Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 05-01-2010, 05:55 AM
ferdi_mcrohl is on a distinguished road
EMC2 and PWM MESA 5i20
I tried to drive dc motor with H-bridge,,, I used mesa's pwm as signal to dc motor,, but the motor didn't move,,
when I check the signal voltage of PWM with oscilloscope,, It's pick value is around 3.6 Volt,,I suspect that the signal is too low to drive the motor,,
I wonder,,,what must I do to get the signal with 5 volt pick value?? Do I need additional circuit to do that??
Old 05-01-2010, 08:45 AM
PCW_MESA is on a distinguished road
The 5I20 default high level output value is 3.3V, Normally this should be OK for driving TTL level inputs, but is is possible to get more output swing by setting the outputs into open-drain mode. the output will swing up to 5V in open drain mode but only have a 3.3K pullup. If a 3.3K pullup is too weak (too slow risetime would be a symptom) you may need to add an external pullup resistor to the pin (around 270 ohm minimum)
open drain mode is a HostMot2 HAL setup option (man hostmot2)
Old 05-04-2010, 04:56 AM
how to set it to opendrain mode? with hal or jumper W4?
I read the manual, it said we can use .is_opendrain in PWM,, but when I check the PWM parameter in terminal, I didn't see .is_opendrain parameter.
Old 05-04-2010, 10:36 AM
Its not a PWM option, its a I/O pin option (it is selectable individually on all I/O pins) So the first step is to determine which I/O pins you need to change, you can determine this by reading the .PIN file or dmesg, these will show you which I/O pins the PWM outputs are connected to. Once you know which I/O pins to change you set the is_opendrain parameter for each selected pin.
Old 05-18-2010, 05:56 AM
thanks...
I have another question,,,
when I run EMC2 with Mesa 5i20, sometimes there is an error. It says
"hm2-servo.hal:46arameter or pin 'hm2_5i20.0.pwmgen.pwm_frequency' not found 8091". but sometimes, it doesn't occur. why is this error happen??
Old 05-18-2010, 08:10 AM
thanks...
It probably means that the firmware did not load for some reason, You can get more details by using dmesg to find the exact driver complaint.
Reasons for occasional firmware misloads that we've seen:
1. Dirty edge connector --> Clean MB edge connector and 5I20 edge connector with with 99% isopropal alcohol
2. Bad or damaged 5I20 --> call us for a replacement, its probably under warranty.
3. External overload on multiple I/O pins --> remove overload
4. Flaky motherboard --> (replace)
5. Flaky software (most likely if you are compiling EMC yourself and some bug has been introduced) --> use standard distribution
Old 05-19-2010, 02:05 AM
if we configure the EMC2 for position control with hal
net motor.00.pos-fb hm2_5i20.0.encoder.00.posistion => pid.0.feedback
net motor.00.pos-fb => axis.0.motor-pos-fb
net emcmot.00.pos-cmd axis.0.motor-pos-cmd => pid.0.command
net motor.00.command pid.0.output => hm2_5i20.0.pwmgen.00.value
how does EMC2 differ two Gcodes with different feed rate?
for example :
G01 X5.0 F5
and
G01 X5.0 F2
Old 05-19-2010, 10:24 AM
for example :
G01 X5.0 F5
and
G01 X5.0 F2
This is actually a general EMC question so you might want to change the title to get a better answer but if I understand your question, the answer has little to do with your HAL file fragment, that portion of the HAL file just sets up a normal PID loop so that the actual position follows the commanded position
The commanded position: emcmot.00.pos-cmd axis.0.motor-pos-cmd is what controls the actual axis movement. It comes from EMCs trajectory
generator, and so is controlled by your feed rates
EMC2+mesa 5i20+automatic tool changer visky LinuxCNC (formerly EMC2) 6 06-12-2010 03:01 PM
Mesa 5i20 PCI card karl1 General Electronics Discussion 0 03-06-2010 11:17 AM
Mesa 5i20 + Boot Up Sequence TZak LinuxCNC (formerly EMC2) 2 12-10-2008 11:55 PM
Spindle Encoder to Mesa 5i20 RogerN LinuxCNC (formerly EMC2) 3 10-17-2008 07:55 AM
Mesa 5i20 and EMC daedalus LinuxCNC (formerly EMC2) 6 06-27-2007 02:19 PM
