Results 1 to 11 of 11
Thread: Idler and Drive rollers for pick and place machine
    Jan 2010
    Hi All,
    I'm an electronics engineer running a design firm in Melbourne Australia, and I've started designing a pick and place machine for surface mount assembly of components.
    For a start I'm looking for good sources of idler rollers and drive rollers. Can any one suggest a good source of low cost miniature rollers, preferable from an online store.
    I thought I'd start with the SMD feed mechanism and move on from there. This is intended for personal use although I'm toying with the idea of making the various sub assemblies and completed machine available through my web site for the general public.
    Any tips would be appreciated.
    Regards
    Robert
    Mar 2006
    low cost = ? miniature = ? dia. x length?
    Can you be more specific?
    Dick Z
    DZASTR
    Jan 2010
    Quote Originally Posted by RICHARD ZASTROW View Post
    Dick Z
    Dear Richard,
    Thanks for the reply. I'm looking for idler and drive rollers of aproximate diameter of 15mm. Width about 15mm. The exact size isn't critical. With intergrated bearings, either sintered bronze/plastic or ball bearing.
    In a pick and place machines each component is held in a reel. If there are 20 components to a pcb being assembled then you need 20 reels, and therefore 20 feed mechanisms that peel the tape off the paper substrate and expose the component to be picked. I'm thinking I need 3 rollers per mechanism so I'm anxious to keep the roller costs to a minimum. Anything under $4 per roller
    would be good.
    Regards
    Robert
    Mar 2006
    Is it possible to shrink fit or glue rollers to a shaft? If so, the rollers could be made from sections of tubing and finish ground to size on the shaft.
    Should be inexpensive if this is possible. Just a thought.
    Dick Z
    DZASTR
    Jan 2010
    Dick Z
    Thanks richard,
    But I'd rather buy them. The quality would be better, and the labour cost of machinining your own can significant. Its false ecomomy.
    Regards
    Robert
    Mar 2006
    You might try this for info. www.fnsheppard.com Their catalog may help.
    Dick Z
    DZASTR
    Jan 2010
    Dick Z
    Thanks Richard,
    I downloaded their catalog but it doesn't mention stocked items. I suspect its a custom made to order place as are so many of them.
    I don't understand why these places just don't slightly over produce a custom roller and then throw it on the interent for on-line sales.
    I've had a surprisingly hard time finding stocked rollers at all, and much less at reasonable prices.
    I'll keep looking I guess or figure out a way to produce a Pick and place machine with a minimum of rollers.
    Thanks,
    Regards
    Robert
    http://www.priority1design.com.au
    Aug 2005
    Smile Bearings
    Jan 2010
    Quote Originally Posted by Robski View Post
    Thanks Robski,
    Yes, great prices on bearings. I'll probably buy some. Although I can't seem to locate any rollers, as in neoprene covered wheels, and the like.
    Thanks,
    Regards
    Robert
    Mar 2006
    Robert, Just had a brain fart. Could you use "O" rings stretched over a bearing or shaft? Just another thought.
    We used to repair feed rollers for printing presses. We cut sections of semi-soft plastic tubes, heated them in hot water to stretch them over cylinders. After they cooled and shrunk (shrinked?) tightly onto the cylinders, we ground the OD of the the plastic "tires" to size.
    Dick Z
    DZASTR
    Jan 2010
    Dick Z
    Thanks Richard.
    I don't think that would be ok in this case. The pick and place machines need to feed tape through which can be from 8mm to 18mm wide. The o-rings would be too small a contact point. Besides I'm hoping to avoid that patched up look about the machine. I'm mostly an electronics guy so machining stuff is mostly a pain for me. Although I get by when I'm forced to improvise. See my virtual reality exoskeleton from my gallery page of my web site.
    http://www.priority1design.com.au/gallery.html
    Now I'm thinking I should just limit the amount of rollers in the design if possible because of their expense. I'm just surprised about how hard it is to locate rollers at all, let alone cheap ones.
    Regards
    Robert
    1. SMD pick and place
      By ciccio in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 01-19-2010, 01:34 AM
    2. Anyone SC or NC need a Pick & Place?
      By Al_The_Man in forum CNCzone Club House
      Last Post: 01-18-2010, 03:46 PM
    3. pick & place machine
      By gombault in forum LinuxCNC (formerly EMC2)
      Last Post: 09-19-2009, 02:19 AM
    4. Newbie- who has smd pick place software???
      By C++ in forum Printing, Scanners, Vinyl cutting and Plotters
      Last Post: 03-04-2009, 02:43 PM
    5. Pick-and-place using a CNC mill
      By mickelsen in forum CNC Tooling
      Last Post: 12-23-2007, 08:02 PM
