Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 06-22-2010, 01:28 PM
MrWild is on a distinguished road
Question Gcode sub program example needed
Could someone post an example of a nested sub program? I know that there are su programs for drilling and etc., but I'm interested in how the sub program is defined, labeled, called, and ended. It need not be a large program, just that it contains how to do sub programs in EMC2.
Old 06-23-2010, 03:18 PM
More information. People say that EMC2 uses the same commands as a Fanuc control, yet EMC2 doesn't recognize M98 and M99. I've read over and over about O100 or 0100 labeled subprograms, but still don't understand the full workings of how they relate to say a Fanuc6M post that uses M98 to call, and M99 to end subprogram. EMC2 G98 and G99 don't seem to be the same commands. The EMC2 manual and quick G-code guide do not give much in the way of examples, and my tech school book doesn't use EMC2's protocols for G-code writing.
My Anilam M and Fanuc Posts in Dolphin Part Master does fine for none subprogram posts, but the minute I start getting involved with subprograms there are problems. I have the PP manual for Partmaster posts, but need subprogram example to make the changes needed.
Old 06-23-2010, 05:00 PM
dpuch is on a distinguished road
looking at the EMC manual it uses O### <-- any unique number as the sub label followed by "sub, endsub, call" instead of M98, M99 that fanuc uses.
It looks like any O number can be used, not just 100 or 101 like in the examples. It also allows calling subs in separate files. In that case the O is followed by the file name. The sub program still has to have O### sub, and endsub lines.
Old 06-23-2010, 05:28 PM
Something I don't understand about the examples. When a notation is made at the start of program , () is used so Axis knows it isn't part of the program. In all but the first example they have constants(?) inside of (). Like;
o200 sub (1=x ... 2=i ... )
and when I look down at the rest of the program it seems that the () data IS being looked at by Axis. I would use the G-code basic tutorial in the WIKI, but it isn't more than an outline of possible chapters with no information and the last update was over two years ago.
The G-code program I'm trying to make has two .64 dia pockets .76 deep 3" away from each other on Y axis, and a border (boss) around them (part of a dust boot). The boss is machined semi finish, and finish passes using separate depths as roughing clears all surrounding material and i don't want that. The loop would be three steps at deeper depth on the boss, and holes.
My text book just assigns a name (number) to a sub g-code program for a call.
move to position, call sub "whatever" which has an incremental modal g-coded program,
finish the sub cut, end sub, move in absolute, and repeat.
The examples in the advanced coding is well,... advanced and uses a different (macro?) format. So looking at what my book says is way different from what I'm seeing.
Old 06-23-2010, 10:13 PM
The variables are set by the call line, not the beginning of the sub. Also use [] not ()
O115 call [1] [2] [37] [3.2]
inside:
O115 sub
(#1=1, #2=2, #3=3,7 #4=3.2)
O115 endsub
Note: the sub code needs to be before the call line in your program unless it is called from a separate file. It has to be read first, but it will not execute until you use the call command.
Old 06-25-2010, 01:31 AM
cyclestart is on a distinguished road
example:
main program:
Code:
G00 x1 y1 z.25
o123 call
G00 X2
o123 call
m2
subprogram:
Code:
o123 sub
G91
G01 z-.5 f10
G03 x.5 y0 r.25 f5
x-1 y0 r.5
x1 y0 r.5
x-.5 y0 r.25
G01 z.5
g90
o123 endsub
main program can be what-ever-name.ngc
subprogram is 123.ngc
Save both programs in the prefix directory set in the .ini file. This is most likely to be home/you/emc2/nc_files
Untested and not meant for actual milling
Anyone who says "It only goes together one way" has no imagination.
Old 07-15-2010, 03:56 AM
ArcEye is on a distinguished road
Sub Program example
Hi
Don't know if you have got to grips with this yet. Very often you don't actually need to put the subroutine in a separate file, only if the code is to be reusable to other code files.
There are 2 examples attached that I use as a psuedo G71 template for linear turning.
I have a different one for turning which involves arcs.
