Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 11-24-2010, 09:54 PM
BWay is on a distinguished road
EMC2 and X axis configuration with 2 sevro's
I am working on driving my x axis with 2 servos using Gecko 320's for each motor. I have been using the EMC2 Stepconfig program to set up the axis/pin assignments. I have tried assigning the pin outputs of the controller board (via the configuration) so both x axis drives are run at the same time and this will only drive the first x axis and the second will be dead. If I switch motors, pin assignments, etc I can get the other motor running but never both at the same time. I also tried setting up the second x axis motor as an A axis and while this allows both motors to be jogged (in test mode) it does not allow them to run at the same time. I am really stumped on this one.
On a side note...I have looked through the prior posts and many have said this is possible but not provided much detail beyond what I have tried. Also, for Mach 3 users reading this....EMC2 does not have a Master-Slave options that does the setup automatically.
Thanks for any input offered.
Old 11-28-2010, 05:05 AM
CaptainVee is on a distinguished road
Not sure if this is at all a normal thought but can't you use one gecko to run both motors parallel?
Sven
http://www.puresven.com/?q=building-cnc-router
Old 11-28-2010, 08:12 AM
This would increase the load on the Gecko and power supply which would probably cause problems.
After much reading I was able to get everything working using the EMC2 gantrykins module which allowed me to drive both motors at the same time.
EMC2 configuration acondit LinuxCNC (formerly EMC2) 6 03-10-2012 11:36 PM
Configuration of Fourth Axis Configuration(Rotation of 360 degree z Axis) Banda LinuxCNC (formerly EMC2) 1 07-12-2010 07:45 AM
EMC2 Configuration File for G540 CoAMarcus LinuxCNC (formerly EMC2) 7 05-22-2009 04:32 PM
HELP!!! Sherline/Ubuntu 6.06/EMC2 - Configuration Telle Benchtop Machines 15 03-21-2009 05:54 AM
Need help with axis configuration jetijs TurboCNC 2 08-24-2006 05:06 AM
