Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 02-01-2010, 12:34 PM
GTRClive is on a distinguished road
Shizuko AN-S X Axis Ballscrew Replacement
Hi All, I have 0.006" back lash in my X Axis. I stripped the axis and it's all in the Ball-screw, anker Bearings fine.
I can preload the Ball-screw with a bigger spacer between the two half's but has anyone else done this, and I'm worried that this amount might just mean it time to replace the whole screw......
Where do you get a replacement ?? I can supply a CAD drawing of the screw if needed, I would like to know how much it might cost to just replace the screw.... Its 30mm diameter on the main screw part, and has a Keyed stile nut held between endcaps on the housing.
Any info gratefully received
Shizuko AN-S What power axis motors do I need ? GTRClive Knee Vertical Mills 11 05-06-2010 11:17 AM
Need Help!- Ballscrew Cover Replacement on TM-1 heavensoutlaw Haas Mills 8 07-30-2009 04:22 PM
Ballscrew replacement/regrind? jetblackaircraf Linear and Rotary Motion 0 05-01-2009 05:26 PM
AN-S and SN-T Shizuko Whats the difference ?? GTRClive Knee Vertical Mills 0 05-18-2008 09:21 PM
EZ-Trak DX2 Z ballscrew replacement brassdrift Bridgeport and Hardinge Mills 1 01-18-2008 06:35 PM
