Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 07-06-2010, 02:36 PM
goaran is on a distinguished road
sending commands from EMC over ethernet
Hello,
i want to send the movement commands from emc2 over ethernet to an FPGA board. In the FPGA board there will be the realtime stuff like the interpolation of the axis.
Now my question: Is ist possilbe to link the command for the movement to ethernet somehow?
Old 07-06-2010, 02:52 PM
irrational is on a distinguished road
Originally Posted by goaran View Post
Hello,
Hey VNC would let you run EMC2 over your network.
--IM
Old 07-06-2010, 03:10 PM
thanks for the quick answer, but i dont want to run emc over network, but just sending the motion commands which are used in emc after the interpreter over network to an fpga board.
The idea is to use emc2 as control-gui for a cnc control which will be inside the fpga..
Old 07-14-2010, 11:37 PM
rangerwreck is on a distinguished road
It doesn't sound like it, but I'm after the same thing. I think think the PWM and PID loop should be run on dedicated hardware, with EMC queuing it motion commands over ethernet, or high speed serial.
Google up "emc rtnet".. someone had something going, didn't sound like anything ready to drive our machines though
Old 07-27-2010, 12:33 AM
erlyrisa is on a distinguished road
I was hoping to chain multiple EMC2 machines (PCs) together in co-operation ...
eg. one machine that controls a pallet feader, and is controlled or controls/tells the other machine to start cutting.
I heard you can control EMC2 remotely... would be a daunting task to setup though.
Arc commands on GE1050HLX MetLHead G-Code Programing 3 07-16-2008 07:47 AM
r plane commands ghostlx G-Code Programing 2 06-04-2008 01:03 PM
G2 and G3 Commands Bohemund G-Code Programing 19 05-28-2007 09:12 AM
Difference between BL and SV commands? Shizzlemah Fadal 3 03-23-2007 08:33 AM
EMC & the G28/G30 Home commands Javelin276 LinuxCNC (formerly EMC2) 1 07-18-2005 03:13 PM
