Newbie Probotix Meteor Fireball won't read a Mastercam NC router post
Results 1 to 3 of 3
Thread: Probotix Meteor Fireball won't read a Mastercam NC router post
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Default Re: Probotix Meteor Fireball won't read a Mastercam NC router post
    Quote Originally Posted by poolrod2 View Post
    Hi all, is there a Mastercam post that will run EMC2?.
    No
    No post actually runs a machine
    A post processor is a decoder type file that translates the operations (toolpaths) created in the CADCAM software....into a NC coded file ( that then is used to control the machine )
    ( the post is customised to suit the specific machine control )
    You need
    - a PC that is capable or running Mastercam software ( Requirements LINK )
    - post processor
    - (if needed, RS232 transfer method ) Transfer software ( Mastercam does have a choice of text editor/transfer software bundled with the install )
    - network cable/cards, if a PC to PC transfer method
    Mastercam is not proven to run on Linux
    .....plus you shouldn't run any CADCAM software on a PC that also controls a machine
    Running one may affect the operation of the other
    Sep 2013
    I made the toolpath in Mastercam, posted it in Mastercam using the router post from Mastercam. Loaded it in my Probotix computer with my flasdrive,but it said bad charactors on several lines and other lines had other errors. I had to use Aspire with a Probotix post but Mastercam is much more user friendly for toolpaths. Thank you for the help.