The decrementing of the X value for each cut is calculated in a separate file '710.ngc' because I use it with other templates.
It also shows the use of named parameters, passing parameters in the subroutine call and using the return value parameter.
1 - 30 can be parameters to the call and 31-60 the return values.
Named Parameters are a real plus for EMC gcode, make reading the code much easier 2 months later!
Hope this is of some assistance.
regards
ArcEye
File Type: txt 710.ngc.txt‎ (965 Bytes, 110 views)
Old 07-22-2010, 08:49 PM
Originally Posted by ArcEye View Post
Hi
regards
ArcEye
WOW. My G-code text book is much too basic. Where might I find a book that tells and explains what each line. and word represents? I can write snfd proof G-code, but this is different than Gwords telling do this and do that. My bok defines a sub program as another g-code string of move.
I like the way it seems to have addresses, but I haven't learned this style. Heck I didn't even know it existed, being self taught. Knowing would help trouble shoot an EMC2 post I'm playing with. As a work around, its all posted as long hand. Fanuc sub programming isn't the same as EMC2 in all respects.
Old 07-22-2010, 10:59 PM
Sub calls can be a simple path, or complex macro commands. It all depends on the creativity of the programmer.
The main reason for simple subs is you only need to change code in 1 place to change every use of the sub.
Macros (fancy subs) allow the use of the same code to do varied operations. Again easily changed in the sub, or by the sub call parameters.
Two samples might be:
Simple g-code that is executed where ever the sub is called
Code:
o123 call (1 x 1 square)
o123 sub (1" square sub)
G91
G1 X1.0 F10.0
Y1.0
X0.0
Y0.0
G90
o123 subend
A more advanced example that uses the two numbers in the call line to change the lengths of the rectangle each time it is called.
Code:
o123 call [2.0] [1.5] (2 x 1.5 rectangle)
o123 call [1.0] [2.5] (1 x 2.5 rectangle)
o123 sub (rectangle macro)
G91
G1 X#1 F10.0
Y#2
X0.0
Y0.0
G90
o123 subend
Remember EMC2 needs the sub to be BEFORE the call, or in a separate file like ArcEye's attachements
Old 07-23-2010, 02:40 AM
Learning GCode
Hi
All the information needed is in the wikis and documentation, the trouble is that you have to know what it is you need to know, sometimes a chicken and egg situation.
I have not found any really useful books, but I can recommend the articles in Digital Machinist magazine by Ed Nisley.
He uses EMC and in particular uses named parameters, sub-routines etc that are specific to EMC.
His series started some while back but back issues are available quite cheaply from Village Press.
The only issue I have with Digital Machinist, is that the other articles tend to be hugely wordy and padded.
I don't know if this is an American trait or just this magazine.
I for one do not need 6 pages and a blow by blow description of drilling operations interspersed with workshop reminiscences, where 1 page and 2 photos would have made all abundantly clear.
That said, there are a couple of writers who make the purchase worthwhile.
Good Luck
ArcEye
  #11   Ban this user!
Old 09-01-2010, 05:37 AM
piasdom is on a distinguished road
fairly new to emc2 and newer still to making complex sub. but i hope this helps.
