Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 10-01-2010, 06:14 AM
Shen Bingquan is on a distinguished road
Creating a new module in HAL
Hi all,
I was wondering if it is possible to create a new module in HAL so that i can customize my own functions, pins and parameters.
Something like "loadrt pid" but instead i would like to have "loadrt MY_MODULE".
Someone mentioned using .comp. Is it possible using comp? And how to go about doing it? Cuz i keep getting the following message when i type "$ comp ddt.comp"
"The program 'comp' can be found in the following packages:
* mailutils-mh
* nmh
Try: sudo apt get install "
Thanks.
BQ
Old 10-01-2010, 04:52 PM
samco is on a distinguished road
Yes - you should be able to do that.
read up on
Comp: a tool for creating HAL components
also - take a look at other comps
git.linuxcnc.org Git - emc2.git/tree - src/hal/components/
sam
love to see your fuzzy pid
Old 10-03-2010, 10:44 PM
chester88 is on a distinguished road
you have to add the development packages to compile components.
look here:
EMC Documentation Wiki: ContributedComponents
Old 10-05-2010, 01:41 AM
I tried installing emc2-dev by '$ sudo apt-get install emc2-dev'
But the following error msg keep coming up.
dpkg: error processing /var/cache/apt/archives/emc2-dev_1%3a2.4.4_i386.deb (--unpack):
trying to overwrite '/usr/share/man/man1/comp.1.gz', which is also in package nmh 0:1.3-1
dpkg-deb: subprocess paste killed by signal (Broken pipe)
Processing triggers for man-db ...
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
Help?
Old 10-05-2010, 02:05 AM
hmm not sure what that means but I might guess that the package is already installed or the versions are wrong.
How did you get EMC and what version is it? What distribution on Ubuntu are you using?
Are you trying to compile the comp file correctly now?
(The last way you said you tried it is not right)
You did read the instructions right
Chris M
Old 10-05-2010, 07:56 AM
Ok it seems like the comp command is working after I restarted my computer, but there are still some minor issues.
"$ comp ddt.comp" creates a ddt.c file in my desktop
But when i type "$ comp --install ddt.comp" to install the .ko into my emc2 dir
it outputs an error message Unable to locate Makefile.modinc
Am I still missing anything?
Old 10-07-2010, 12:38 AM
Well, after i reformatted my whole system and reinstall emc2 followed by emc2-dev there is now a different error after i tried compiling the module
"$ comp install BQ.comp"
WARNING: "hal_init" [/tmp/tmpXwbloT/BQ.ko] undefined!
WARNING: "rtapi_print_msg" [/tmp/tmpXwbloT/BQ.ko] undefined!
WARNING: "hal_exit" [/tmp/tmpXwbloT/BQ.ko] undefined!
WARNING: "hal_export_funct" [/tmp/tmpXwbloT/BQ.ko] undefined!
WARNING: "hal_malloc" [/tmp/tmpXwbloT/BQ.ko] undefined!
WARNING: "rtapi_get_msg_level" [/tmp/tmpXwbloT/BQ.ko] undefined!
WARNING: "hal_pin_bit_newf" [/tmp/tmpXwbloT/BQ.ko] undefined!
WARNING: "hal_pin_s32_newf" [/tmp/tmpXwbloT/BQ.ko] undefined!
WARNING: "rtapi_snprintf" [/tmp/tmpXwbloT/BQ.ko] undefined!
WARNING: "hal_ready" [/tmp/tmpXwbloT/BQ.ko] undefined!
WARNING: "hal_pin_float_newf" [/tmp/tmpXwbloT/BQ.ko] undefined!
WARNING: "rtapi_set_msg_level" [/tmp/tmpXwbloT/BQ.ko] undefined!
CC /tmp/tmpXwbloT/BQ.mod.o
LD [M] /tmp/tmpXwbloT/BQ.ko
make[1]: Leaving directory `/usr/src/linux-headers-2.6.32-122-rtai'
cp BQ.ko /usr/realtime-2.6.32-122-rtai/modules/emc2/
cp: cannot create regular file `/usr/realtime-2.6.32-122-rtai/modules/emc2/BQ.ko': Permission denied
make: *** [install] Error 1
never seen this error previously..
Old 12-17-2010, 03:30 AM
Ryobiguy is on a distinguished road
Try prepending sudo:
sudo comp install BQ.comp
Old 10-24-2011, 09:16 PM
wangyu is on a distinguished road
I had the same problem.
Newbie- laser module to a new cnc stregoi Laser Engraving & Cutting Machines 4 05-19-2010 01:20 AM
MasterCam art module gabi68 Mastercam 1 02-24-2008 09:21 PM
if you need ic and module,please tell me. keithshen Want To Buy...Need help! 0 01-07-2008 07:07 AM
Lathe Module rodneydeeeee BobCad-Cam 9 08-27-2007 06:09 PM
Please need help on I/O Module yeager General Electronics Discussion 9 01-13-2006 08:19 AM
