Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 03-21-2010, 12:16 AM
kanton's Avatar
kanton is on a distinguished road
EMC for Lucid Lynx?
The new version of Ubuntu, codenamed Lucid Lynx is due out in April. Does anyone know if a new version of EMC will be produced for it? Will a new install .iso be available? If so when?
Thanks.
Old 04-06-2010, 07:27 PM
Parpalu's Avatar
Parpalu is on a distinguished road
# March 1: emc 2.4~beta.deb packages on linuxcnc.org (pre-beta packages are [already available])
* Call for translators
* update documentation for new features
# (create v2.4_branch somewhere in here)
# April 15: emc 2.4.0 packages on linuxcnc.org
# June 1: anticipate at least one bugfix release by this date
# June xx: emc 2.4.1 / Ubuntu 10.04 Live CD by Fest
Old 08-20-2010, 10:27 AM
outofoperation is on a distinguished road
Hello,
found the info on another forum, 10.04 EMC˛ is here available. Note, that it isn´t the Live-CD, but the installer-version.
regards, Steff
Old 08-20-2010, 02:52 PM
samco is on a distinguished road
actually - that is the livecd.
sam
Old 08-22-2010, 07:54 PM
skullworks is on a distinguished road
Thumbs up
Sweet!
Old 08-22-2010, 08:07 PM
Valen is on a distinguished road
I've been hanging out for this release
SMP enabled by default, means we should get much better performance out of the box on modern dual core machines, and no need to compile stuff. Rather fast boots as well.
I can't wait to get it on our mill.
Do keep an eye out for this bug with ubuntu 10.04 though, it stops some services from starting at boot.
https://bugs.launchpad.net/ubuntu/+s...6?comments=all
www.vapourforge.com
Old 09-18-2010, 03:21 AM
greybeard's Avatar
greybeard is on a distinguished road
I've done a clean install of 10.04 on a pentium 3/32bit over the last week, and am still having some problems with the gui not loading properly.
I then downloaded the latest EMC2 and have version 2.4.3.1 installed.
Currently I can't get any config file to work, even the sample sherline 3axis throws up an error file window.
1. has anyone got this version working ok ?
2. Can I launch the Axis window without first launching emc2 ?
John
It's like doing jigsaw puzzles in the dark.
Enjoy today's problems, for tomorrow's may be worse.
Old 09-18-2010, 10:15 AM
wendtmk's Avatar
Moderator
wendtmk is on a distinguished road
What does it say in the error window that comes up? Without seeing the error, it's a bit difficult to help you troubleshoot. What have you attempted to do so far? Have you run the Stepconfig wizard? Are you using .ini and .hal files from a different installation? Usually, if you scroll down a little bit in the error window (if it's the error window I'm thinking of) it will tell you exactly which file and the line number that the startup is croaking on.
Mark
Old 09-18-2010, 11:47 AM
greybeard's Avatar
Hi Mark, and thanks for your posting.
I've been posting over the last couple of days to both the linuxcnc forum, and to the Ubuntu forum, and have had quite a lot of help in my endeavours.
Having learnt quite a lot in the process, it wasn't wasted, but seeing that quite a few people have been posting simillar problems with 10.04 not loading the gui correctly(got past that eventually), not being able to get emc2's config to work either was a bit of a set-back, to say the least.
My posting here was only to find out if anyone had got it all working, as an encouragement to myself, but about an hour ago, I gave up, and am in the process of re-installing 8.04 and whatever emc2 version that I had on the cd.
It never gave me any problems other than my own inexperience, so I shall wait to hear when later versions are bug free, before I try again.
Regards
John
Old 09-18-2010, 03:57 PM
Zig Zig is offline
Zig is on a distinguished road
John,
I tried the iso from the link posted in a response few responses below this one.
Initially I got an error , EMC2 would not fire up.
I then looked at the comments in cnclinux forum and the solution was straight forward. Had to delete a statement in the old .INI file.
I am sorry I can not recall exactly whihc line it was but it is as simple as that.
  #11   Ban this user!
Old 09-18-2010, 04:13 PM
greybeard's Avatar
Hi Zig.
Thanks for the info, but like I said, I've given up for the time being. i need to get the m/c running again.
The only reason I wanted to upgrade was to get the inkscape path to gcode latest version.
I've now got that on the laptop running my drawing programs, so it will hardly be a problem to transfer them after the conversion via a pendrive.
Just got one idea fixed in my head and couldn't see the alternatives.
Ho hum, off to bed.
John
Old 09-19-2010, 08:48 AM
wendtmk's Avatar
Moderator
I got mine up and running over the last week. I'd been running EMC2 v2.4.3 on the old Ubuntu 8.04 system, and basically just copied my configs and such over to the new machine. Been working like a champ.
Were you trying to use old .ini's and hal files on the new setup?
Mark
lynx 85 breazr CNC Plasma and Waterjet Machines 2 02-07-2011 03:02 PM
LYNX-T1 - my first design rakus CNC Wire Foam Cutter Machines 0 10-16-2009 08:21 AM
Dawoo lynx positiverake Daewoo/Doosan 0 08-24-2009 03:42 PM
lynx 220 wilko Daewoo/Doosan 1 02-02-2007 08:26 AM
DaeWoo Lynx 200 GL fjd Daewoo/Doosan 5 10-29-2005 09:43 PM
