Linuxcnc Mesa 5I25 + 7i76 5v Enable signal
Results 1 to 5 of 5
Thread: Linuxcnc Mesa 5I25 + 7i76 5v Enable signal
    Member Tkamsker's Avatar
    Oct 2010
    Austria
    Default Linuxcnc Mesa 5I25 + 7i76 5v Enable signal
    Hi i
    am aware of the thread from 2012
    i have now in 2016 similar problem we have 2 Granite VDE and for the Z Axis an Delta Drive and servo. The Delta works perfect-
    Now my issue i also need an 5v + for enable but when i measure pin 1 to 6 i should get 5v i read 0,22V
    no matter what i do i don't get 5v my workaround would be the Enable always on 5+v
    so my question is is there an easy way around or do i have to do an PCB with optocoupler which does get 24V from Out signal to convert to the Enable signal ? I expect that almost everyone has this isseo ?
    any help would be nice
    thomas
    Feb 2008
    Default Re: Linuxcnc Mesa 5I25 + 7i76 5v Enable signal
    If you dont use all 5 step/dir axis, you can use a spare step or dir signal for a 5V enable.
    If the 5V enable input is an OPTO input, you can also probably use a 24V signal with a
    series resistor (check with the drive manufacturer)
    Oct 2010
    Austria
    Hi PCW_Mesa wow that is fast thank you i appreciate it
    i thought about this so i will use the Step+ from the 6th axis for enable and when the System get powered on the servo is enabled.
    But i thought i could use the 5pv Pin 6 for instance why does it show 0,22v ?
    Reading the Manual https://granitedevices.com/assets/fi...160_manual.pdf i interpret that everything else than Enable and Fail is Opto coupled - (page 5 ) But i am not sure chapter 7.4 page 13 says optocoupler
    pin 10 and 11 is used for IN3 = Enable out 2 = error ? I am afraid to grill the device but maybe it should work out well ?
    best reg thomas
    Feb 2008
    if 5VP shows .22V that probably means either you have no 5V to the 7I76
    or perhaps you have a wiring short somewhere
    (The 5VP pin is common with all 5VP pins on TB3 and all are supplied via a PTC device so a short on any pin would give the symptoms you see)
    Oct 2010
    Austria
    You where right about short thank you
    Gesendet von iPhone mit Tapatalk
