| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
sooo...my current computer has a latency rate of 275,000, which emc does not like. Is there any way to improve my latency or do i need to resign myself to getting another computer? In that case, any suggestions? I don't even really know specifically what latency is, so i don't know what i'd be looking for in a new computer. |
Have you tried disabling hyperthreading in the BIOS if it's turned on? Here's a page on the EMC2 wiki site that goes into some things you can do to try and get that latency number down: EMC Documentation Wiki: TroubleShooting Mark |
| Hi, I have just upgraded my desktop PC, and I have used my old motherboard to upgrade my EMC2 control, but I also tested both new and old systems for latency, I was planning on the ASROCK board as a potential for my next control system. ----------------------------- AMD 4000+ ATI Radeon Video AGP MSI Neo4 Motherboard StarTech IDE Compact Flash Adapter + 8GB Compact Flash Max latency 8500nS ( Average 4000nS ) ------------------------------ AMD 2100 64X2 Dual Core ( This is my new desktop PC ) ATI Radeon PCI Express ASROCK N68C-S ( has 2 pci slots + it's cheap ) StarTech IDE Compact Flash Adapter + 8GB Compact Flash Max latency 7000nS ( Average 3500nS ------------------------------- I have run both setups extensively, I don't use the network on the EMC setup as I use USB memory sticks to transfer GCode to the machine.
__________________ David ( never stop learning ) http://www.steamcastings.co.uk/ |
What controller are you using with these two PC setups. I've recentlyjust lost my older PC to a basement flood, and now am searching for something with a parallel port, to run a G540. Did you install an additional card or are you using a USB controller? thanks |
| Hi Rk, I use £10 PCI parallel port cards, that way if I kill one I can replace it easily, the last set I bought were 'Sweex PU005V2' they use a Moschip MCS9865 chipset and work fine with EMC2 and Ubuntu. My config uses 2 ports one for motor step direction spindle and estop, the second port is used for home and limit switches, but leaves plenty for the tool changer that I am working on. If you use add in PIC cards then you will have to find the address that the card uses but this is detailed in the emc documentation.
| What to do to get latency figures down? | CaptainVee | LinuxCNC (formerly EMC2) | 4 | 07-11-2010 12:51 PM |
| EMC2 from Mach3 issues | bevins | LinuxCNC (formerly EMC2) | 6 | 02-13-2010 01:06 AM |
| Need Help!- Determining Latency...Which #? | margni74 | LinuxCNC (formerly EMC2) | 4 | 11-25-2009 04:55 PM |
| Improving my latency figures | greybeard | LinuxCNC (formerly EMC2) | 5 | 07-23-2009 02:30 PM |
| EMC2 latency from Network card | randyf1965 | LinuxCNC (formerly EMC2) | 1 | 03-22-2008 10:08 PM |
