Results 1 to 10 of 10
Thread: My lithophane with EMC2 image to gcode
    Apr 2010
    p.r.china
    Hi
    I am using EMC2 image to gcode to produce my first lithophane like the following
    Every thing works fine with my Chinese made machine.
    K.T.Chan
    Feb 2008
    united states
    what material are you using?
    Apr 2010
    p.r.china
    material for lithophine
    I got the 100x100x5mm corian (dupont) form their sale person. good for cutting.
    I did tried with plastic cutting broad for kitchen.(cheap)
    white arcalic also can do but the transparency (that is the white part of the picture) is not as good.
    May 2011
    Nigeria
    Emc settings for the lithophane
    Hi
    Could you tell me the settings u used on the image to gcode in emc2?? i have tried twice and all it does is to draw lines. Do i have to convert the image to bump maps first before feeding it to emc2?? what type of cutting tool did you use v or ball nose or flat nose?? I appreciate your reply thanks.
    Apr 2010
    p.r.china
    emc2 image to gcode setup
    Hi Stikyke
    The setup for image to gcode is as following:
    invert image yes
    normalize yes
    extend image border none
    tolerance .01 (the machine limit)
    pixel size .25 ( the size of engrave in mm / pixels total ) most important cause most error
    feedrate 2000
    plunge feed rate 2000
    spindle speed 2000
    scan pattern rows
    scan direction alternating
    depth 4 mm ( the engrave depth)
    step over 2
    tool dia 1mm
    safety height 0
    tool type flat end
    roughing offset 1
    roughing depth per pass 2
    Hope that helps
    post if it works.
    Regards
    May 2011
    Nigeria
    Not much activity on z axis
    Hello ktchk,
    I tried your settings, it took me long to reply cause i had small issues i needed to sort in the machine. Its home built, and i cant find parts readily here am in Nigeria.
    When i tried using ur setting i got same result it only cuts in xy on same depth. the z axis remains stationary most of the time. As you can see from those white material i had there in the pic.
    Do you know what could be causing it?? i dont know why the Z axis doesnt move most of the time it cuts.
    thanks
    Iyke
    May 2011
    Nigeria
    pic
    Sorry here is the pic of the machine and the sheet it cut
    Apr 2010
    p.r.china
    Hi
    The Z movement depended on the image black and white and the setting of "normalize" set to yes, "depth" set to thickness of material minus 1mm, zero or home of z axis set to surface of material. Chick up and test again.
    May 2011
    Nigeria
    Angry
    Hi Ktchk,
    i inspected the Gcode and i think its working, so i have to zero at about 1.5mm above the work. I did cut a 3d on wood and it was almost through but my tool burnt i have to get a means of evacuating the dust/chips maybe a vacuum or blower. I feel the machine is ok now i will cut more tomorrow but not so deep to avoid burning the tool again.
    Apr 2010
    p.r.china
    If you need, the "roughing" can let you cut in layers 1mm in one layer the "roughing offset" can set the layer does not touch the high points until the last layer.
    EMC2 can also set the tool movement speed to slow down until tips can handle the cut.
    1. Image (Greyscale) to GCODE
      By rackbox in forum OpenSource Software
      Last Post: 02-13-2013, 06:55 AM
    2. Image to Gcode info.
      By kasari in forum General CAM Discussion
      Last Post: 06-06-2010, 10:45 AM
    3. Image to mach3 gcode
      By Woodenspoke in forum Mach Software (ArtSoft software)
      Last Post: 03-20-2010, 01:13 PM
    4. EMC2 & Image to G-Code
      By Bob La Londe in forum Engraving Machines
      Last Post: 12-14-2008, 11:22 PM
    5. Image to Vector And or GCode
      By whoafat in forum General CAM Discussion
      Last Post: 01-28-2008, 10:44 PM
