Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-22-2010, 12:52 PM
315john is on a distinguished road
M1nn passing a variable question
I am going to use emc2 to run a form grinder the operator needs to run the same program but have some change-able variables. I will use pyVCP to setup spin boxes to change these variable. how do i link them to the m1nn files. Example is GrindFullDepth is entered by operator so i would need
g01 x(grindfulldepth)
as a code but have the number the operator entered in there.
thanks
Old 10-22-2010, 08:03 PM
found info
LinuxCNC.org - signal to global variable - EMC Support Forum
Old 10-22-2010, 11:15 PM
acondit's Avatar
acondit is on a distinguished road
Thanks,
I don't need this right now but I can definitely see using this info in the future.
Alan
http://www.alansmachineworks.com
Passing profile to a macro Dam Parametric Programing 2 05-28-2010 11:02 AM
Passing Geometry back and forth between Cad and Cam Mike RZMachine Dolphin CADCAM 4 10-13-2009 08:31 AM
EMC2 variable pitch / variable diameter threading. samco General Metalwork Discussion 0 03-09-2008 01:40 PM
Another Variable speed question wcarrothers1 Bridgeport and Hardinge Mills 1 05-31-2007 09:24 AM
passing arguments to a sub program kiprip Mazak, Mitsubishi, Mazatrol 1 07-13-2006 11:11 AM