g17 g20 g40 g49 g54 g80 g90 g94
(Mill Four Ports)
#<_plunge> = 3
#<_startfeed> = 3.5
#<_regfeed> = 5
#<_finfeed> = 8
#<_fastfeed> = 12
#<_safeheight> = .2
#<_start> = .05
#<_end> = .06
#<_.69step> = -.69
#<_.8depth> = -.8
o100 sub (roughing top)
g1 f#<_startfeed> x#<_start> y#<_start>
y2.27
x1.2
y#<_start>
x#<_start>
x.03 y.03
f#<_regfeed>
y2.29
x1.22
y.03
x.03
x#<_end> y#<_end>
o100 endsub
o101 sub (top cleanup)
f#<_regfeed> x.15 y .15
x1.05
y2.15
x.15
y.15
x.3 y.3
x.9
y2
x.3
y.3
x.45 y.45
x.75
y1.85
x.45
y.45
x.6 y.6
y1.7
o101 endsub
o102 sub (finishing top)
g1 f#<_regfeed> x.022 y.022
y2.293
x1.228
y.022
x.022
x.015 y.015
y2.3
x1.235
y.015
x.015
x.01 y.01
y2.305
x1.24
y.01
x.01
x.005 y.005
y2.31
x1.245
y.005
x.005
x0 y0
y2.315
x1.25
y0
x0
f#<_fastfeed> y2.315
x1.25
y0
x0
g0 x#<_end> y#<_end>
o102 endsub
o103 sub (roughing Step)
g1 f#<_startfeed> x.02 y.02
x.01 y.01
y2.02
x.91
y2.305
x1.24
y1.76
x.99
y.09
x1.24
y.01
x.01
(step cleanup)
x.15 y.15
x.8
y1.85
x1.075
y2.165
y1.9
x.15
y.25
x.65
y1.7
x.3
y.35
x.475
y1.5
o103 endsub
o104 sub (finish step)
g0 z#<_safeheight>
g1 f#<_regfeed> z#<_.8depth>
x.005 y.005
y2.025
x.9
y2.31
x1.245
y1.75
x1
y.1
x1.245
y.005
x.005
x0 y0
f#<_finfeed> y2.03
x.9
y2.315
x1.25
y1.75
x1
y.1
x1.25
y0
x0
f#<_fastfeed> y2.03
x.9
y2.315
x1.25
y1.75
x1
y.1
x1.25
y0
x0
o104 endsub
o105 sub (tool change)
g0 z2
g49 g80
g0 x3.8 y2
o105 endsub
o106 sub (0.0 run on top)
g1 f#<_fastfeed> x.01 y.01 z-.68
x0 y0
y2.315
x1.25
y0
x0
z#<_safeheight>
o106 endsub
( o107 sub)
(O102 if [#<_.69step> lt .68])
( o100 call [10])
(O102 else)
( o101 call)
(O102 endif)
( o107 endsub)
(program start)
G10 L2 P1 x0 y0 z0 (p1 = g54, L2? L1? L10? L20?)
G10 L2 P2 x1.9 y0 z0 (p2 = g55 )
G10 L2 P3 x3.8 y0 z0 (p3 = g56 )
G10 L2 P4 x5.7 y0 z0 (p4 = g57,p5 = g58,etc...g59.3)
o105 call
g28.1
(o107 call)
g54 (g54)
g64 p.005 q0
g0 x#<_start> y#<_start>
z#<_safeheight>
m6 t4
(msg, first port)
(disable / to mill from blank stock)
g1 f#<_regfeed> z-.1
/o100 call
g1 f#<_plunge> z-.2
o100 call
/o101 call
g0 z#<_safeheight>
g1 f#<_plunge> z-.3
/o100 call)
g1 f#<_plunge> z-.4
o100 call
/o101 call
g0 z#<_safeheight>
g1 f#<_plunge> z-.5
/o100 call
g1 f#<_plunge> z-.6
o100 call
/o101 call
g0 z#<_safeheight>
g1 f#<_plunge> z-.675
o100 call
g1 f#<_plunge> z#<_.69step>
o100 call
o101 call
g0 z#<_safeheight>
o102 call
g0 z#<_safeheight>
g1 f#<_plunge> z-.78
o103 call
g0 z#<_safeheight>
g1 f#<_plunge> z#<_.8depth>
o103 call
o104 call
o106 call
g0 z#<_safeheight>
g55 (g55)
(msg, second port, s to continue)
m1 (alternate stop)
/o100 call
g1 f#<_plunge> z-.2
o100 call
/o101 call
g0 z#<_safeheight>
g1 f#<_plunge> z-.3
/o100 call)
g1 f#<_plunge> z-.4
o100 call
/o101 call
g0 z#<_safeheight>
g1 f#<_plunge> z-.5
/o100 call
g1 f#<_plunge> z-.6
o100 call
/o101 call
g0 z#<_safeheight>
o100 call
o100 call
