Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 11-29-2010, 07:28 PM
ninefinger's Avatar
ninefinger is on a distinguished road
MODBUS control of VFD
I'm trying to get control of my GE -Fuji Electric VFD model AF300-E11. It will talk (and listen to) MODBUS so I figured I'd give it a shot at using the MODBUS in EMC2 to control it (versus a 0-10V analog output card and fwd/rev relay)
1st - has anybody done this for this series of VFD?
2nd - rather than starting from scratch I'm going to "try" and work from prior examples such as:
gs2_vfd
OR
does somebody have a classic ladder clp file they can share for any MODBUS control that I can look at as an example - I've looked but not found one?
3rd - this will be strictly an EMC2 effort as I have checked out communications so I know that works...(unlike some cheap VFD's I've been reading about on other threads)
Unfortunately my programming skills are rather weak - though I do know a bit about MODBUS as I've had to fight through it for work purposes.
I'll use this thread to publish any positive results I get for the benefit of others with this series of drive (got mine from here Variable Frequency Drive, AC Motor Drives, Pool Pump Motors, Marathon Electric 3 Phase Motor, Teco Westinghouse Distributor
BTW my initial objective is to have the following controls:
Spindle stop, on-fwd or on-rev, spindle speed,
and to read the following:
Spindle speed
(pretty basic list...)
Mike
Old 11-29-2010, 07:45 PM
chester88 is on a distinguished road
I assume you are using serial modbus?
here is the basic idea:
EMC Documentation Wiki: ClassicLadder Ver 7.124
What version of EMC are you using?
Its been a while since I used modbus with CL but some are using it.
Running EMC / CL in a terminal will give much more info while debugging modbus
Chris M
Old 11-29-2010, 08:27 PM
ninefinger's Avatar
Thanks Chris,
Yes to be clear I'm using the Serial Modbus (RTU).
EMC2 is up to date (v 2.4.5 on Ubuntu 10.04)
****EDIT - udpate manager was running - its now 2.4.6 if that makes any difference) - ***
I've had a look at the wiki - unfortunately I'm such a newbie at this it isn't much help - I really need a "worked" example to play with and break to get the hang of it (classic ladder that is) ie somebody has made the connections in classic ladder to their VFD via Modbus.. From there I can usually find my way to rework it for my application (ie my vfd's function codes, registers etc)
The other option is to hack somebody else's work such as the gs2_vfd.c that is referenced in the manual. Looks like that is the way I may end up going (though I still would like to learn the classic ladder interface)
Cheers,
Mike
Old 11-29-2010, 08:32 PM
modbus configs are so specialized for each vfd.
I will look to see if I can find my modbus example for a yaskawa vfd.
do you have pdf docs for your vfd?
CL does take a bit to get used to.
Old 11-29-2010, 08:41 PM
ninefinger's Avatar
I do have the pdf for the drive, but not on this machine ( it did take a whole bunch of searching to find it so I hope its still on my other machine). I'll post it here when I go upstairs.
If you do have an example I would really appreciate it - I'm a bit slow on the programming stuff but I usually get from point a to point b eventually...
Thanks,
Mike
Old 11-29-2010, 09:54 PM
ninefinger's Avatar
pdf of the manual is in a zip over here...
I don't have the manual on my machine but thank goodness I posted it to the zone for safe keeping! (albeit in a place that wasn't where I thought it would be...)
http://www.cnczone.com/forums/732560-post11.html
Mike
Old 12-01-2010, 07:28 PM
It's not clear to me from docs if 8n1 (8 bit data,no parity,1 stop bit ) serial signals are supported.
currently CL only supports this.
Have you connected to this inverter with modbus before?
Can you check the settings of :
H31 slave number
H34 baud rate
H35 data bits
H36 parity
H37 stop bits.
Boy are the docs written poorly for modbus!
Old 12-01-2010, 10:00 PM
ninefinger's Avatar
H31 slave number
H34 baud rate
H35 data bits
H36 parity
H37 stop bits.
