Results 1 to 12 of 12
Thread: help with Y axis not working at slow rates
    Mar 2008
    I have a gekko G540 with EMC2 setup. I'm running dual X axis on a XYZ setup, with pins for the second X axis mapped to X and direction inverted.
    The problem I have is that the Y axis will not move at slow rates. It does fine jogging at higher rates, but if I put the velocity at 0.1 in/min, it doesn't move in stepconf. It also doesn't move most of the time when running through G code.
    Any ideas? I've already tried increasing jitter
    Nov 2005
    Just a shot in the dark - i would check electrical noise or whether the parport has enough power to run all the axis. Is there a break-out board between the g540 and computer?
    Is it a mobo parport or a PCI add on parport?
    Nov 2005
    If you disconnect the two x axis will Y work properly?
    Mar 2008
    It's a motherboard parallel port. I will disconnect X and see if Y works.
    I thought it might be a noise problem as well, and moved the Gekko box around. All the cables between the G540 and the steppers are shielded (I believe) - purchased from cncrouterparts.com (9 pin connectors).
    Mar 2008
    disconnecting the 2 X motors makes no difference.
    Y won't move on the stepconf test at .1 in/sec... it works fine at .6 in/sec or higher.
    Nov 2005
    next to try :
    can you easily physically rewire the parport to move the Y axis to another set of pins?
    or may be you can switch the pins in software for y and z to see if z is screwed up.
    What we are trying to do is figure out if its hardware or software and exactly what part of the hardware.
    Has this ever worked correctly?
    Mar 2008
    Quote Originally Posted by chester88 View Post
    next to try :
    Hi, followed your recommendation by swapping Y and Z, and changing the pin mapping in stepconf. Everything seems to work now, which is great, but now I wonder what the problem could be.
    And, this is a new machine - just finished assembly yesterday.
    Nov 2005
    glad you got it fixed.
    Sometimes that happens you take it apart find nothing wrong put it back together and it works!
    annoying but as long as it works.
    Probably a bad connection did it.
    Chris
    Mar 2008
    Thanks for your help.
    I guess tonight I'll hook it up the "right" way and see if the problem returns - if so, I'll just leave Y and Z swapped and leave it alone.
    Mar 2008
    well, I guess I lied... tried a different gcode file with more Z axis movement and today Z wouldn't move with slow rate (Z used to be Y) Switched things around, and problem moved to Y again.
    This only happens at very slow jog speeds.
    Any idea why?
    Nov 2005
    sounds like a hardware problem. Do you have a PCI add on parport you can try or another computer? Is the parport wired directly to the g540?
    Mar 2008
    I can try it, but I think I may have fried something on the G540.
    I noticed Y does work when the unit is first plugged in (Even when moving slow)
    Tried adjusting the trim on the Y - motion got choppy and G540 went into fault. Have not been able to prevent it from doing that since, no matter what I do with the trim pot. As soon as I plug in Y, it goes into fault.
    X,Z and A still seem to work fine. Contacting Gecko
    1. 4th Axis very slow
      By irv in forum Syil Products
      Last Post: 12-14-2009, 01:30 PM
    2. Need Help!- G540 x-axis slow jog stops working after a minute
      By Waldermac in forum Benchtop Machines
      Last Post: 07-12-2009, 12:50 AM
    3. general confusion about z axis movement rates
      By groomden in forum Mach Software (ArtSoft software)
      Last Post: 04-30-2009, 09:06 PM
    4. Need Help!- Slow working STL
      By koz in forum Visual Mill
      Last Post: 02-26-2009, 12:32 PM
    5. Need help working on FEED rates!!
      By LiamRatedRKO in forum General Metalwork Discussion
      Last Post: 02-23-2009, 05:46 PM
