Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 04-14-2005, 06:01 PM
2muchstuff is on a distinguished road
Linear Bearings
I'm trying to build my cnc router using THK type linear bearings. My problem is that there seems to be a lack of longer length rails available on Ebay, or I'm getting impatient. I know it is possible to match up the ends of two shorter length rails to create one longer one. My question is will there be a problem with the smoothness as the bearing truck rides over the joint? I don't want any problems to appear on the part that I'm trying to cut out because of the joint. Any comments are more than welcome.
If it's not nailed down, it's mine.
If I can pry it loose, it's not nailed down.
Old 04-14-2005, 06:16 PM
ger21's Avatar
If you make a "perfect" joint, it should be ok. Stagger the joints on the two rails, and you should be OK. Have you considered the Bishop Wisecarver Dual Vee rails and wheels? They might even be better for a router, as you don't have to worry about dust getting in them.
Old 04-14-2005, 06:33 PM
I like to scrounge stuff up but I think that I have gotten to the point where parts will need to be bought. I have seen the dual vee rails used on large machines, how do they compare in price per foot to the THK style? Do they come up on Ebay?
Old 04-14-2005, 07:42 PM
ger21's Avatar
Never seen them on Ebay, but they have prices online. http://www.bwc.com
Old 06-28-2005, 06:58 AM
bcox999 is on a distinguished road
Wink
http://www.misumi-europe.com/eucatalogue/04.html
Old 06-28-2005, 09:11 AM
mxtras's Avatar
Silver Member
mxtras is on a distinguished road
If the THK type rails were not ordered for end to end use, the factory chamfers the ends. Even with perfect alignment, you will have a small hitch in when the bearing passes over the seam - you can feel it during assembly, but I have never really noticed it once the motion platform is assembled and running. It's there, but it's less noticable after assembly.
Scott
Consistency is a good thing....unless you're consistently an idiot.
Old 06-28-2005, 09:27 AM
Moderator
Halfnutz is on a distinguished road
I just built a gantry style frame and butted rails together in two places. It works fine, but only after some serious work. It is very hard to align everything and get a smooth ride over the joints, but it can be done. I would avoid it if possible, but if you have to, be prepared for a lot of additional work aligning them correctly. The problem is when you drill the mounting holes and tap them everything must be EXACTLY right, or when you tighten the screws up it will pull the rails allignment out. A real pain in the $*&, but not impossible. As just mentioned, once everything is put together, there is allmost no detection of a ridge or bump, but while putting together you can feel it on some joints. I had to remove the chamfer on my rails before assembling by sanding with a stationary bench disc sander.
Halfnutz
Old 06-28-2005, 09:37 AM
Lightbulb Misumi
Misumi supply rails up to 2Meter in 1mm....is that enough
Old 06-23-2008, 12:07 PM
Need TECH Help!'s Avatar
Need TECH Help! is on a distinguished road
Linear Rails
Hello,
Iam making my own bench top mill and plan on using Linear Rails like the THK.
Question has anyone heard of or used HIWIN rails and blocks?And,ever heard of automation-overstock.com.They have bought out the stock of HIWIN,but not sure if they are safe or not,i dont see any security locks or links on there web site.
Any help and direction to low cost rails would be awesome
Troy
Old 07-09-2008, 08:20 PM
ProDrawerCom
IQChallenged is on a distinguished road
I did. Are they the best in the world? I don't have a clue. But how good does your system need to be? Are you going for hobbyists quality or NASA quality? I'm far from an expert but I doubt any linear rails and blocks are better than some of the alternatives like roller-skate wheels. And I'm not knocking those systems. I think they're great. If I build another system I'll probably go straight to automation4less.com and just buy new retail rather than wasting time with eBay. Of course, if I can find them on eBay pretty quickly I will.
ProjectCNC.wordpress.com
  #11   Ban this user!
Old 07-09-2008, 10:04 PM
bml6116 is on a distinguished road
I have bought -amongst other things- 3m long Hiwin rails for a CNC router from automation-overstock. I did pick up the merchandise in person since I live fairly close. Automation-verstock and automation4 less (same outfit) have a huge warehouse full of linear ways, bearings, aluminum extrusions, etc, etc.
I bought new 'old stock' at a very reasonable cost. Also the guys there are extremely helpful and accomodating.
Disclaimer: I am not connected in any way to that business, just a very satified customer.
Cheers,
Bernhard
  #12   Ban this user!
Old 07-10-2008, 09:05 PM
Kevin Taylor is on a distinguished road
Two much Want a router with a dead control P.M. me and I will see if I can hook you up It may be gone but for the money the Iron would salvage for the cost about 350 mi from you Kevin
Bearings for home made linear Alaskan DIY-CNC Router Table Machines 12 08-14-2005 02:09 PM
Need help on linear bearings bbergami DIY-CNC Router Table Machines 11 05-25-2004 07:04 PM
Nylon Linear Bearings and shafting Jcadwell CNCzone Club House 7 04-15-2004 09:29 AM
Linear Guides with Teflon Bearings cely General Metal Working Machines 0 03-19-2004 05:05 PM
It seems my linear bearings don't fit... mikeschn DIY-CNC Router Table Machines 13 01-28-2004 04:45 PM
