| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
Hi Folks, I recently bought a new laptop on which I installed lucid with emc besides win 7, for testing purposes (so no actual milling) and it worked a treat. Today when I wanted to actually use it it would not start anymore, gave the message at the end of this post. Could it be that there is a conflict with other linux versions? I have also installed 10.10 and somehow a kernel between 10.04 and the latest 10.10 is showing in the boot options which also starts 10.10. (not sure if this can be but I am not that familiar with linux terminology) I also checked running the current live cd from usb, even there emc won't work! It may be that I had not tried 10.04 after installing 10.10 so I am unsure if this problem is actually new. Is there a fix that I can do? Going back to the old desktop is a big pain as it is unworkably slow.... Here is the error report: Code: Print file information: RUN_IN_PLACE=no EMC2_DIR= EMC2_BIN_DIR=/usr/bin EMC2_TCL_DIR=/usr/share/emc/tcl EMC2_SCRIPT_DIR= EMC2_RTLIB_DIR=/usr/realtime-2.6.32-122-rtai/modules/emc2 EMC2_CONFIG_DIR= EMC2_LANG_DIR=/usr/share/emc/tcl/msgs INIVAR=inivar HALCMD=halcmd EMC2_EMCSH=/usr/bin/wish8.5 EMC2 - 2.4.6 Machine configuration directory is '/home/sven/emc2/configs/Sherline3Axis-1' Machine configuration file is 'Sherline3Axis_mm.ini' INIFILE=/home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PARAMETER_FILE=stepper.var EMCMOT=motmod EMCIO=io TASK=milltask HALUI= DISPLAY=axis NML_FILE= Starting EMC2... Starting EMC2 server program: emcsvr Loading Real Time OS, RTAPI, and HAL_LIB modules Starting EMC2 IO program: io Starting EMC2 TASK program: milltask Starting EMC2 DISPLAY program: axis USRMOT: ERROR: command timeout USRMOT: ERROR: command timeout USRMOT: ERROR: command timeout USRMOT: ERROR: command timeout waiting for s.axes waiting for s.axes waiting for s.axes waiting for s.axes waiting for s.axes waiting for s.axes waiting for s.axes waiting for s.axes waiting for s.axes Shutting down and cleaning up EMC2... Killing task emcsvr, PID=3268 Killing task milltask, PID=3320 USRMOT: ERROR: command timeout USRMOT: ERROR: command timeout USRMOT: ERROR: command timeout Timeout, trying kill -9 Removing HAL_LIB, RTAPI, and Real Time OS modules Removing NML shared memory segments Cleanup done Debug file information: A configuration error is preventing emc2 from starting. More information may be available when running from a terminal. 3268 PID TTY STAT TIME COMMAND 3320 PID TTY STAT TIME COMMAND 3320 ? R 0:04 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:05 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:05 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:05 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:05 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:05 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:05 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:05 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:05 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:06 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:06 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:06 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:06 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:06 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:06 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:06 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:06 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:07 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND 3320 ? R 0:07 milltask -ini /home/sven/emc2/configs/Sherline3Axis-1/Sherline3Axis_mm.ini PID TTY STAT TIME COMMAND /usr/bin/emc: regel 358: 3320 Geëlimineerd $EMCTASK -ini "$INIFILE" Stopping realtime threads Unloading hal components Kernel message information: [ 510.837255] I-pipe: Domain RTAI registered. [ 510.837265] RTAI[hal]: <3.8.1> mounted over IPIPE-NOTHREADS 2.6-03. [ 510.837268] RTAI[hal]: compiled with gcc version 4.4.3 (Ubuntu 4.4.3-4ubuntu5) . [ 510.837342] RTAI[hal]: mounted (IPIPE-NOTHREADS, IMMEDIATE (INTERNAL IRQs DISPATCHED), ISOL_CPUS_MASK: 0). [ 510.837345] PIPELINE layers: [ 510.837350] faa6de20 9ac15d93 RTAI 200 [ 510.837353] c085cb20 0 Linux 100 [ 510.864945] RTAI[malloc]: global heap size = 2097152 bytes,
__________________ Sven http://www.puresven.com/?q=building-cnc-router Last edited by CaptainVee; 04-27-2011 at 06:43 AM. |
| Wow, if ever there was a quick result...! Looked up how to remove old kernels and now emc will start up again! During boot, look up what kernels you have installed. In my case linux-image-2.6.35.28 and linux-image-2.6.35.22 (or something similar, NOT SURE IF THIS IS FACTUAL) for 10.10 and then another kernel for 10.04. Using synaptic package manager, search for linux-image-2 and mark the oldes one('s) for removal, then apply. But be careful not to delete currently needed stuff!