o101 call
g0 z#<_safeheight>
o102 call
g0 z#<_safeheight>
o103 call
g0 z#<_safeheight>
o103 call
o104 call
o106 call
g0 z#<_safeheight>
g56 (g56)
(msg,third port, s to continue)
m1 (alternate stop)
/o100 call
g1 f#<_plunge> z-.2
o100 call
/o101 call
g0 z#<_safeheight>
g1 f#<_plunge> z-.3
/o100 call)
g1 f#<_plunge> z-.4
o100 call
/o101 call
g0 z#<_safeheight>
g1 f#<_plunge> z-.5
/o100 call
g1 f#<_plunge> z-.6
o100 call
/o101 call
g0 z#<_safeheight>
o100 call
o100 call
o101 call
g0 z#<_safeheight>
o102 call
g0 z#<_safeheight>
o103 call
g0 z#<_safeheight>
o103 call
o104 call
o106 call
g0 z#<_safeheight>
g57 (g57)
(msg,fourth port, s to continue)
m1 (alternate stop)
/o100 call
g1 f#<_plunge> z-.2
o100 call
/o101 call
g0 z#<_safeheight>
g1 f#<_plunge> z-.3
/o100 call)
g1 f#<_plunge> z-.4
o100 call
/o101 call
g0 z#<_safeheight>
g1 f#<_plunge> z-.5
/o100 call
g1 f#<_plunge> z-.6
o100 call
/o101 call
g0 z#<_safeheight>
o100 call
o100 call
o101 call
g0 z#<_safeheight>
o102 call
g0 z#<_safeheight>
o103 call
g0 z#<_safeheight>
o103 call
o104 call
o106 call
g0 z#<_safeheight>
(msg,Complete)
g40 g80 g54 g92.1
m6 t0
g28
m2
o100b sub (roughing top)
o101b sub (roughing Step)
o102b sub (finish step)
o103b sub (finishing top)
o104b sub (top cleanup)
o105b sub (safe position)
o106b sub (0.0 run on top)
  #12   Ban this user!
Old 09-01-2010, 01:07 PM
A nice real world example.
Because it is long though, I wanted to edit your example to show the different parts better. Note the order. Also note this example is using nicely named global variables, and not passing local only variables in the sub call command as I posted above.
Start of program
set variables before any use
define sub programs
Main program with sub calls
(Mill Four Ports)
#<_plunge> = 3
#<_startfeed> = 3.5
#<_regfeed> = 5
#<_finfeed> = 8
#<_fastfeed> = 12
#<_safeheight> = .2
#<_start> = .05
#<_end> = .06
#<_.69step> = -.69
#<_.8depth> = -.8
y2.27
x1.2
y#<_start>
x#<_start>
x.03 y.03
f#<_regfeed>
y2.29
x1.22
y.03
x.03
x#<_end> y#<_end>
o100 endsub
x1.05
y2.15
x.15
y.15
x.3 y.3
x.9
y2
x.3
y.3
x.45 y.45
x.75
y1.85
x.45
y.45
x.6 y.6
y1.7
o101 endsub
... snip
(program start)
o105 call
g28.1
(o107 call)
g54 (g54)
g64 p.005 q0
z#<_safeheight>
m6 t4
(msg, first port)
/o100 call
g1 f#<_plunge> z-.2
o100 call
/o101 call
g0 z#<_safeheight>
... snip
m2
Help needed for incremental line numbering of a Gcode program yaji63 G-Code Programing 14 06-25-2010 02:12 PM
Need Help!- Direction needed with BobCad Pro Art X to GCode tamedia1 BobCad-Cam 1 03-23-2010 03:47 AM
Warmup Program Gcode Phife DIY-CNC Router Table Machines 6 01-08-2010 07:45 PM
What program builds 3D Model from GCode? cjjonesarmory General CAM Discussion 2 07-28-2009 02:33 PM
cheap bitmap to gcode program balsaman DIY-CNC Router Table Machines 29 07-28-2003 01:04 PM
