Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > LinuxCNC (formerly EMC2)
LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here!
Old 03-08-2010, 01:15 PM
sambuls is on a distinguished road
slow pulses
hello
This is the first time I use LinuxCnc and a homemade cnc machine.
I created a stepper board driver with an IMT901 stepper driver and it works fine.
I would like to control these drivers using linuxcnc but I encountered a problem.
For a simpel test I connected pin 2 of my parallel port to the step-input of one of my drivers. This is the default value that 'emc2 stepper mill configuration' suggest. I can create a dummy configuration file with 'EMC2 stepper mill configuration' but when I want to test the motor it receives very slow pulses...
these are the settings of the x axis configuration:
motor steps per revolution : 200
driver microstepping : 2
pulley teeth : 1:1 (dummy value - I dont have a cnc yet)
leadscrew pitch : 1 mm/rev
max velocity : 2 mm/s
max acceleration : 5 mm/s^2
If I press the 'test this axis' button and press "run" I can see the step-led on my driver receiving approximate 1 step every second, this results in a very slowly revolving motor..
Am I doing something wrong?
I think that linuxcnc generates all the pulses needed to revolve the motor, or is this assumption wrong?
Old 03-16-2010, 07:10 PM
flash319 is on a distinguished road
I have found it easier to dial in steps and stuff just using the Configuration menu within EMC not the Stepconf wizard. Just go into EMC using Axis display program (this is default I believe) and go to Tools menu at the top (I think Tool) in the menu you will see configuration. If you go in there you can change the steps and rate. The first number is pulses per unit (inches or mm whatever you are in), They call it offset or something like that but that is all it is. Then under that is acceleration. Those are the only numbers that are needed to control the pulses. If you make the first number 3000 and the second 30 or 40 you will see very fast pulses.
Then just turn off the estop, turn on the power (both buttons top left corner) and then jog the axis.
Old 03-17-2010, 04:11 PM
CalG is on a distinguished road
The drop down is "Machine" and then "Calibration"
Try to look there
Tags
pulses, slow
Pulses Per Second stuck on 96 idtkid Mach Software (ArtSoft software) 6 04-01-2009 09:35 PM
Pulses Per Second stuck on 96 idtkid Mach Mill 0 04-01-2009 09:03 AM
Max pulses and IPM margni74 LinuxCNC (formerly EMC2) 7 12-05-2008 11:11 AM
Newbie- Accumulated pulses? MattTheNoob Gecko Drives 3 09-14-2008 08:59 PM
Step Pulses per second? thielert TurboCNC 2 11-06-2003 12:35 PM
