Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 04-26-2005, 11:44 AM
raytor is on a distinguished road
Linux/EMC file conversion help needed
I just installed BDI/EMC Debian kernel Linux on my Sherline mill - I can run g-code written with a text editor just fine. But all of the CAD programs on the disc (Sherline) save in a format that EMC will not load (Synergy and QCAD). Is there a good Linux based CAD program that will generate g-code in a format that I can read? Preferably Linux GNU based. Or is there a conversion program for .syn and .dxf files?
Old 04-26-2005, 12:32 PM
Jan Jan is offline
Jan is on a distinguished road
check this link:
http://www.ribbonsoft.com/camexpert.html
emc does not understand dxf files, the above will convert your dxf to an nc file, upload that to emc.
jerry
CNC mini-lathe conversion help needed. minilatheman Mini Lathe 5 05-24-2005 08:47 AM
Advise needed for rotary table conversion spoiledbrat DIY-CNC Router Table Machines 2 05-11-2005 03:34 PM
Vacuum pump/blower conversion needed Al_The_Man DIY-CNC Router Table Machines 10 01-16-2005 09:46 PM
File conversion signIT General CAM Discussion 0 06-13-2004 06:55 AM
File conversion JOE65 Autodesk Software (Autocad, Inventor etc) 9 05-28-2003 08:57 AM
