Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 02-18-2010, 09:19 PM
bigalexe is on a distinguished road
Need a small ball-screw or similar
I am looking for a small self-contained ball-screw or similarly powerful linear actuator mechanism. I would prefer if it were powered by either a 9V battery or AA's for the prototype but after that I will probably move onto something with a bit more juice. My needs are for a good amount of power and low linear speed. The power will be divided by 13-16 depending on the length of the lever arm, hence the need for excess power.
The dimensions I would like are 2 to 6 inches long by 1 to 3 inches in the diameter. I would also like it to weigh as little as possible but realize with a self-contained unit its not going to be feather-light.
Also of note is that in the end this mechanism will be covered with a guard so that needs to be kept in mind when it comes to designing dimensions.
Stuff i can use: AutoCAD 2010, AutoCAD Inventor 2010, Solidworks 2009, MasterCAM X2/X4, CNC's FADAL, and Hurco 3-axis CNC Mill
Old 02-19-2010, 11:09 AM
packrat is on a distinguished road
Do you mean something like this? http://www.anaheimautomation.com/pro...ist.php?cID=52
While not ball screws they are very smooth moving.
what bearing fit with acme screw 1/2 -10(for cheap ball screw) apex Linear and Rotary Motion 4 07-27-2007 11:15 AM
roller screw versus ball screw. Paraprop Linear and Rotary Motion 2 04-15-2007 04:21 AM
Belt vrs. Ball Screw vrs. Lead Screw stevesplanes Linear and Rotary Motion 7 01-09-2006 11:23 AM
New technology.... old debate.....ball screw vs lead screw trubleshtr Linear and Rotary Motion 1 08-15-2005 08:42 PM
acme screw to ball screw question Billw DIY-CNC Router Table Machines 9 07-18-2005 12:10 AM
