Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-22-2010, 02:26 PM
FozzTexx is on a distinguished road
Auto touch off?
Does anyone know of a guide for setting up an auto touch off for the Z-axis? I've done lots of searching and I've seen people say they've done it and people say they are going to write a guide, but nothing out there really says what files need to be modified and what lines need to be added where.
I'd also love to be able to auto touch off on the x&y axis like I've seen in some videos where they use a copper tube to find the center.
Old 10-24-2010, 12:43 PM
Adding buttons to Axis
Ok, so I'm trying to figure out a procedure to do the auto touch off. I haven't made it very far.
It seems like the first step is to add one of those virtual control panels on the side of Axis so I can click a button to do it. I thought a good button to start with would be a "home" button to simple do g0x0y0z0.
To setup the button requires use of pyvcp, creating an xml file, and adding a line to the .ini file.
Here is my home.xml file:
PHP Code:
<pyvcp>
button>
halpin>"home-button"</halpin>
text>"Home"</text>
button>
pyvcp
In the .ini file you add a line to the [DISPLAY] section:
PHP Code:
PYVCP home.xml
When you load Axis you'll now get a Home button on the right side. Unfortunately it won't do anything. Somehow you need to connect a "pin" to something to execute the g-code.
Old 11-25-2010, 05:31 AM
Tinkers is on a distinguished road
Tou need classiladder to do this routine.
check this out Single_button_probe_touchoff
Need Help!- Touch Pad ardsranger Mach Mill 0 10-05-2010 12:13 PM
Need Help!- Spindle to hot to touch!!! slatronic Industrial Hobbies (Support forum) 58 04-21-2010 07:01 AM
One Touch IGF-L ProToZyKo General CNC (Mill and Lathe) Control Software (NC) 0 01-15-2010 10:53 AM
Spindle Hot To Touch Cory Haas Mills 45 03-29-2008 10:21 AM
anyone use a touch screen? jderou Screen Layouts, Post Processors & Misc 13 09-01-2005 06:09 PM
