| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
I just got my JGRO up and running for the first time this weekend. While assembling it I managed to break one of my DumpsterCNC AB-nuts so I am not able to run the z-axis, but have both x and y running. I made a pen mount for it so that i could at least seem some fruits of my labor and draw pictures of what i would be routing. very cool. However, there is something wrong with the scale of my machine. When drawing the EMC splash screen g-code "EMC2 Axis" it only draws it about 1/4" tall, i think it is supposed to be larger than that. I also tried making some drawings in Inkscape and converted them with gcodetools and they worked, however they are much smaller than they are supposed to be as well. I don't really know where to start trouble shooting this as this is my first machine and first attempt at using cam and controller software. Any thoughts? Thanks |
| Congratulations on your new machine. Don't be discouraged by the small problems you're having. You probably need to run the step configuration wizard again. My suspicion is you simply made a math error with your stepper setup. In case you haven't found it yet this is a good guide: http://www.linuxcnc.org/docs/EMC2_Getting_Started.pdf Good luck! |
| Newbie- Need Help Setting Up Used Table | ASMCO | Plasma, EDM and other similar machine Project Log | 1 | 05-16-2010 05:13 PM |
| Setting Size of cutout | Crawdaddy | PlasmaCam | 1 | 10-08-2009 04:04 PM |
| Setting Table Height | Sam A | Commercial CNC Wood Routers | 2 | 03-07-2009 03:57 AM |
| Setting Material Size | dgoddard | MadCAM | 8 | 09-08-2007 11:07 PM |
| XY table design basics, linear ways to table size ratio? | Konstantin | Mechanical Calculations/Engineering Design | 0 | 03-13-2007 12:21 PM |
