Just finished setting up linuxCNC and ran a code that I had used before and that I knew worked to test out the software. when I checked the dimensions of the part came out bigger and i cant figure out where the issue is .I've used the same Gecko drive and motors before with Grbl connected to an arduino so I know its not an issue with the electronics. Thanks for the help .