__________________ Sven http://www.puresven.com/?q=building-cnc-router |
| Well, not as true as first thought. After initial sucsess this stuff has returned and it is driving me mad! Anyone able to shed some light on to this? I triple boot my system, win 7, ubuntu 10.04 with emc and 10.10
| Well, finally got a workable solution. I discovered that there is a simulator version of emc. After installing that on my 10.04 partition I thought to give it a try on my main partition (10.10) And that works! You need to load specific sim configurations to be able to start emc and if I do not I get the same kind of errors I got on my 10.04 partition. The specific sim configurations can be altered to reflect your machine's setup.
| The original problem was probably because of an update to a new kernel version. This pushed the old kernel down the list and loads the newest. A real time version of EMC requires a realtime kernel. The realtime kernel has RTAI mentioned in it. By deleting kernels from the list, you probably got the RTAI version back in the default loaded position. when you boot up the realtime version of EMC choose that ( RTAI) kernel from the list. |
| I did keep the rtai kernel, it was updated but to another rtai. But that still kept the problem of EMC not starting everytime. Edit: Oh, you mean that it might have still worked if I had not updated....
__________________ Sven http://www.puresven.com/?q=building-cnc-router Last edited by CaptainVee; 07-09-2011 at 01:14 AM. |
| updating the kernel from any update will not work and makes emc unusable , this is the reason updates to or from an older version should be turned off , and rarely suceed , the problem you have is because of a multiboot linux system , any updating of one linux version has the ability of changing the other linux version librarys and shared files and especialy the kernal and RTAI libs , especialy if sharing the same harddrive . |
| Ubuntu 10,04 LTS (from Ubuntu) Ubuntu 8.04 LTS (from linuxcnc) Ubuntu 6.06 LTS (from linuxcnc) BDI something or other with emc (predates the emc Ubuntu releases ?) The result of pack rat habits and a reluctance to reinstall certain software. If 10.04 is updated to 12.04 via update manager down the road the older installs could be affected ? I've never considered the possibility. Thanks for the heads up. If users download the image from linuxcnc.org and resist the eventual update manager offer of 12.04(?) things should go smoothly. neilw20 If you're happy with Mach I'm happy for you.
__________________ Anyone who says "It only goes together one way" has no imagination. |
#10
| You may allow updates. As long as you don't change major versions. don't allow 10.04 to update to 10.10. What I am saying is that linux loads up a kernel by position in a file. If an update adds a new kernel the position changes and then the rtai kernel is not loaded (and EMC needs it) There are a few things you can do: - edit your file so it loads from the new position - u'll have to do this each time there is a new kernel. - make the boot process wait till u choose a kernel from a list - make the boot process display the list for a few seconds (for u to choose) then load a default kernel. - never allow any Kernel updates Choosing Mach3 is fine till you find it has other problems or doesn't do what you want. If you are saying you use Mach cause it allows updates and EMC doesn't - thats not rrue. |
#12
Regardless of Mach3 or EMC2, whatever OS, if you have something that works you need to read the upgrade notes first to see if it has anything you need. Upgrading just for the sake of it can cause problems. If it isn't broke why fix it? Upgrades have some purposes. 1. Original system did not work correctly. Did the upgrade address the problem? 2. To fix bugs/deficiencies. 3. To add/remove features. 4. To make things work with later OS releases. (why did you upgrade?) 5. Old hardware obsolete. $$$ 6. To make new hardware work. $$$ 7. To make old software obsolete. --$$$ Solidworks is a perfect example. and the list goes on.... Ticked none of the above? Why change it? I am not a one eyed Mach/EMC/Windows/MAC supporter. Choose the platform that provides the best solution for the application. I still use Win98 (Vesa graphics) on Win7 using DOSBox with NO SOFTWARE CHANGES to stuff that has worked flawlessly for 10-15 years. I ticked boxes 4-6. Multiple monitors is like having multiple computers. What a bonus!
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| Earth Sheltered or Earth Bermed homes | Edwardo | Environmental & Alternate Energy | 8 | 05-06-2012 04:54 AM |
| Earth grounding question | plain ol Bill | CNC Plasma and Waterjet Machines | 6 | 08-20-2008 02:41 PM |
| Earth Ground | LYN BYRD | Milltronics | 5 | 06-20-2007 11:39 AM |
| How on earth do I make this!!! | disinformation | G-Code Programing | 14 | 10-11-2006 07:53 AM |
| Google Earth ( You'll love it) | ynneb | CNCzone Club House | 28 | 08-05-2005 01:13 PM |
