Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 04-13-2011, 07:11 AM
Makeek is on a distinguished road
Realtime system did not load
I downloaded ubuntu emc from LinuxCNC.org - Installing EMC2
Installs fine but when I'm trying to start emc I get error which is attached. What to do?
Old 04-13-2011, 09:48 AM
wendtmk's Avatar
Moderator
wendtmk is on a distinguished road
Check this link for troubleshooting that problem:
EMC Documentation Wiki: TroubleShooting
It's more than likely problem 2 based on your error messages.
Mark
Old 04-13-2011, 02:33 PM
Thanks. I would try but gedit says that file is read only and I cannot edit it. I don't know about linux nothing so could somebody give me detailed instructions how to run ubuntu always that I can do whatever I want and I can edit files.
Old 04-13-2011, 07:06 PM
Heinz Reimer is on a distinguished road
Open a terminal window and type:
sudo gedit
You will be prompted for your password, following which gedit will open with root priviledges.
Old 04-14-2011, 02:04 AM
cncbasher is on a distinguished road
are you installing under a virtual os ?
within windows or mac etc
Old 04-14-2011, 04:32 AM
wendtmk's Avatar
Moderator
or if you want the file to open in the geditor, just type sudo gedit /etc/default/grub
Mark
Realtime timeout! matthew6060 Cincinnati CNC 4 02-22-2009 11:33 AM
Realtime in EMC Kailo LinuxCNC (formerly EMC2) 2 01-23-2009 03:51 PM
Newbie- Load testing steppers on a Sherline system? David Campbell Gecko Drives 17 01-08-2009 07:40 PM
Realtime implementation in EMC ChandlerBing LinuxCNC (formerly EMC2) 4 02-28-2008 03:26 PM
Fanuc 16M system software load ROM Parity Error ljmapet01 Fanuc 2 06-07-2007 11:42 PM
