Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 07-05-2010, 09:38 AM
M250cnc's Avatar
M250cnc is on a distinguished road
Front & Rear Tools
I currently use a G51 x-2 to use a rear toolpost.
Is there an equivalent procedure for EMC2 ?
Old 07-05-2010, 07:46 PM
chester88 is on a distinguished road
There is no mirror image function in EMC2.
if you want to use a rear turret you must code it as if its a front tool.
untill someone writes a mirror image function which won't be anytime soon I would bet.
but I would like it for my lathe too.
Chris M
Old 07-06-2010, 01:01 AM
M250cnc's Avatar
Thanks for the answer Chris.
Do the developers know it is a much needed feature ?
I tried just coding when i first tried it on Mach3 because to a simpleton like me it should work. But no it doesn't, but G51 x-2 does
Old 07-06-2010, 09:32 PM
I would say no.
mills are the main stay.
Having Diam mode is actually fairly recent!
I would suggest you join the mail list and ask.Here:
https://lists.sourceforge.net/lists/listinfo/emc-users
and add a formal request on source forge.Read here:
http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?Trackers
This is an informal feature request list :
http://wiki.linuxcnc.org/cgi-bin/emcinfo.pl?EmcFeatures
Its mostly for reference.
Chris M
Old 07-07-2010, 03:06 AM
M250cnc's Avatar
Hi Chris,
Thanks for the help thus far.
Is it OK to add another name to the request list to say, yes i want this too ?
Will be doing some more reading
Additional rear light pit202 Haas Mills 3 06-18-2010 12:28 PM
Lathe with Front and Rear tool posts slammers Mastercam 2 05-31-2009 04:49 PM
RFQ- Small job on a front and rear panel Dougie085 Employment Opportunity 29 04-18-2008 07:17 PM
Rear toolpost operations? zephyr9900 Mach Lathe 4 10-12-2007 04:00 PM
Adding rear shaft to MCG ID33004 avale Servo Motors and Drives 7 07-03-2007 04:00 PM
