Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-19-2010, 05:18 PM
scudzuki is on a distinguished road
Does EMC support ATCs and rigid tap
My Cincy Arrow is acting up again and I'm exploring options.
EMC looks like it may be a viable alternative, and given that it's open source and not hardware dependent, should remain so for a while.
My Arrow 500 has a 21 tool "umbrella" changer. Does EMC support toolchangers? I assume it supports macros, so in theory one could be written for a toolchanger.
What about rigid tapping?
TIA
Joe
Old 10-19-2010, 05:47 PM
acondit's Avatar
acondit is on a distinguished road
A gentleman named Stuart has a 5 axis Cinci running emc2 and at the EMCFest a year or so ago they demo-ed rigid tapping.
Look at the last couple of posts on this thread re an ATC.
Large Kearney & Trecker HMC conversion. - CNCzone.com-The Largest Machinist Community on the net!
Good luck,
Alan
http://www.alansmachineworks.com
Old 10-19-2010, 06:37 PM
samco is on a distinguished road
emc2 has integrated ladder (classic ladder). Emc sends out the tool prep command -> that part of the ladder activates and preps the tool -> ladder sends back the command telling emc the tool is prepped.
same with the actual tool change. Emc sends out the tool change command -> ladder changes the tool -> ladder tells emc that the tool has been changed.
I am using ladder - you could also create a hal component. It is a C like language (or you can do it in C if you want to) - that allows you to control real-world things. I wrote a hal component to do my spindle gear shifthing and locking. Very happy with how flexable and powerful emc is.
this is tool chain video
YouTube - Kearney and Trecker tool chain logic working in EMC2. Mechanically barcoded tools
this is an actual tool prep - tool change location and spindle orient - then tool change.
YouTube - Kearney and Trecker full tool change with spindle orient
spindle shifting - running though the 16 gears
YouTube - kearney and Trecker 16 speed spindle gearbox
sam
Old 10-19-2010, 08:14 PM
Thanks for the info guys.
Joe
Old 10-20-2010, 11:24 AM
jthornton is on a distinguished road
I converted my Hardinge CHNC to EMC with no problems. It has an 8 station tool changer and I used Classicladder to do the tool change.
John
Old 10-20-2010, 09:33 PM
*Registered User*
wjr09 is on a distinguished road
Originally Posted by jthornton View Post
I converted my Hardinge CHNC to EMC with no problems. It has an 8 station tool changer and I used Classicladder to do the tool change.John
I'm curious to know what you use to keep track of which tool position is which for your application.
Old 11-08-2010, 11:06 AM
stustev is on a distinguished road
I am the 'Stuart" referred to in an earlier post. Here is a video of a machine with a random tool changer.
http://www.mpm1.com:8080/machines/en...toolchange.mp4
This is done with a hal component I wrote.
ATCs and Little Tools HimyKabibble Bridgeport and Hardinge Mills 1 03-11-2009 07:42 PM
What exactly is Rigid tapping? Why people always ask does it do rigid tapping? cjchands General Metalwork Discussion 23 12-19-2008 08:19 AM
How do I rigid tap on a VM 7 III Mazakdude OKK 3 05-20-2008 04:16 PM
rigid`ing tm-1 ? pit202 Haas Mills 7 04-11-2008 07:31 AM
Rigid tap 100 Haas Mills 7 05-11-2007 11:53 AM
