Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 12-02-2010, 09:43 PM
bikedude987 is on a distinguished road
motors lock but nothing moves!
I'm in the process of setting up my mill. I'm using EMC2 and Keling 4030 drivers with a C10 BOB. I have the axes wired up exactly according to their website, but haven't wired in things like the limit switches or estop yet. During configuration, I can plug in the power supplies, and the motors will lock, but when I go to test them, they will not move. They seem to make a kind of random clicking when I try to jog or run them, but will not move.
What could be wrong?!
Old 12-02-2010, 09:54 PM
ninefinger's Avatar
ninefinger is on a distinguished road
sounds like the dir and step pins are reversed - try changing them in step config and see if that makes a difference.
Mike
Old 12-03-2010, 11:09 AM
i changed them but then tho motors wouldn't even lock. what type of parallel port do i need to use in the bios? EPP? ECC?
Old 12-03-2010, 12:10 PM
figured it out.
had to check the 'invert' checkbox to get anything to output. all the axes work now.
can anyone explain why i had to do this?
Old 12-04-2010, 11:04 AM
photomankc is on a distinguished road
Sounds like the driver was set to active low so it expected the pulses to be drops from high to low for step/dir instead of what people generally think of, low to high.
CNC: Making incorrect parts and breaking stuff, faster and with greater precision.
Need Help!- Spindle lock Larry Myers Sharp CNC 1 06-15-2010 10:04 PM
Cam Lock Vices 2_many_hobbies Benchtop Machines 5 05-14-2010 08:37 AM
Step motors moves 1 step only alecu7 Hobbycnc (Products) 1 10-16-2008 12:18 PM
CNC lock-outs thetrillionaire General Metal Working Machines 1 06-11-2008 02:12 PM
Spindle Lock for SX3 Old Megawatts Syil Products 1 05-01-2007 05:19 PM
