You'll need to ask the LinuxCNC people.
I'm in the process of designing a 3-axis gantry-type machine. I've been going in circles with hardware setups and looking for some answers as there seem to be more options and hardware and things seem to be changing quickly.
I'm trying to work to a reasonable budget and keep components/setup simple-ish.
I'm looking to use something like this forr the computer: Intel Motherboard BLKD2550MUD2, Atom Dual Core 2500 NM10 mITX 2xSODIMM DDR3 LVDS+DVI+VGA+LPT, PCI, 4/3 USB2, GBLAN
and something like this for motion:
DMM AC Servo Kit
FYI,I don't want/like steppers.
From what I understand about the Servo options, there are two basic options(correct me if I'm wrong)
The stepper-type that do step-direction(As I understand, this isn't a FULL feedback loop back to the controller. The servo motor has internal feedback loop to itself.) With these servos, I couldn't truly synchronize two servos for something like Rigid Tapping or Lathe Threading
The real deal servos where encoder signals are fed directly into the controller(linux cnc). Fully closed loop. Servo Synchronization, position feedback, etc.
I'm looking for option 2.
Aside from any peripherals and bonus IOs and whatnot, generally speaking, what hardware is required to get linuxCNC to control the servos with full feedback? Are there any complete kits? Do I need a PCI card or only onboard parallel port? What's recommended here? Mid-Low cost.
TLDR; Starting from scratch, what hardware components are required end to end for a 3-4 axis full feedback servo setup to get up and running from nothing?
Thanks for you guidance.
UCCNC 2017 Screenset
The process you are talking about is electronic gearing, this is when one or more (slave) servo's are geared after a master encoder, there is Kflop that will also do it.
AFAIK you would need a motion card for Linux.
I do the same process with a Galil card, there is a plug in for it in Mach, I have used the Galil many times but not in Mach so you would need to check the Mach site on that.