Hi Chris,
Boy, I wasn't expecting you to wade through that manual - been there done that! I did connect up briefly with my laptop and a terminal program. I sent the example of an invalid message and got the proper error response message so I left it at that. (page 12-9 of the users guide..) I do have a GE program for configuring the drive via the RS485 so I can use that to prove the communications - but its on my laptop at work (the laptop is a windows machine)
I just tried a terminal program (moserial) on the linux machine - and I get the same as before:
send: 01 03 03 31 00 14 14 4E (request 20 bytes of data)
receive: 01 83 02 C0 F1 (error response)
Here are the configuration data as it stands now -
H31 = 1 = slave 1
H34 = 1 = 9600 baud
H35 = 0 = 8 data bits
H36 = 0 = no parity
H37 = 0 = 2 stop bits
8n1 is supported I believe - I will test it now by reconfiguring the drive.
If you have your yaskawa VFD example please post it so I can have a look - it might be the piece that lets my brain put together all the pieces
Thanks for your help with this!
Mike
Old 12-01-2010, 10:11 PM
ninefinger's Avatar
8 N 1 not supported..
Chris
Turns out you can't set 8n1 - the drive automatically sets the stop bits depending on the parity - no parity is 2 stop bits, even or odd parity is 1 stop bit.
Does this mean the whole idea of using Classic Ladder is dead in the water?
If so I'll try the other method - hacking up the gs2_vfd.c file I copied from somewhere...
Mike
Old 12-01-2010, 10:32 PM
I check the source code and it is possible to set different values for data, stop bit, and parity. It just hasn't been tested or documented.
i haven't found my USB drive with the modbus ladder tests on it yet.
I may just build a little one to suit testing for you to try.
next thing you need to find out is Linux's serial port address. Are you using a serial port or a usb serial converter?
Where in Canada are you?
Chris M
  #11   Ban this user!
Old 12-02-2010, 10:33 AM
ninefinger's Avatar
The serial port is /dev/ttyS0
It works throught the moserial program I downloaded moserial - GNOME Live!
I just haven't tried to actually control it yet as that requires figuring out the CRC to go with the command sent - I'll bring my laptop home tonight as it has my little tool for doing the Modbus stuff (crc calculator) as well as a GE program for configuring the drive via the RS485.
BTW I'm in Ottawa
  #12   Ban this user!
Old 12-04-2010, 07:35 AM
ninefinger's Avatar
I was controlling the VFD through the GE configurator software on my laptop last night.
At the same time I was snooping on the serial port and recording a log file for future refference of the commmands that were being sent.
Unfortunately the GE software does a lot of monitoring of the drive and is reading continuously so picking out the write commands is a bit tedious. If I get a chance I'll post up some of the commands it sent cause they don't make a lot of sense to me (though I was doing this at midnight so maybe that was the problem).
From memory an example command started as:
01 30 31 06 53 .......
I get the 01 - address 01 but then 30? I can't find anything like this in the manual for a function code?
31 - lost me here too
06 53 - From the manual S06 is operation command so 53h = S in Ascii
Note - i may be reveresing the 06 53 as this is from memory... I'll correct it when I can confirm what I recorded - too many pc's!!!)
Went back and I can't view the log I recorded as its and unknown format to windows and I need some sort of program to read the log file
I might get to this tomorrow and do it all live with multiple pc's to try and get as much as I can written down..
Mike
USB Modbus I/O Using PIC rdhopkins PIC Programing / Design 7 05-02-2012 07:23 PM
Modbus to run GS-2 drive? mecheng10 Mach Mill 13 05-13-2009 08:59 PM
Mach3 with Hitachi VFD using Modbus swinn Mach Software (ArtSoft software) 2 11-28-2008 12:44 PM
EMC2/Modbus......HELP! pauldkeeton LinuxCNC (formerly EMC2) 5 02-18-2007 04:47 PM
modbus device Drew Machines running Mach Software 14 02-11-2007 01:59 PM
