Results 1 to 8 of 8
Thread: gtksourceview-2.0 (gedit) gcode syntax coloring.
    Jun 2005
    norway
    I was not able to find a syntax coloring definition for gcode in gtksourceview (gedit) so I made one.
    It helps me when I´m reading through my gcode so I thought It might help others if I shared it..
    it´s far from perfect, but it´s a start
    http://dl.dropbox.com/u/22370817/ngc.lang
    drop it in either .gnome2/gtksourceview-2.0/language-specs/ or /usr/share/gtksourceview-2.0/language-specs/
    Henrik
    Attached Files Attached Files
    Last edited by henrikw; 03-02-2011 at 05:20 PM. Reason: Added lang file to original post in case the dropbox file goes down.
    Dec 2009
    Cool that I'll have to give a shot.
    CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
    May 2005
    canada
    This adds a menu item but doesn't seem to do anything else
    Did you upload the wrong file or is it a work in progress ? Maybe it's something I'm doing wrong ?
    Anyone who says "It only goes together one way" has no imagination.
    Jun 2005
    norway
    Hmm.. no, it is the same file I´m using.
    What file suffix do use? the files supported now is "*.ngc;*.nc;*.cnc;*.tap", but it is very easy to add more.
    Henrik
    May 2005
    canada
    There are a couple of others available.
    one from the linuxcnc wiki
    EMC Documentation Wiki: Highlighting In Gedit
    and another from the inkscape gcode developer (Gcode tools)
    cnc-club.ru •
    They look rather easy to customize with a bit of knowledge of regular expressions. I'd like to see one that has separate colors for letters X,Y and Z as seen in some other gcode editors.
    Jun 2005
    norway
    wow, and I thought I did a thorough search for this before I made my lang file they both look way better than mine.
    This should really be a part of the ubuntu-distro available at linuxcnc.org
    H.
    May 2005
    canada
    Quote Originally Posted by cyclestart View Post
    That was easier than I thought
    Attached Thumbnails Attached Thumbnails gtksourceview-2.0 (gedit) gcode syntax coloring.-gedit_gcode.png
    Jun 2005
    norway
    Yep, simple and helpful nice! too bad it's hidden away like that.
    I'm working on a script to make it easier to install such "features" on a vanilla emc2 ubuntu.
    Any tips on features that will be helpful? what are the first thing you do after a fresh install?
    Henrik
    1. Coloring Gold or Platinum
      By tung in forum Metal Finishing and Plating
      Last Post: 03-07-2010, 06:18 PM
    2. Coloring brass
      By ErnieD in forum Metal Finishing and Plating
      Last Post: 02-14-2010, 10:41 AM
    3. Need Help!- Using Gedit without EMC2 to manually edit Gcode with syntax
      By mouratoglou in forum LinuxCNC (formerly EMC2)
      Last Post: 07-25-2009, 03:36 AM
    4. painting & coloring via cnc?
      By vaneeck1 in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 03-25-2006, 01:33 PM
    5. Syntax question
      By doug6949 in forum Mastercam
      Last Post: 12-13-2004, 02:14 PM
