| LinuxCNC (formerly EMC2) Discuss LinuxCNC (formerly EMC2) Controlers here! |
If I want to cut a parabolic path, or any non-circular arc, do I need to be able to programme ? The alternative to writing hundreds of lines of code for small incremental moves would be to either write my own program, , or to be able to tell the machine to run some sort of iterative code that stops after a given number of cycles, then moves on the the next instruction. Any help, please ? John
__________________ It's like doing jigsaw puzzles in the dark. Enjoy today's problems, for tomorrow's may be worse. |
| Well, there's no canned cycle that will cut a parabolic arc, but if you can define the arc mathematically, I don't see why you couldn't get EMC to move from point to point along the arc. Running for a set number of cycles and them moving on, or cutting each cycle with a slightly different path (such as stepping down, or over, or along a radius) is the REASON I switched from Mach3 to EMC. I use conditional loops and program variables constantly at work, and just HAD to have them at home, too. ![]() http://www.linuxcnc.org/docview/html/gcode_main.html
__________________ http://www.youtube.com/user/vlmarshall |
| The end result is always a series of short, straight moves. The easiest way to get there is to find a CAD program that'll let you do what you want, and export a .dxf of line segments and convert that to g-code. Another easy way is to use Excel to output the G-code.
| Programming the part's surface path isn't so hard... figuring out how to compensate for the shape of your cutter can be fun though ![]() I.E. calculate the path of a vertical circular arc... x^2+Z^2=R^2 Z=(R^2-X^2)^.5 If your cutter is a sphere, it would come out fine if you just subtract its radius from the final radius, but if your cutter is a cylinder, flat end, like an end mill.... then you need some Trig. to find your cutter compensation... same for a parabola and a round cutter. |
| Hi John, I had a small program a couple of years ago that created code for mirrors, lenses and I think it would do parabola's as well, I cannot think of its name but if I can dig it up I will let you know. Cheers. Russell. |
| Morning all, and hi Russell. Welcome to another room in Greybeard's Home for the Bewildered. My request for this bit of info comes from my other thread on working out a centre line Roman letter plot. To generate a decent looking serif, the 60 degree v-cutter needs to follow a short parabolic helix, and given the emc doesn't have a gcode for that, it's going to be a series of short cuts, ramping down to the final depth of the main stroke of the letter. I have no problem with producing the function of the curve, but only have a vague idea on how to write the gcode such that the interpreter will calculate a series of steps for me. For example, if I needed to cut a sine curve - X [#1], y[ sin^-1#1] (where #1 goes from 0 to 1 in steps of 0.05 )(Not sure if ^ is the correct symbol for "to the power of") Then when #1 reaches 1, the plot moves on to the next line of code. I have some idea that this uses an IF -, THEN -, structure, but I don't know how to set it out. Regards John
__________________ It's like doing jigsaw puzzles in the dark. Enjoy today's problems, for tomorrow's may be worse. Last edited by greybeard; 02-27-2010 at 11:37 AM. Reason: syntax |
#10
O100 While [#1 LE 1] G1 X [#1], Y[ SIN^-1#1] #1=[#1+.05] O100 ENDWHILE ...but the [sin^-1] doesn't work.
#11
| My [sin^-1 *#1] was a complete guess as to how to express "that number which was the sine of n degrees, where n went from 0 degrees to 90 degrees in 20 steps". I think it should have read Y[SIN[**-1]#1], but I see it wouldn't have worked anyway. I'll see what I can learn about the WHILE/ENDWHILE command, but I may come back for more help. ![]() Regards John
__________________ It's like doing jigsaw puzzles in the dark. Enjoy today's problems, for tomorrow's may be worse. Last edited by greybeard; 02-27-2010 at 02:50 PM. |
#12
| Is there a list of O-codes showing specific meaning associated with particular numbers, or does the operator define their own meaning ?
| Need Help!- Circular Cut | mikelohj | LinuxCNC (formerly EMC2) | 1 | 06-18-2009 12:19 PM |
| What do you know about this circular saw??? | mailloux | WoodWorking | 5 | 10-16-2007 10:34 PM |
| Circular pockets not cutting round - Help! | watsonstudios | DIY-CNC Router Table Machines | 6 | 07-05-2007 03:42 PM |
| Circular Cut | Sanghera | GRZ Software- MeshCAM | 13 | 11-13-2006 10:26 AM |
| Circular Milling - G12/G13 | HPT | Servo Motors and Drives | 6 | 05-14-2006 01:22 PM |
