Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 05-22-2010, 01:14 AM
Regnar's Avatar
Regnar is on a distinguished road
Homing question/setup
Hey everyone, I am finally going to install limit/homing switches. I have 3 pins left on the BOB and would be enough to give all 3 axis their own pin but none future expansion.
My question is If each axis has its own pin will all 3 axis home at the same time or would it only do 1 axis at a time.
If it does 1 axis at a time in my mind it wouldn't be worth 3 pins it would only be worth 1 pin unless I am completely missing something.
Thanks for you help.
Old 05-22-2010, 04:06 AM
dlktdr is on a distinguished road
You can make EMC home each axis one at a time or in any order you like with the HOME_SEQUENCE property in the ini file..
Usually you would make the Z home first so it's out of the way then you can do the others.. Set the home_offset a little away from the switch so it can't be accidentally triggered when the second axis goes to home.. If your using a limit switch for the home switch you also have to set home_ignore_limits so it won't fault out when it hits it. You can also set HOME_IS_SHARED so it won't start homing if one of the switches is already closed.
I always like 3 homes gets 3 inputs for debugging sake but if your low on IO go for it.
homing/limit setup Thorpydo Benchtop Machines 3 01-04-2010 12:46 AM
Need Help!- Homing and Limits Setup Mr.Chips Mach Software (ArtSoft software) 33 01-21-2009 09:12 PM
How to setup homing in Syil X3 albatros62 Syil Products 5 11-11-2007 12:14 AM
New setup with Mach3 - Limits work, homing doesn't journeyonline Mach Software (ArtSoft software) 10 03-21-2007 09:09 PM
what is the best homing and limit switch setup? Bryscnc Machines running Mach Software 1 09-28-2006 05:37 AM
