALW.
My question is what hardware (cards etc.) would I need to connect a new PC to properly run this CNC with EMC2?
The old control was a PC runing Microsystems CNC Controler (a DOS program that is no longer supported) with an ISA card (ACL-7120 rev.B) connected to some sort of breakout board (unknown manufacturer). There are high and low limits for each axis, an enable/reset switch, emergency stop, and at least one relay for turning on and off vacuum.
The drives seem to be working, but after putting in a new pc with the old card and software, I am not getting any control, I think there is either a problem with the old card in the PC or the break out board.
The machines manufacturer hasn't been a lot of help because it is an older custom machine, and the only person who "might" know anything is on vacation.
Old 06-01-2011, 09:19 AM
PCW_MESA is on a distinguished road
Originally Posted by Todd Zuercher View Post
I am new to this.
I would search for the Teknic motor drive specs to determine what interface they use (Analog +-1OV, PWM, STEP/DIR etc), then the retrofit hardware requirements can be determined.
Other information that will help:
Do the motors have encoders?
Do you have a system wiring diagram?
Old 06-01-2011, 09:25 AM
The drives take Step/dir.
Yes, the servos have encoders.
No, I do not have any wiring diagrams.
Old 06-01-2011, 09:56 AM
The simplest EMC setup would be to use one or two parallel ports. A breakout board may or may not be required (a dual port PCI parallel card is cheap if you make a mistake but I would use a breakout board if you use a motherboard parallel port)
The limitations of a parallel port based system are limited I/O points and limited step rate, these may not be serious limitations depending on your resolution and speed requirements. If you need more I/O or higher speeds, then special hardware for EMC can be used. For hardware step generation (so no practical limitations on step rate) Both Mesa and Pico Systems make
cards.
Need Help!- Teknics RC-520-MC mill Allmine General Metal Working Machines 0 02-16-2011 08:31 AM
VSD-A + emc2 + pluto-servo Esa Hippolin Granite Devices 5 07-15-2010 04:58 PM
