Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 32
Thread: Cutting a non-circular arc ?
  1. #13
    Registered vlmarshall's Avatar
    Mar 2006
    Quote Originally Posted by greybeard View Post
    Is there a list of O-codes showing specific meaning associated with particular numbers, or does the operator define their own meaning ?
    Nah, the O number can be anything, it's just a number to identify the subroutine.
    http://www.youtube.com/user/vlmarshall
  2. #14
    Registered greybeard's Avatar
    Jun 2005
    UK
    Just discovered how age distorts meaning
    I now find that [sin^-1] is the same as "inverse sine", is the same as "arcsin", is the same as "ASIN".
    So I've got 50+ years of name changing to catch up on.
    Ho hum.
    Regards
    John
    I think I'll go to bed with a headache
    It's like doing jigsaw puzzles in the dark.
    Enjoy today's problems, for tomorrow's may be worse.
  3. #15
    Jun 2005
    UK
    Back to square one, but at least it works so far !
    g17 g21 g40 g49 g54 g80 g90 g94
    #1=50 (scale)
    #2=[0.05*#1] (sh)
    #3=[8*#1] (feed)
    #6=0
    #7=0.36
    g00 x[0] y[0] z#2
    g01 x[0] y[0.015*#1] F#3 (start point)
    g01 x[0] y[0.015*#1] z[0.015*SQRT[3]*#1] F#3 (start serif depth and width)
    O100 WHILE [#6 LE 0.18]
    g01 x[#6*#1] y[[2.006173*[#6**2]+0.015]*#1] z[SQRT[3]*[[2.006173*[#6**2]+0.015]*#1]] F#3
    #6=[#6+0.009]
    O100 ENDWHILE
    g00 z#2
    AXIS allows me to use this bit of the code to cut a short path to start the serif, a parabola that ramps down to join the main vertical stoke.
    Next problem is how to most easily mirror/invert the curve, so that I can cut the other four corners the same, with similar code.
    In the WHILE/ENDWHILE , what does the LE signify ?
    Examples welcome.
    John
  4. #16
    Mar 2006
    Less-than or Equal-to.
    Congrats on the progress!
  • #17
    Jun 2005
    UK
    Oh G, it makes sense now. I can read it in English "While #6, is less than or equal to 0.18perform the following instruction".
    Thanks for the enlightenment
  • #18
    Jun 2005
    UK
    Next curious problem.
    N01 g01 x[#6*#1] y[[2.006173*[#6**2]+0.015]*#1] z[-1*SQRT[3]*[[2.006173*[#6**2]+0.015]*#1]] F#3
    N02 g01 x[#7*#1] y[[2.006173*[[-0.36+#7]**2]]+0.015]*#1] z[-1*SQRT[3]*[[2.006173*[[-0.36+#7]**2]]+0.015]*#1]] F#3
    The first line is accepted by AXIS, but the second is rejected with a warning that in the second line, a "*" is a "bad character".
    I'd be grateful for yet more help in identifying the error, as it's not something that I can see.
    The [-0.36+#7] was originaly [#7-0.36], but I switched it round when trying to track down the source of this problem, but it hasn't made any difference.
    I've found the pop-up window that AXIS uses sometimes not particularly helpful in the way it expresses an error.
    For instance using the "near line ..." rather than something more specific, and sometimes the targeted symbol is not the actual error at all, just affected by it.
    John
  • #19
    Mar 2009
    John-
    I haven't had time to pursue this myself but I've been following your progress and have been quite impressed with what you've accomplished so far!
    Have you checked out this page: http://wiki.linuxcnc.org/cgi-bin/emc...ode_Generators?
    Look at the dxf2gcode generator and the text engraving routine. It looks like you could find some good code to work with here if you want to delve into python.
    Keep up the good work!
    Best regards,
    Greg
  • #20
    Jun 2005
    UK
    Hi Greg, and thanks for the encouraging words.
    I've already had a quick look at those pages, and thought that I might well follow them up later.
    I feel the route I'm following at the moment, while it might seem a bit masochistic to some, will give me a good intro to gcode.
    Having to understand some of the details in depth will be a good discipline if and when I want to move on to python et al.
    I've been a problem solver all my life, and it's hard to give up the habit.
    Regards
    John
  • #21
    Registered WayneHill's Avatar
    Mar 2004
    Michigan
    Quote Originally Posted by vlmarshall View Post
    Something like:
    O100 While [#1 LE 1]
    G1 X [#1], Y[ SIN^-1#1]
    #1=[#1+.05]
    O100 ENDWHILE
    ...but the [sin^-1] doesn't work.
    Are they in radian values?
    Wayne Hill
  • #22
    Jun 2005
    UK
    It might help if I expand the current problem by posting a few lines of code.
    N01 O100 WHILE [#6 LE 0.18]
    N02 g01 x[#6*#1] y[[2.006173*[#6**2]+0.015]*#1] z[-1*SQRT[3]*[[2.006173*[#6**2]+0.015]*#1]] F#3
    N03 #6=[#6+0.009]
    N04 O100 ENDWHILE
    N06 g00 x[0.18*#1] y[0.08*#1] z#2
    N07 g00 x[0.36*#1] y[0.015*#1]
    N08 g01 x[0.36*#1] y[0.015*#1] z[-0.015*SQRT[3]*#1] F#3
    N10 O100 WHILE [#7 GE 0.18]
    N11 g01 x[#7*#1] y[[2.006173*[[#7-0.36]**2]+0.015]*#1] z[-1*SQRT[3]*[[2.006173*[[#7-0.36]**2]+0.015]*#1]] F#3
    N12 #7=[#7-0.009]
    N13 O100 ENDWHILE
    All goes well till line N10, where my attempt at producing a mirror image of the curve cut by lines N01 to N04 produces garbage - "G.I.G.O."
    Been trying to resolve the problem by trial and error, but no luck so far.
    John
  • #23
    Dec 2008
    canada
    Just a guess, but your using the same program name o100 in the second program.
    Try o101
  • #24
    Jun 2005
    UK
    Quote Originally Posted by Pandinus View Post
    Try o101
    That seems very sensible, so I'll do it. Thanks.
    In the meantime I've managed to get the best of three with AXIS, and now have a parabolic curve meeting its mirror image in the centre
    One thing I've noticed though, and here's a small bit of code to illustrate the point -
    #1=0
    O100 WHILE [#1 LE 0.18]
    g01 x[#1] y[0.5*#1]
    #1=[#1+0.009]
    O100 ENDWHILE
    Running this in the AXIS gui, the curve only goes from x0 y0 to x0.171 y0.0855 , rather than x0.18 y0.09.
    Is this correct ?
    I assumed the "less than or equal to" would finish when #1 reached 0.18
    Any comments ?
    John
  • Page 2 of 3 FirstFirst 123 LastLast
    1. Need Help!- Circular Cut
      By mikelohj in forum LinuxCNC (formerly EMC2)
      Last Post: 06-18-2009, 01:19 PM
    2. What do you know about this circular saw???
      By mailloux in forum WoodWorking
      Last Post: 10-16-2007, 11:34 PM
    3. Circular pockets not cutting round - Help!
      By watsonstudios in forum DIY CNC Router Table Machines
      Last Post: 07-05-2007, 04:42 PM
    4. Circular Cut
      By Sanghera in forum GRZ Software- MeshCAM
      Last Post: 11-13-2006, 11:26 AM
    5. Circular Milling - G12/G13
      By HPT in forum Servo Motors and Drives
      Last Post: 05-14-2006, 02:22 PM
